(#4451)
Mastermixlee Mastermixlee is offline
Car: 335
Default 06-12-2012, 01:27 PM
Most thefts I have heard of here in the uk have been to do with a weakness with the security system which BMW are not admitting too. If you look on the bimmer forums there's quite a few articles on there about it too.
OldBooster's Avatar
OldBooster OldBooster is offline
Car: 2008 135i AT
Send a message via Skype™ to OldBooster
Default 06-12-2012, 01:56 PM
Originally Posted by mykal335xi
Have you run the car on the dragstrip with RBs?
Full weight, 1/2 tank race gas, dual meth, mufflers, MTs, 60 add ... bad launch, some spin into 2nd ... first run out of the box: 11.4 @123 mph ...
If I had perfected a 2nd gear launch, and not launched in 1st gear, it would have been better, ... but the car felt amazing and shifted good, even after many abusive power runs since '08.
Next time out, maybe Thursday if the weather holds up, I'll be prepared and have the car set up right (and with Terry's terrific help with logs and advice), I can try some more aggressive settings.
Cheers!
Held #1 on www.DragTimes.com:
First to run 11.012 @129.30
Xearo's Avatar
Xearo Xearo is offline
Because Racecar
Car: '08 135i
Default 06-13-2012, 08:59 AM
Originally Posted by Kurukt20
Hey Terry or any admins. I was wondering something. I set my JB4 Spedo 4 tacho 5 for the Canflap to be open, but I can bearly hear it go off like the one in the video. Is there anything special that you did? Just wondering. Thanks!
With the car running, take a piece of card board and hold up to each tail pipe; observe results. Then enable the canflap option and hold the card board up to each tail pipe again. Should have different results.
EDIT: Like this http://www.youtube.com/watch?v=19pq3nk8bRc
-'09 135i MT - Custom 6466 ST - 680whp
-'08 135i AT - 6466 ST - dead
-'97 318is - Daily
-'82 320i
mrbillytalent's Avatar
mrbillytalent mrbillytalent is offline
Probably being sarcastic
Car: e46 323i & e90 335i
Default 06-13-2012, 09:31 AM
All it does it close off the drivers side tail pipe and route all the exhaust back to the other pipe. I just had my exhaust out a few days ago. It's a terrible simple design
200k mi 99 blk 4dr e46 m52 323i w/ h&r's k&n cai shark'd
95 e36 m3 s50 5spd stg2 turner re11a's autox toy lol
07 BSM 6spd e90 n54 335i jb4 g5 iso ar dp's SPEC 2+ w/ SMFW BMW ssk bms dci RB pcv 455lph lpfp 50% e85 Syn. BOV hijk lmnop
94 e34 530it 290k 350ci sbc tko600 project
robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default 06-14-2012, 10:05 AM
Originally Posted by Ocean
Put a tracking device on your car. Then if it goes missing, round up a couple of NRA buddies and a juiced up Big Foot, follow the signal!
Lol!! Or just leave a iPad in there and go to your pc and do the "find my iPad app" roflmao!
JB4 G5, ***** flash, 455 LPFP, HFS-4 meth kit, BMS OCC, VM 6466 ST, RB valve, BMS DCI, 3" AR ***, Custom OC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 guide rods, M3 upper links, M3 front & rear sway-bars, HPA rear toe arms, Wavetrac LSD, HPF Gen 2 exhaust DEFIV kit, KW clubsort, Delrin solid subfrane bushings, stoptech rotors, Rogue Tranny Mounts, 1M bumper, M3 CF hood, MORR VS8.2 rims 245/295
davidrbixby's Avatar
davidrbixby davidrbixby is offline
Car: 2008 335i Sedan
Default 06-15-2012, 08:53 AM
Anyone know the max oil and water flow rates at over 6000 rpm? Trying to decide if I need to add more capacity or cooling to both for South Florida summer track days. Running RBs at 18.5 psi.
2008 E90 Sedan 335i, BMS G5, Quaife LSD, BMS Intake, Forge Diverter Valves, ER Charge Pipe, Forge Intercooler, Macht Schnell down pipes, Bilstein Suspension, M3 Hood, Bumper, Sideskirts, Custom 700hp Oil Cooler, Square 18x9.5 wheels with 275/35R18 Continental Cup Tires.
Vroom's Avatar
Vroom Vroom is offline
Car: 335i 318ti
Default 06-15-2012, 10:48 AM
Don't know flow rates, but post a pic of your oil cooler & use the MaxCool option.
Default 06-15-2012, 12:39 PM
@Vroom, Not the issue....I have a 40 row and 16 row dual oil cooler setup. Looking for flow rates to see how quickly oil and water flow round trip above 6000 rpm, and then to see if I need to add capacity to coolant and oil. We have only so much space and airflow and I use a lot already between the radiator, intercooler, 2 oil coolers, and dual race brake ducts to the caliper and wheel hub.
OldBooster's Avatar
Car: 2008 135i AT
Default 06-15-2012, 02:11 PM
Update: last night at the track I managed a 11.10 @ 124. Awful fishtail out of hole even with 2nd gear launch and MTs. Track was not dried out. I'll try again on Sunday. 10s are getting close. Oh, and NO NITROUS!
OldBooster's Avatar
Car: 2008 135i AT
Default 06-15-2012, 02:17 PM
Look at the lousy 60' ... here's the slip:
Default 06-15-2012, 02:25 PM
Very good start for the track conditions. With a little more aggressive tuning and a solid low 1.6 60' I see a 10 second run in your future!
mykal335xi mykal335xi is offline
boom
Car: BMW
Default 06-15-2012, 02:33 PM
Wow that's awesome! The trap seems low, do you have quite a bit more room to push boost on the RBs?
2011 335i m-sport
2008 335xi (Sold)
themyst themyst is offline
Super Demigod
Send a message via AIM to themyst
Default 06-15-2012, 02:54 PM
What kind of DA were you dealing with? That trap is awfully low for a 75 add?
E90 LCI N54 6AT
OldBooster's Avatar
Car: 2008 135i AT
Default 06-15-2012, 03:03 PM
I really don't know how much boost the RBs can handle. I dialed in a 75 additive and could have used more octane to max it out.
My best trap last night was 127. Keep in mind it was a Thursday night test & tune with a poor, non-prepped track. Good launches and a decent track are paramount to breaking personal records.
One nice tidbit: my 11.2 run at 127 let me reel in and pass a very nice GT-R at the 3/4 mark. He jumped out in front a good car-length at the start. That brought a lot of Corvette guys over to my car!
Cheers!
shuteng486 shuteng486 is offline
Car: 2010 E60 535I
Default 06-15-2012, 03:12 PM
i am scared to drive my car with map 5 e85 50% mix with 91.
SO fast!!!! i love eco map too.
save some fuel.
Super Demigod
Default 06-15-2012, 03:13 PM
Cheers!
Full weight, or seats out?
E90 LCI N54 6AT
OldBooster's Avatar
Car: 2008 135i AT
Default 06-15-2012, 03:25 PM
Seat out, but 2 gallons of meth and 1/2 tank fuel. I'd like to find out how to reduce the weight without sacrificing the daily driving comfort. What do you think of removing the exhaust system entirely and blow straight out of the *********? For the track only, of course!
Super Demigod
Default 06-15-2012, 03:31 PM
I think it will whack out your o2 sensors and cause all sorts of fuel anomalies. I think that's what Cobb said at least.
You need to get that car somewhere cold up north. I got a feeling it's got higher trap speeds in it
E90 LCI N54 6AT
Vroom's Avatar
Car: 335i 318ti
Default 06-15-2012, 03:36 PM
Really just wanted to see the custom oil cooler in your sig. Thinking of adding something myself.
Default 06-15-2012, 04:37 PM
I've done it just around town to see how loud it would be, etc. Once drove to the track 300 miles round trip with the rear muffler section off. With a 1 series it's fairly easy to do and saves 30#. You just make a little bracket to hold up the midpipes.
jrsniper12453 jrsniper12453 is offline
Default 06-19-2012, 01:48 PM
So is there any chance a 0-60 readout is ever going to make it to JB4? I know you haven't gotten into the display but maybe use the speedo to read the time back?
Default 06-20-2012, 05:57 AM
This
Trickcruiser's Avatar
Default 06-20-2012, 11:44 AM
Been doing some testing of the new G5 board and am VERY happy with the way my car is running right now! The car is reaching and holding target better than ever.
Car Details: FBO - Meth 70/30 - Dual CM10's - 45 Add - 93 Shell - NOS Booster
Pull: 70 to 140+
robc1976's Avatar
Car: 2007 335i
Default 06-20-2012, 11:49 AM
Pull: 70 to 140+
My god that is a good log, it grabs boost fast in the lower RPMS!! I thought my G4 log was good....really nice man your PWM is low to...I am jealous lol!!
robc1976's Avatar
Car: 2007 335i
Default 06-20-2012, 11:50 AM
Pull: 70 to 140+
Stupid question but are you running a custom map? Map 6 possibly? Or is hs map 3.
