(#1251)
Default 12-19-2018, 08:50 AM
Then new fuel control is working perfectly. Nice to see IAT not climbing as much as you might expect at higher speed too.
Sboylan Sboylan is offline
Car: Kia stinger gt1
Default Intake - 12-19-2018, 11:11 AM
Any update on Intake release/price?
Default 12-19-2018, 11:43 AM
Yes we have 100 in stock. Page should be live today and I'll make a post when it is.
D-C D-C is offline
Car: Stinger
Default 12-19-2018, 12:08 PM
Hi Terry
Can you please check the attached log using your new v7 firmware. The car cut power in 4th gear around 5200rpm it was like hitting a rev limiter this happened twice but I was only doing around 160km. Thought I better get you to check if everything is ok before making more logs
Default 12-19-2018, 01:25 PM
Originally Posted by D-C
Hi Terry
Yes I see it here. The power cut is from fuel pressure dropping.
Why did you disable fuel control? No fuel wires? What E85 mix? Fuel wires are needed for these power levels.
Adamdan Adamdan is offline
Car: Stinger
Default 12-19-2018, 01:33 PM
With v7 I thought the fuel setting did not to be entered in. How would someone disable fuel control or enable?
D-C D-C is offline
Car: Stinger
Default 12-19-2018, 01:35 PM
Did I disable the fuel control ?
I thought I had to change future use D to 1.
I'm running easily more than 30% E85
In my previous log you said fuel wires are working so I must have changed to the wrong setting ?
D-C D-C is offline
Car: Stinger
Default 12-19-2018, 01:46 PM
I think I know what I have done.
I turned on bit0: which gave me a value of 1.
Where as I should of turned on bit1: to enable fuel control which would give me a value of 2.
Is that correct Terry ? It was a little confusing at 5am this morning lol
I assume the JB4 cut power because the fuel pressure drop to protect the car ? so no damage would have been done ?
Default 12-19-2018, 01:47 PM
All FUD options should be off by default. Including bit1. Turning on bit1 disabled fuel control per the notes.
washguy washguy is offline
Car: gt2
Default 12-19-2018, 01:50 PM
Terry V7 b-2 is a winner...so smooth....I also backed down to map2 cause map3 is really not useful with cold pavement and map2 does such an awesome job! CONGRATS!
Wash
Default 12-19-2018, 02:11 PM
Wash
D-C D-C is offline
Car: Stinger
Default 12-19-2018, 02:44 PM
That explains a lot lol
A good lesson don't try upgrading your maps at 4:30am on light sleep
Mr GT2's Avatar
Mr GT2 Mr GT2 is offline
Car: Kia stinger
Default 12-20-2018, 08:56 AM
Oh wow I haven't checked back in here in a bit and I see there's been like 4 updates to the jb4 I'm still on 5_T5.hex cant wait to see if the new firmware makes a difference definitely taking a trip to Mexico tonight to get a full pull 0-130
brancky3 brancky3 is offline
Car: '18 Stinger GT2
Default 12-20-2018, 08:58 AM
v7 is actually a really big upgrade. I love the new fuel delivery.
hungtran505 hungtran505 is offline
Car: Kia Stinger
Default 12-20-2018, 09:00 AM
What mods does everyone have on there car?
Car: Stinger
Default 12-20-2018, 09:16 AM
I have k&n panel filters jun ********* and evc catback and stock plugs gapped to .024.
Default 12-20-2018, 09:54 AM
Log from a crazy Korean customer hitting his ~168mph speed limiter on WMI, 60 additive.
Default 12-20-2018, 09:57 AM
Log from a crazy Korean customer hitting is 160mph speed limiter on WMI, 60 additive.
Good God! Look at that smooth-ass AFR!
Default 12-20-2018, 10:06 AM
I could not be happier with how the v7 fuel control panned out. You guys can partially thank JohnB@Tork for that, all his continuous bull**** posts in JB4 threads pushed us to reinvent a better wheel on that algorithm to beat his ET.
Default 12-20-2018, 10:08 AM
Oddly enough I haven't seen him comment on the 1/4 mile defeat since you posted that
Default 12-20-2018, 10:17 AM
I'm sure he's busy installing his 50shot of NOS now to ensure he takes back the "record"
Default 12-20-2018, 11:42 AM
Better late than never... Finally released our BMS Stinger Intakes! In stock and ready to ship. Intro price $329.
BMS Kia Stinger Performance Intake - BurgerTuning.com
Broobrou Broobrou is offline
Car: Stinger
Default 12-20-2018, 11:44 AM
Materials?
Default 12-20-2018, 11:47 AM
Originally Posted by Broobrou
Materials?
Powder coated aluminum. Considered rotomolding but the problem with this application is the rotomolded tubes themselves are really thick so the only way to do that without adding restriction is to go all the way to the turbo, making the install more complicated. The factory turbo inlets themselves flow really well so this design for us was the most viable design.
Default 12-20-2018, 12:02 PM
To be used with the stock airbox bottoms? Very interesting; makes putting it back to stock pretty easy I'd imagine.
