michaelalex17 michaelalex17 is offline
Car: 335xi coupe
Default what codes does "auto code clear" delete? - 11-18-2013, 03:05 PM
hello, obviously it deletes the tuner codes and I guess a related ******** code so you can run ***-less *********, but was else does it clear? I think I might need to replace my 02 sensor but i have not gotten one of those "2C7C lambda probe behind catalytic converter 2, signal" codes in awhile, I want to make sure the jb4 is not autoclearing these codes. thanks
Default 11-18-2013, 03:26 PM
If auto clear is on it will eventually clear any pending code. Active codes will continue to show a light in dash, though. As a general rule of thumb if you get a light in dash disable auto clear or switch to map 0 to further troubleshoot.
********* will trigger 29F4/29F5 codes only.
Car: 335xi coupe
Default 11-18-2013, 05:20 PM
ok great thank you very much Terry
muzzammil15 muzzammil15 is offline
Car: 07 e92
Default 11-18-2013, 05:22 PM
After installing *********, I had cel for 2 days and afterwards it went away on its own. What would cause that terry?
coolbho3k's Avatar
coolbho3k coolbho3k is offline
Bravest N54 Owner Award
Car: BMW 335xi
Default 11-18-2013, 08:57 PM
If it got cleared, don't think anyone what it was can tell unless you read (past tense) it out... try reading out your codes now and see if there's a related code that wouldn't throw a cel?
2007 E90 335xi 6AT Premium Pkg | JB4 G5 ISO | Cheap custom exhaust: OBX ********* ***, Secondary *** Delete w/ Magnaflow Xpipe | WedgePerformance Backend Flash ("PUMP") | DCI | BMS Cowl Filters | Alpina TCU Software | M3 flappy paddles retrofit | NGK "one step colder" Soon: custom oil cooler retrofit, VRSF 7" FMIC
