Sheddy's Avatar
Sheddy Sheddy is offline
Car: 2016 Lexus IS200t
Default 10-03-2017, 08:29 AM
Any more kits Terry?
Default 11-07-2017, 12:23 PM
Tuners are finally in stock!
Will add to our site shortly.
Sheddy's Avatar
Default 11-08-2017, 08:58 AM
Ok great!, I informed the Lexus community!
Default 11-08-2017, 09:21 AM
It's on the website here: http://www.burgertuning.com/lexus_pe...nce_tuner.html
I'll work on the install guide later this week, but it's just two easy to reach connections.
Default 11-27-2017, 02:38 PM
Added a basic install guide to our site so should use some additional photos. If you want to help the cause post some photos here as you're doing the install and we'll grab the best ones to update the guide.
Sheddy's Avatar
Default 11-30-2017, 08:04 PM
Awesome! Hopefully the sales are doing well. I’ve had quite a few people inquiring about your product.
Default 11-30-2017, 08:33 PM
A few are out there but I'd love to see more customers post their feedback and reviews.
Sheddy's Avatar
Default 12-19-2017, 08:25 AM
I've installed a PPE test pipe, FTP charge pipe and turbo muffler delete. I will do some testing with the +6 PSI setting.
Sheddy's Avatar
Default 12-19-2017, 08:26 AM
Default 12-19-2017, 08:43 AM
Nice!! Grab a Dragy off our site so we can check actual performance metrics too.
Sheddy's Avatar
Default 12-19-2017, 09:20 AM
Would definitely look into it!
Sheddy's Avatar
Default 12-19-2017, 09:38 PM
Terry, do you think it would perform well having those bolt ons with the +6 psi setting on 93 oct? I remembered you telling me less is more in some situations.
Default 12-19-2017, 09:45 PM
The turbo is the limiting factor, so what you set the Stage1 to, as long as its at +4psi or higher, probably won't make much difference. But uses the Dragy to do before/after testing for each mod so we know what the real world benefit is.
Sheddy's Avatar
Default 12-19-2017, 10:11 PM
Thanks for the information, Iíll keep this thread alive with my results.
Sheddy's Avatar
Default 12-28-2017, 11:17 AM
Hey Terry,
I installed the BMS stage 1 and did a couple of data logging runs at +4, +5 and +6. Which one of these seem to be the best setting?
Default 12-28-2017, 11:39 AM
The stage1 logging is limited but overall +5psi looks best to me there.
Sheddy's Avatar
Default 12-28-2017, 05:54 PM
Great! I’ll leave it at that. Hopefully soon I’ll take it to the dyno to get some figures.
Sheddy's Avatar
Default 01-06-2018, 07:33 PM
Here are my dyno results. Holy torque!
Default 01-06-2018, 09:05 PM
Not bad at all! Power under the curve is what you can really feel behind the wheel.
Sheddy's Avatar
Default 01-15-2018, 05:22 PM
Oh definitely! I think I will look into fuel mixes next or even a custom re flash tune that incorporates the BMS to get maximum output.
Sheddy's Avatar
Default 02-20-2018, 08:09 AM
Just wanted to share some feedback from other users.
rlora rlora is offline
Car: Q50
Send a message via Skype™ to rlora
Default 04-03-2018, 03:25 PM
On the Lexus NX 300; where are the TMAP & MAP Sensors?
Default 04-03-2018, 05:17 PM
Both on passenger side.
http://www.burgertuning.com/instruct...xus_Stage1.pdf
Sheddy's Avatar
Default 04-04-2018, 07:48 AM
Attachment 72795
For the NX the 2 boost sensors are located near the firewall (back of the engine) they will be labeled with a blue sticker.
Car: Q50
Default 04-04-2018, 09:01 AM
