ashrafb58 ashrafb58 is offline
Car: 340i
Default pure turbos stg2 oil vaporizing - 08-22-2019, 07:05 PM
i have issue with pure stg2 when i rais the boost to 21-24 i get i high oil vaporization i can lose half a liter of the oil inadter 6-8 runs even after i installed OCC if any body had a common issue can help ?
Jay1312 Jay1312 is offline
Jay1312
Car: BMW 320i and M5
Default 08-23-2019, 04:50 AM
Have you raised this with pure?
Car: 340i
Default 08-23-2019, 05:04 AM
yes same happened with another two cars of friends of mine
Jay1312
Default 08-23-2019, 06:26 AM
What was pure response? I think top up check if oil consumption reduces if you run lesser boost? Not many run at 24 psi daily unless you have full custom turbo.
Car: 340i
Default 08-23-2019, 06:59 AM
no i donít run daily 24 psi it happen in same time of the run
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 08-23-2019, 09:15 PM
Does your car smoke out the tail-pipe after boost? Have your friends had the turbos replaced and was it fixed?
Car: 340i
Default 08-24-2019, 04:29 AM
no the smoke appeares after i start the car again not after the rum immediately
dRDiesel's Avatar
Car: BMW
Default 08-24-2019, 08:19 PM
Have you or your friends spoken to Pure turbos? Any news from their end?
Car: 340i
Default 08-27-2019, 02:38 AM
they didnít respond with an effective answer
dRDiesel's Avatar
Car: BMW
Default 08-28-2019, 03:53 PM
Does your oil catch can fill up with oil?
Car: 340i
Default 08-28-2019, 03:56 PM
no the oil skips the catchcan
dRDiesel's Avatar
Car: BMW
Default 08-28-2019, 04:53 PM
Does the car smoke on a cold start when it sits overnight? Also if the car is warm and you hold the RPM say around 4000 rpm for like 20 seconds do you notice smoke coming out the tail-pipe?
Car: 340i
Default 08-28-2019, 04:55 PM
yes
dRDiesel's Avatar
Car: BMW
Default 08-28-2019, 04:57 PM
yes
On the stock turbo it never smoked or ate oil?
Car: 340i
Default 08-28-2019, 04:59 PM
no it happens after i reach 23-24 psi
dRDiesel's Avatar
Car: BMW
Default 08-28-2019, 05:05 PM
So if you're boosting 18-21 psi it does not eat oil or smoke out the tail pipe? This is very interesting. Reason why i ask is because i have a Pure Stage 1 turbo myself.
Car: 340i
Default 08-29-2019, 02:54 PM
at 20-21 pai the catchcan can handle it
