Dagumpf's Avatar
Dagumpf Dagumpf is offline
FS
Car: BMW E93 N54 2009
Default MSD81 Low Pressure Fuel Sensor voltage problems - 08-25-2019, 04:43 AM
After much diagnosis, I have figured out there is something wrong with the voltage signal from the DME to the low pressure fuel sensor.
On the X60005 connector at the DME, pin 7 is Ground Low Pressure sensor, pin 8 is Supply Low Pressure Sensor and pin 34 is Signal Low Pressure Sensor.
I disconnected just the three sensor wires at the DME, and then measured the voltages coming from the DME.
Measuring pin 8 (Supply) to chassis give a perfect 5.00V. Measuring ground to chassis jumps around, normally between 1.2 and 3V. So this looks like a DME fault.
Can this be repaired? If so, how?
Further background: After driving through a large puddle (accidentally), I caused some other electrical damage, including blowing the radiator fan. After repairing that, I also discovered a silent 29FE fault, referring to a faulty low pressure sensor. This fault doesn't affect the operation of the car, as it just runs the Low Pressure Fuel Pump flat out. I replaced the sensor, and he fault did not go away. Hence I began an electrical diagnosis, leading to the above.
References:
Low pressure fuel system
BMW E93 335is Convertible
