notabenex notabenex is offline
Car: MB W205 C250
Default Help with my C63 JB4 - solved only with removing jb4 - 05-27-2019, 11:21 AM
Going to install this finally on my 2017 C63 W205 sedan EU.
After install use only map 1+2 ? Send logs to Terry or who? After reviewing the logs he can make some setting? I have been using Ecutek before.. i have 98octane fuel and possibly E85 also.
I would like to make some video comparation before/after and I am also going to dyno same day.
Car: MB W205 C250
Default 06-02-2019, 07:17 AM
Hi I have just finished install of jb4 for my c63 sedan. everything went well. Will post some pics soon. here are the logs
Car: MB W205 C250
Default 06-02-2019, 10:04 AM
here is longer log. There is more power, but sometimes i feel like rpms dont go smoothly with full throttle
Car: MB W205 C250
Default 06-02-2019, 10:10 AM
with map 2
Default 06-02-2019, 10:47 AM
Log looks clean to me on map1. No obvious sign of issues with boost, timing, or fueling.
with map 2
I see some wheel spin or DSC kicking in here on map2, to be expected.
Car: MB W205 C250
Default 06-02-2019, 11:44 AM
Thanks for very fast reply. I am really enjoying extra power. should I set something in app? or keep it and use map1/2
Car: MB W205 C250
Default 06-02-2019, 11:18 PM
If you have traction issues can lower boost in 1st or 2nd gear.. But otherwise enjoy!
Thanks Terry. Lowering boost in those gears means using map6 with individual settings? Or where can I set this in Android App?
Car: MB W205 C250
Default 06-03-2019, 11:31 AM
So after few hundreds kilometres with JB4 I have to say that the increase of power in my C63 is very addictive. I am glad that I went this way.
With map1 or mostly map2, (I have new P4S 275 in the rear), there is still something weird even with higher gear, like 4 if I do full throttle there is some slowering of rpm, its like when you have too much boost and clutch cant take it (had this with previous car). Is it really some DSC thing (no TC light) or ?
Car: MB W205 C250
Default 06-03-2019, 01:29 PM
Friend of mine who was doing the install with me, thinks that he can see it here, but it sometimes happens in lower rpms, around 4krpm. Will try tomorrow to reproduce it and send the log
Car: MB W205 C250
Default 06-03-2019, 08:57 PM
I'd need CSV file to open in the JB4 interface.
Its the file I've posted earlier.
Car: MB W205 C250
Default 06-04-2019, 10:38 AM
Here are two more logs. map2
check timestamp 458,5 and 316
Car: MB W205 C250
Default 06-04-2019, 10:19 PM
one more log.
5th gear and hesistation with rpms
Default 06-05-2019, 08:25 AM
View logs in the JB4 windows interface.
I don't see any issue in these, at what time stamp do you think there is an issue so I can zoom in?
Default 06-05-2019, 08:27 AM
Do you mean like at 475?
Car: MB W205 C250
Default 06-05-2019, 08:36 AM
I tried to make a video with map2 and jb4 C63 jb4 on Vimeo and if you compare this video with this one with map 0 you can clearly see rpm problem c63 jb4 map0 on Vimeo
so what do you suggest Terry?
Default 06-05-2019, 02:33 PM
That just looks like some sort of slippage and catching again, of tires or trans, rather than a tuning issue.
If map1 has the issue then use map6 to lower boost further as needed in that area.
Car: MB W205 C250
Default 06-05-2019, 09:00 PM
I dont think that its slippage of tires, thats why I did the video on dry Road with heated P4S, on 5th gear in 80mph (130kmh) with ESP in sport mode..
Car is 2017 model, with 30k miles so transmission should be ok
What settings do you recommend for map 6?
update : with map 6 seems like no issue. Will play with it. where to add more boost?
Car: MB W205 C250
Default 06-10-2019, 11:12 AM
The values represent the base boost profile over stock for map6.. The 3psi peak there is a good starting point. Maybe add 0.5psi in areas to evaluate?
Well I tried several settings for map6, car is behaving OK. Could you tell me which PSI uses map1 compared to map6 ? There is less taper in higher rpms?
Here are some logs with this settings. Could you please check them?
Here is screenshot with my settings od map6 and also screenshot of max 23.1PSI which scared me .
Car: MB W205 C250
Default 06-10-2019, 11:57 AM
Logs look normal. You're looking at boost spikes as throttle closes since boost is sampled in front of the throttle body.
Under normal conditions you're hitting around 16psi peak in the logs.
Thanks Terry. I have to say that its too much fun with map 2, but the ''slipping issue'' is worrying me.. I was thinking if it could be some transmission torque limit which cuts fuel or releases friction in transmission, because in is not happening on 2,3rd gear only 4+5..
What do you think?
Default 06-10-2019, 04:09 PM
What do you think?
It's difficult to tell, we haven't observed anything like that in in our development car nor had anything else reported. I'd just stay conservative on boost for now and we'll see if we can triangulate in to your issue in the future.
Car: MB W205 C250
Default 06-17-2019, 10:26 AM
so today when going to work I got CEL blinking for a while, I was on map 6. Car was getting rough idle. I connected OBD reader and got codes from screenshot....
Default 06-17-2019, 10:37 AM
Sounds like a misfire code, from plug gap being too wide for the boost level. But none of those seem to be ECU codes. Maybe delete all codes so when it comes back we have a clean slate to look at.
Car: MB W205 C250
Default 06-17-2019, 11:00 AM
I am planning to change plugs. what do you recommend? thank
I checked codes before jb4 install and there were none
Default 06-17-2019, 08:16 PM
On plugs we've only used OEM so far, but I'd close the gap down to 0.022".
