Shanrock316 Shanrock316 is offline
Car: 2009 335i 6m coupe
Default The more I read the more confused I get - 04-29-2019, 10:05 AM
So Iím new to turbo cars but am solid with a timing light and a holly double pumper. Please forgive the lack of current tech speak.
I got problems(donít we all)
Looks like run I logged in map 4 is labeled map 1 and run starts at marker 550 on graph and runs to 710.
1) Added JB4, got the misfires and replaced plugs. No more misfires! Whoo Hoo!
2) Now Iím getting overboost code when in tune 1 and 5. Only tried 2 once with same result.
3) Went to drag race yesterday and logged some stuff but the data doesnít seem to line up with the graph. Best pass 13.91@ 101.74. Not proud of it.
4) Best I can tell when in map 1 or 5 the throttle drops in and out with pedal at WOT when JB4 is on and past approx 2/3 pedal position. Logs a code just a second or 2 into WOT and feels like boost is on/off/on/off instead of clean pull.
5) Car seems to run well and not log any codes with tuner off.
6) The attached files seem backwards from the map I was on. I was not able to run a pass w tuner on but did get a pass w map 4. I think itís lables as 1 if I see the data correctly.
7) The whole update software and do back end flash has left me very confused. Is there an update and back end flash set of instructions for dummies? G5 cutting diodes, which one to load and can I do back end flash through my mobile app or do I need the cable.
8) Itís the wifeís daily driver and she I asking me to pull the plug on all of this. I just wanna go fast. Please advise.
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-01-2019, 05:55 AM
Need to move or Repost this post to the Support Thread
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
nefariousminion nefariousminion is offline
Car: 08 535i
Default 05-01-2019, 06:37 AM
+1 log reviews go in Support Thread. Also list your mods.
535i E60 6MT: VTT Wastegate Fix / BMS DCI / No name Dpipes & CP / ARM 7" FMIC & Hose Upgrade / VRSF Inlets
C5 A6 2.7T 6MT
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 05-01-2019, 09:27 AM
Menu 4, is it in position 2 or 3?
09 335 - 6266
07 335i - 6870, E85 - SOLD
