cesarortiz23's Avatar
cesarortiz23 cesarortiz23 is offline
Car: e90 335i sedan
Exclamation bootmod3 backfires/sputtering - 04-19-2019, 04:21 PM
hey guys so i just installed bootmod3 today in the morning i am running stage 1 witch does not require mods
only thing i am running is intake and muffler delete if that even makes a difference
but in the morning it was running fine and the more i drive the car the more sputters and backfires i get
on low rpms like to the point i can hear the engine sputtering and throwing black smoke.
some pulls it pulls great very strong power but then some pulls i get very badd backfires/ sputters and black smoke from the exhuast
do you guys think i just need better spark plugs or you guys think is something worse
any ways i got ngk spark plugs (97506)
do you guys think i should gap them
another i thing i noticed was today in the morning the car was running great but it was like 68 degrees at max and right now it got up to like 87 degrees and the car started to act up ...
any suggestions or opinions.
i would apreciate the help
f30 335i pwg
Car: e90 335i sedan
Default 04-19-2019, 05:42 PM
bootmod3 - 5cba65edae729b44f42741c9 datalog chart
bootmod3 - 5cba6475c090c642baed0b31 datalog chart
wcoleman320 wcoleman320 is offline
Car: 2009 BMW 335i Xdrive manual sedan
Default 04-23-2019, 09:42 AM
I would start with installing new spark plugs. Gap them at .22 using any standard gapping tool. BMS sparkplug tool is a must, i recommend that you get one, as i went to 4 different autopart stores trying to find a thin walled spark plug socket and it cost about the same as BMS's tool. After that i would make sure that your are putting good gas in it. If that doesnt work, come back here to the forum as it could be injectors, coils, carbon buildup or a whole number or other things. Good luck man!
Wyatt J. Coleman
Default 04-23-2019, 09:45 AM
Also the link provided will not download the datalogs. Please either upload the CSV file, or use something like datazap . me
Wyatt J. Coleman
