Default 340 B58 PURE STAGE 1 Testing - 10-21-2016, 03:11 PM
Just got our 2016 340i B58 back from PURE with the Stage1 turbo for a little fun. JB4 tuning for it is still a work in progress but turbo response is almost as good as stock and so far no problems making around 30whp more than the stock turbo up top. I've got some work to do on the tuning still but I'm pretty encouraged by the early testing.
The test vehicle is running the JB4, BMS B58 intake, BMS WMI, and PURE S1 turbo. Exhaust and emissions equipment all 100% unmodified. Boost juice and ~95 octane.
Attached is a dyno/log of of what we've worked up so far (@ 23psi) and also a log with the JB4 on map4 (stock tuning) for comparison. The stock tuning seems to run the turbo just fine at stock like boost levels which makes our life easier. I did a few runs up to 25psi (the current boost cap setting in the B58 JB4) and while it wanted to make more power there are a few tuning glitches I'll have to tweak first. Hope to see 500whp with this thing shortly. Then it's open season on lightly modified M3s....
We'll be testing this car as part of our development fleet at Shift Sector 1/2 mile tomorrow.
Pure Turbos's Avatar
Pure Turbos Pure Turbos is offline
Default 10-21-2016, 03:15 PM
Awesome!!!
135idct 135idct is offline
Default 10-21-2016, 05:46 PM
Originally Posted by Pure Turbos
Awesome!!!
What about the price?
katsooba's Avatar
katsooba katsooba is offline
Car: 135i N55 DCT
Default 10-21-2016, 09:38 PM
this motor seems promising!
respect to Burger and Pure for making this happen!
135i N55 / KW V3 / CP-E charge pipe / CP-E 5" ** / CP-E 7" FMIC / JB4 S2 / MHD / K&N inbox / Custom made 3.25" catback / Tons of other mods
Peter @ Pure's Avatar
Car: F20 M135i
Default 10-22-2016, 12:19 AM
Looks very good! B58 sure has potential!
F21 M140i - 100-200: 6.95
Audi TTRS - 100-200: 4.47 60-130: 5.16
F80 M3 - 100-200: 4.45, 60-130: 5.1
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 10-22-2016, 09:04 AM
Making M240 even more tempting for me now.
Is meth required for BT at this point due to the fueling restrictions?
Also, is it normal for timing to zero in the low range like that? Saw that in logs of stock turbo B58 as well.
m123 m123 is offline
Car: 440i F32
Default 10-22-2016, 11:55 AM
This is awsome!!!!!!
F32 440i JB4
F11 550i N63tu JB4
JP.BSB JP.BSB is offline
Car: BMW 320i Sport 15/15
Default 10-23-2016, 02:26 AM
This is TERRYfic :-)
Sanesh21's Avatar
Sanesh21 Sanesh21 is offline
Car: 2013 F21 M135i MT
Default 10-23-2016, 11:29 PM
Great work Terry!
2013 F21 M135i 6MT
JB4 / PWG / BMS intake / BMS meth kit / FSB / ER CP / Down Pipe / VTT stg1 / Pure inlet / GFB DV+ / AFE air scoop / N20 Tmap / Rev3 Connect / M performance exhaust / ACS springs / H&R Trak spacers / M Performance V2 steering
Iflickr.als Iflickr.als is offline
Car: Bmw
Default 10-24-2016, 12:00 AM
Is it possible that the E series can make the same numbers on stage 1 pure ?
BMW 135i 2011 N55 Pure Stage 1 ETS Fmic , BMS Downp1p3 , BMS Intake , BMS OCC , BMS meth kit cm7 , jb4 ISO + MHD .
Default 10-24-2016, 09:33 AM
The car ran great at shift sector. Almost took out our 2016 Z06 Corvette...
Collected some good data and working on mapping improvements as I type this.
JETmn JETmn is offline
Car: 2011 335xi
Default 10-24-2016, 11:08 AM
Nope, E series has the smaller exhaust side. 426whp is the most I have seen, IIRC.
drumma022 drumma022 is offline
Car: 2016 340i
Default 11-07-2016, 06:56 AM
I can't wait!!
Bours Bours is offline
Car: 335i x-drive n55 2011
Default 11-07-2016, 09:53 AM
with what setup ? i mean what octane aside from FBO and pure stage 1 ?
Car: 2011 335xi
Default 11-07-2016, 02:04 PM
That was at least E30, I know the turbo was maxed and dyno may have read a tad high. I have seen several others in the 400's though. Anyway, not to get this thread off track.
zinner zinner is offline
Car: 2015 F30 N55 M6
Default 11-07-2016, 07:10 PM
quite impressive results.
Default 11-07-2016, 07:41 PM
Still poking along on the tuning on this. If I can work out a couple little things I think we'll see 500whp.
Car: 335i, 2009
Default 11-09-2016, 11:06 AM
Incredible results. Looking forward to more. I am sure all of the tuning and lessons from other platforms has helped get this platform up to speed. If the bottom end can handle it, you should be able to do 600 WHP with minimal supporting mods. Just unbelievable!
M3 F80 2017 Competition & Carbon Brakes
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
klipseracer klipseracer is offline
Default 11-09-2016, 04:14 PM
Nice Terry! That Z06 sure does move out
JB4OFF JB4OFF is offline
Car: 340i
Default 12-02-2016, 12:44 PM
Timing looks pretty low on those logs... how's the tuning going for this?
Default 12-02-2016, 12:48 PM
Been working on things in the background and I think 500whp is within grasp. But still some software work to do.
Default 12-02-2016, 01:56 PM
So the b58 is making pure stage 2 numbers on the n55 with meth !? And no down pipe ? Thats amazing right ?
Default 12-02-2016, 03:25 PM
The B58 engine is way better than the N55. Almost as good as the N54.
Default 12-02-2016, 03:33 PM
365 whp to 481 whp by just adding meth ??? Stock boost for b58 is ? And 23 psi will wear out that stock snail really fast right ? And running this much with no ***** ** damn
Sean_g Sean_g is offline
Car: 340xi 6 speed
Default 12-02-2016, 11:34 PM
I know that this turbo is only a month into R&D but any word on when this will be available and what the price of the turbo will be.
