petrov7875@gmail.com petrov7875@gmail.com is offline
Car: e60 535xi
Default Making a daily beast N54 - 10-11-2017, 12:26 AM
Hi guys , i'm making a daily car and i want 500-550whp .. Car is 535xi , but i will make it RWD .. For now i have jb4 G5 iso and bms dci ,RB PCV VALVE,BMS oil termostat , removed all catalytic converters . The motor star to burn oil and i open it . Now i'm changing everything that can be changed in motor , i want to make it new. I give the turbos to make it hybrid and now they have 5mm bigger billet wheels. I will get the new map 3.5bar and custom fmic , straight pipe. I want someone to make custom tune , but i dont know who can do it best .
And some photos of project ...
Only with the JB4 and DCI and removed catalytic converters car make this times
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 10-11-2017, 10:37 AM
GLWB.
So ... converting your XI to RWD? Might PM USCBWSR on here, and ask him how that went for him.
2017 AMG C63 -JB4
2009 535i - 548whp - sold
Car: 2008 E93
Default 10-11-2017, 11:05 AM
David....aka trebila
Car: e60 535xi
Default 10-11-2017, 11:15 AM
Originally Posted by LessIsMore
GLWB.
I cant understand u sry
Car: e60 535xi
When i`m ready i will contact with him to make custom tune ! Thank you .
Car: 2008 E93
Default 10-11-2017, 04:28 PM
You will be happy, im sure.
Default 10-11-2017, 06:32 PM
I can't see the photos, but sounds like a fun project! When you get it together post up some logs and we'll help you dial it in. E85 I hope?
Maniac0908 Maniac0908 is offline
Car: 07 BMW 335xi JB4 G5 DP DCI BOV
Default 10-11-2017, 07:26 PM
How do you plan on doing the conversion? Just pulling the shaft? Or doing everything?
2007 335XI SEDAN // ACF/VM 6266 SINGLE TURBO// MMP PORT INJECTION // VRSF CP W/ TIAL BOV // XHP 6AT FLASH // MOTIV TUNED // BMS OCC // VRSF EXHAUST // DIY STAGE 3 LPFP// VRSF FMIC //
Car: e60 535xi
Default 10-11-2017, 10:48 PM
Hello Terry : ) , i fix photos and they can see now , i will not sure i will drive on e85 ... in my country Bulgaria we don`t have E85 (( , but i will try to find. I drive car only on 100oct from Shell. I will add meth later. . Yes it`s fun project :D i really want to make 11.xx on 402m. I think to get Hoosier tyres for thah :D it`s crazy i know ... hahh
I will post everything for the project .
p.s. this is my other daily (economic) car
Car: e60 535xi
Default 11-28-2017, 11:14 AM
Here are some fresh photos of the project : ))) I change everything with OEM parts from BMW
rkreimer10 rkreimer10 is online now
Car: 08 535i
Default 11-28-2017, 11:35 AM
GLWB.
@LessIsMore is saying study this.......
http://www.n54tech.com/forums/showthread.php?t=36899
ms335i ms335i is offline
Car: 2007 BMW 335i
Default 12-01-2017, 07:20 AM
Koi gi pravi tez turbota v bg?
Car: 08 535i
Default 12-01-2017, 11:15 AM
I don't think many people speak Bulgarian on this forum but I could be wrong.
The question is how to get these turbos in Bulgaria?
Car: e60 535xi
Default 01-02-2018, 01:04 PM
Hello guys and Happy New Year , i wish to all of you to make everything that you want to cars , and make it faster !! : )))
I have a little question for my car , the car is ready and working good. Can i flash now BMS BEF for pump for my hybrid turbos , and is it necessary to change MAP sensor ? For that moment i get off the JB4 from the car and now is with stock ECU MAP . What to do from now ? : ) Thank you .
LessIsMore's Avatar
Inner Circle Member
Default 01-03-2018, 12:35 PM
Yes, you will want a 3.5 bar TMAP sensor, so you can reliably target 20+ psi.
When you flash a backend flash for hybrids and the fuel you use:
Download MHD.
Connect the K+D cable to the OBDII, turn ignition on.
JB4 will automatically switch to map 0 for DME flashing (you don't need to physically uninstall the JB4).
Flash the DME with MHD BEF.
Once it's done, turn off ignition, then start the engine.
Clear any codes.
Reset adaptations.
Then go drive and take some logs.
2017 AMG C63 -JB4
Car: e60 535xi
Default 01-06-2018, 12:53 PM
Download MHD.
Clear any codes.
Reset adaptations.
Thank you !!! I will get 3.5 bar TMAP soon , can i flash BMS BEF for hybrids ( no e85) just PUMP BEF. After flashing BEF what to do with JB4 which map i will use?
Car: e60 535xi
Default 01-25-2018, 11:19 AM
Hello : )) I run the car 300 miles , and something happened .. the car start to burn oil, smokes when i release the gas pedal. We remove the cylinder head cover , and we saw a lot of oil on 5 cilynder. I think its the head cover problem.The car is back to the service and know i`m thinking what to do with the PCV. Is the best way to take pcv to exhaust with OCC or something else. I think to plug the head ports , and make RB PCV external kit or can anyone can tell me the diagram and how i can make the pcv vent to exhaust? Thank you.
LessIsMore's Avatar
Inner Circle Member
Default 01-25-2018, 12:11 PM
did you turn on the exhaust burble with MHD? Many people have complained of burning oil/smoke/oil comsumption with burble on.
Get a RB PCV from BMS if you haven't already (silver/black). Oil Catch Can is a good idea too, but probably isn't going to fix your smoking.
if you go RB External PCV, email Rob, he's very knowledge about the PCV systems.
2017 AMG C63 -JB4
Car: e60 535xi
Default 02-05-2018, 11:37 AM
The car is with stock maps , no JB4 , no BEF.
I have RB PCV VAVLE , now i bought a valve cover , i dont know this will help me.
Car: e60 535xi
Default 03-30-2018, 10:24 AM
Hello again : ) The car stop to burinng oil , and for now its good . I made JB4 BEF Pump , and bosch 4bar TMAP.Now i drive the car on map 2.Any suggestions for custom map 6 ? : )
