AZN54 AZN54 is offline
Car: N54 135i
Default Advance Auto Injectors - Seals? - 09-08-2016, 10:28 AM
Can anyone who ordered these injectors from Advance Auto confirm if they come with seals on them? I understand injectors don't normally come with decouplers and will pick some up from the dealership, just wondering if I will need to source the tool for putting on seals. Also, can you confirm index, please?
http://shop.advanceautoparts.com/p/g...es+&showTitle=
2009 135i
DOC Race 6266 Single, VS DW400 LPFP, VRSF Race FMIC, Motiv BoostBox, Tuned by Wedge
Offering Arizona Walnut Blasting Service:
http://www.n54tech.com/forums/showthread.php?t=36741
Car: 2010 135i
Default 09-08-2016, 11:22 AM
Right in the info on the page:
When replacing injector, requires (1) 13 53 7 564 751 decoupling element and (1) 13 53 7 584 315 injector seal.
2010 135i auto, MHD E40 tune, Fuel-It stg 2 pump, best 1/4 mile 11.863 @ 119.17 mph
new mods this year, VRSF 5" stepped IC, RB EVO inlets, CP-e/Tial CP, 1320 **'s, xhp stg 3 trans tune, E-85 tune
Best 1/8 mile: 7.469 @ 98.56, 1.769 60'
Best 1/4 mile: 11.480 @ 121.79 1.802 60'
Car: N54 135i
Default 09-08-2016, 11:38 AM
Yup, but doesn’t state if they are sold separately. If new, they typically come with seals.
2009 135i
Jsr1256 Jsr1256 is offline
Car: 08 335i Sport Package
Default 09-08-2016, 12:11 PM
The word require probably means they don't. I'm 99% sure
08 E92 335i AT 20k Miles | Wedge E60 Flash| E85 | VRSF FMIC | VRSF Lower Charge Pipe | ER Charge Pipe|Tial Bov| Vrsf *** | DCI | IC Sprayer | Scoops | NGK 1 Range Colder Plugs | Fuel It LPFP | E60 | [12.2 @ 118with e85 flash] [ My E60 flash 1/4 = 11.8 @ 120
I6+TT=FTW's Avatar
I6+TT=FTW I6+TT=FTW is offline
Car: 2007 E90 335xi
Default 09-08-2016, 01:17 PM
Your local dealer should have the decouplers in stock, for like $8 each.
2007 Jet Black E90 335xi /PTF-Cobb/E50/FuelitS2/5" Stepped FMIC/Synapse BOV and Charge Pipe/Black 19x8.5/245s all around/and more
Car: vw passat
Default 09-08-2016, 01:40 PM
mine from autozone and rock auto came with seals
Car: 2007 BMW E90 335i
Default 09-08-2016, 01:45 PM
There's a guy on E90post that said his did not come with seals.
2013 135is DCT Carbon Black
Car: N54 135i
Default 09-08-2016, 01:50 PM
Thank you for the info, appreciate it
2009 135i
Default 09-08-2016, 01:53 PM
Let us know though. I'm interested in buying sooner or later
Car: N54 135i
Default 09-09-2016, 10:28 AM
FYI, a member on another forum order these exact injectors from Advance Auto; received them last night and confirmed index 12 and they come with seals on them. I ordered a set and will reconfirm once received, but it's safe to say they come ready for install (other than decouplers).
2009 135i
RCB RCB is offline
Car: E61 535XIt
Default 09-09-2016, 11:34 AM
That is good news, it still leaves hope that they are new and not refurbished.
2008 E61 535xit MHD, VRSF CP, Tial BOV, DCI, RB Inlets and Outlets, VRSF 7"FMIC, Custom ***, BMS OCC, RB External PCV, M5 seats, LED interior/DRL, 20" Style 128 wheels, KWv3, M5 steering wheel, M-Sport conversion, Bimmer-Tech HD/Apple TV, RB Twos
2008 Lexus ISF I/H/E, Figs suspension arms, BC/swift, BC wheels, PSS (305 rear)....
1993.5 Supra 857 WHP, GT42R, CCW/R888 (305 rear)...
1968 Plymouth GTX 440 (For Sale)
2017 Chevy 2500HD Z71 LTZ
IG: CBBOOST
Car: N54 135i
Default 09-09-2016, 11:41 AM
Right. I'll post pics here once a receive them.
2009 135i
Car: N54 135i
Default 09-12-2016, 09:44 AM
Another member on other forum confirmed seals are installed on the AA injectors. Again, mine will be delivered today; post pictures tonight or tomorrow.
2009 135i
sshec152's Avatar
sshec152 sshec152 is offline
Car: 07 335i mt
Default 09-12-2016, 10:37 AM
Ive ordered 8 different airtex injectors from rockauto on different occasions, all index 12 with seals but not decoupling elements. All had bmw stamping on them. bmw stamping
Car: N54 135i
Default 09-13-2016, 08:00 AM
Received AA injectors last night; all look brand new in sealed boxes. No indication of being remanufactured that I can see. Did not pull caps off to check for seals, but I am installing tonight and will update thread.
2009 135i
chadillac2000's Avatar
Car: 2008 535i
Default 09-13-2016, 08:05 AM
Great to see another vendor offering these in brand new condition. These were getting hard to get for a bit there it seemed.
Car: N54 135i
Default 09-13-2016, 08:10 AM
Agreed. I've been searching for a little while now. O’Reilly’s and Autozone couldn’t get them as of a last week. Doesn’t seem like Rock Auto have had them for a while and other sites are ~$100 more per injector.
2009 135i
Default 09-13-2016, 10:17 AM
If you cannot easily remove the caps, that means the seals are installed. The cap prevents the seal from expanding until it's inserted into the cylinder head. Do not remove the cap until you are ready to insert the injector into the engine!
The caps need to be removed with pliers. I had to crush the very end of the cap with the pliers in order to get a good enough grip to pull it off. If you grip the very end of the cap you shouldn't have to worry about damaging the intjector tip. But compare lengths with one of the injectors you remove to make absolutely sure.
FWIW, those look exactly like the Standard Motor Products units I got from Rock Auto back when they were $110 each. I've probably put 6000 miles on them so far and they have been flawless.
Don't forget to code them with INPA!
Car: N54 135i
Default 09-13-2016, 10:25 AM
Appreciate the tips. I didn't remove the cap for that exact reason; waiting to install. INPA is setup and ready for coding.
2009 135i
FCobra94 FCobra94 is offline
Car: '07 E90 335i
Default 09-14-2016, 07:04 AM
A better option is to cut a short length of proper diameter PVC pipe. Slide the pipe onto the injector until it rests where the decoupling element would normally sit; take an open end wrench and use the pipe as a fulcrum and slowly ease the protector off the injector with the open end of of the wrench.
Works like a charm and no chance of causing damage to the injector
Default 09-14-2016, 08:43 AM
Took me a sec to imagine this, but yes that would work better.
pez pez is offline
Car: 08 E61 535xi 6MT
Default 09-29-2016, 12:21 PM
Anyone with index 13's from Advance Auto yet? need to order a set of 6 to replace failing index 7's and 8's, hoping they'll have the new index part soon....
RCB RCB is offline
Car: E61 535XIt
Default 09-29-2016, 12:38 PM
We are up to idex 13 now? I just installed a set of index 12s in my own car. I seriously hope these injectors don't have issues down the road. How many tries does it take to get these things right?
IG: CBBOOST
pez pez is offline
Default 10-05-2016, 03:14 PM
Hmm, maybe not - my only knowledge of that was from this thread: http://www.n54tech.com/forums/showthread.php?t=39006
One of the posts mentions hearing of an index 13 injector, but never having seen one.
I'd been holding off on a purchase as I wanted the latest index, and figured the index 13s were coming.
CeeWhizzle CeeWhizzle is offline
Car: 09 E92 335i
Default 10-05-2016, 03:22 PM
There are Index 13's out now. I'm jealous that you guys can get Injects from Advance Auto for such an insane price.. I'm in Canada, so they won't ship . May ship by the border.. Considering the cheapest I can get a full set of 6 in Canada is $2,050 CAD..
