Rolltide67's Avatar
Rolltide67 Rolltide67 is offline
Car: 2008 335i E92 coupe
Default Consistently misfiring on cylinder 6 under wot - 09-14-2015, 04:13 PM
I am constantly misfiring on cylinder 6. I have replaced the coil pack, all injectors are new index 12. Replaced by the dealer less than 10k miles ago. It does not misfire on any other cylinder nor does it do it under any other throttle percent. It does it if I run pump flash with 93 octane, race flash, or even e85 flash ...it does it with all e85 mixes....it does it with methanol spraying....I have tried map 1,2,3,5,6,&7 on jb4. I have NGK plugs gapped to .22. I am FBO, 455 lpfp, BMS meth kit. 2008 n54 with 55k miles. I have logs and I'm trying to figure out how to attach them. It does look like that bank is running richer by the AFR numbers. Maybe a leaky injector? Could it be a jb4 setting? Thank you for any help!
Car: 2007 BMW E90 335i
Default 09-14-2015, 04:19 PM
How many miles on the plugs and coils?
Last walnut blast?
Does the misfire result in a code?
If there is a code, try moving the coil to another cylinder and the plug to another cylinder (different than where you move the coil to) and see if the code follows.
Use *********** to upload logs.
2013 135is DCT Carbon Black
Rolltide67's Avatar
Default 09-14-2015, 04:36 PM
Less than 1k miles on plugs and coils. I have replaced the coil twice...( I have new spare coils) walnut blast was 10k ago According to BMW records, no code other than misfire on cylinder 6 and that cylinder cuts off. I clear the code and make sure I don't hit wot. I have inlets coming in within the next couple weeks and want to Dyno the car. I will need wot...lol
TX_Noah's Avatar
TX_Noah TX_Noah is offline
Car: e90 335i w/ JB4 G5 ISO
Default 09-14-2015, 04:53 PM
I could potentially be having a similar issue. tuning in.
golden_boy // NARA Speed // https://www.youtube.com/channel/UCiv...7nXb9Dg_llnDKw
jb4, e85, eating mustang girlfriends for breakfast.
prelude2perfect's Avatar
Car: '07 335i
Default 09-14-2015, 05:02 PM
you need to post in the support section, you'll get more help in there anyway. Post logs with it. Also need to know if you manual or auto and if the rpm it's happening at is consistent.
Best 1/4 ET: 11.4
Best 1.4 Trap: 127.7
nyt nyt is offline
Car: 335ix
Default 09-14-2015, 05:33 PM
logs? manual? auto? what rpm do you see the misfires at? Have you tried swapping injectors and recoding to see if it follows?
2010 335ix - pure 600 turbos @ 30psi, dps, cp, 7.5in hd ic, inlets, outlets, jb4, pi, fuel-it stg3, at cooler
Default 09-14-2015, 05:43 PM
It could also be a boost leak.
Post the CSV files here and we'll look at the logs.
Rolltide67's Avatar
Default 09-14-2015, 06:39 PM
Auto, I have not swapped the injectors yet.it does this at multiple rpm ranges. I guess that will be the next item.
Rolltide67's Avatar
Default 09-14-2015, 06:43 PM
Here are a few logs, they are short due to the misfires. E85 backend flash from BMS....e40 fuel
Rolltide67's Avatar
Default 09-15-2015, 06:44 AM
I did a few more pulls this morning and it's now misfiring on 5&6. No other codes
j1gilles's Avatar
j1gilles j1gilles is offline
The Fonz
Car: 2009 BMW 335xi
Default 09-15-2015, 07:35 AM
I would check the install of those injectors...
ASE master tech (previous career)/G5 iso/Backend Flash/Trunk mount 100% alcohol injection/DCI/Alpina Flash/Borla Mids/custom x-pipe/ER Charge Pipe/Custom dual "Ebay" BOV's
Default 09-15-2015, 04:27 PM
Have you selected 4/2 with your steering wheel controls?
Rolltide67's Avatar
Default 09-15-2015, 04:39 PM
Yes I have.
Rolltide67's Avatar
Default 09-15-2015, 04:48 PM
I pulled the plug today and it looked fine. I swapped the coils on 1 and 6 and the misfire still occurred on cylinder 6 under wot.
Rolltide67's Avatar
Default 09-15-2015, 05:01 PM
Latest 2 logs. It goes lean on AFR2 right before it throws the misfire code and turns off the cylinder.
Default 09-15-2015, 05:40 PM
Do logs in 3rd gear at WOT from 2.5K to redline.
Rolltide67's Avatar
Default 09-15-2015, 06:14 PM
The moment I hit WOT I get a misfire on cylinder 6... Any rpm. I can post a gradual increase in throttle or maybe 75%. Just can't put it to the floor.
Default 09-15-2015, 06:35 PM
Okay, your rail pressures are really unstable. Was thinking it may in part be due to the logs and needs to adapt but its really bad.
with the car on but not running, have you done a 1/7 with the steering wheel controls?
You're not getting any other codes?
Rolltide67's Avatar
Default 09-15-2015, 06:50 PM
The only codes I get are the misfires on 5 or 6. 90 percent of the time it's 6. Sometimes it says multiple misfires. I will try to rest the adaptions with 1/7. Any particular driving behavior you would suggest after I reset them? Thank you for your responses and help! Btw I have your stage 2 kit
Default 09-15-2015, 07:56 PM
No problem and thanks.
Just drive normal for a bit, you shouldn't really notice anything after the adaptions reset.
If you have an INPA cable you can reset your fuel control valve adaptions as well.
https://www.dropbox.com/s/fx6brmnn1y...tions.pdf?dl=0
Rolltide67's Avatar
Default 09-16-2015, 10:21 AM
I reset all adaptions this morning. I put about 75 miles on the car and decided to do a pull. It still gave me a misfire on #6. The log is attached.
Rolltide67's Avatar
Default 09-16-2015, 10:59 AM
Map 2 log as well, so you can see it still does it without meth. Still the only code is #6 misfire.
Default 09-16-2015, 12:44 PM
Which flash are you running?
The rail pressures are very erratic.
FCV, HPFP, injector....not totally sure. I'd verify the injectors were installed and coded correctly. From there I'd probably go to an HPFP since it's so erratic.
Rolltide67's Avatar
Default 09-16-2015, 01:23 PM
I am running the JB4 backend e85 flash from BMS. The injectors were installed by the dealer so there is no telling if they were done correctly. I will check the injector instalation and coding. From the records pulled at my local dealership the HPFP was replaced when the injectors were around 10k ago. I will admit if I just run 93 it misfires much less than when I run e85 mixes.
Rolltide67's Avatar
Default 09-16-2015, 01:26 PM
Oh and what is FCV? Sorry I'm still learning about this car. Thank you for all of your help.
