(#101)
Rob@RBTurbo's Avatar
Stalker
Car: 335I
Default 10-05-2015, 05:46 AM
Originally Posted by bmsportzn135i
I'll make payment first thing monday morning.
Shipment can be with my inlets.
Payment received thanks!
Originally Posted by iminhell1
So you want people to switch from a crimped factory hose with 2 potential leak points (per hose) to one with 4 potential leak points (per hose)?
What is the rubber hose you're using?
Why not add some actual fire sleeve and not some shabby dryer ducting?
I mean if you're going to create more potential leak points you should try your best to reduce the amount of things that are going to burn when the hose fails.
Or no?
We have had great luck with these materials. If you wish to order and would like to change them around to your liking, no big deal, its a short section of 5/8" ID hose do as you wish.
Thanks,
Rob
Stalker
Car: 335I
Default 10-05-2015, 08:31 AM
Just as an update, all oil drains have been shipped (that were not pre-designated to ship with other packages) and tracking info has been sent.
Thanks,
Rob
Socket's Avatar
Socket Socket is offline
Default 10-13-2015, 04:34 AM
would have been nice to receive an email about these
Nexic Nexic is offline
Car: '10 335i
Default 10-13-2015, 07:35 AM
Rob,
Just for future reference, when I received mine they were not wrapped separately. They were just in a plastic baggy with all the other metal parts. Due to this, they must have bumped around while shipping scratching some of the anodizing off of the drains. I am sure once they are on and I am not looking at them it will be fine but the packaging process could have been better.
Stalker
Car: 335I
Default 10-13-2015, 08:16 AM
Originally Posted by Nexic
Rob,
Thanks for the feedback. The primary problem was that one of the four adapters just didn't take well to the anodizing process (for whatever reason).
The anodized parts will also unfortunately scratch, but typically under harsher tampering. Fortunately these particular parts are never to be seen once installed, and that functionally it will not matter in the slightest.
Thanks,
Rob
lcvette's Avatar
lcvette lcvette is offline
Default 10-13-2015, 09:08 AM
Originally Posted by Rob@RBTurbo
-8AN recommended on ANY JB Turbo? You really surprise me… nah nah you don't.
Truth is -10AN is the normal lowest recommended drain for Journal Bearing, preferred generally -12AN.
The moral of the story there is nothing wrong EVER with a bigger/better drain, Period. But don't take my word for it… maybe take MHI's (see attached). Maybe take Garrets (follow link).
http://www.turbobygarrett.com/turbob...il_water_lines
Or take the cameraman drama barbie toni's. Setting stages all day everyday...
Tony,
Rob is supplying the correct information here for the return line sizing. -8AN is never recommended for a drain size for a journal bearing turbo, -10AN is the minimum recommended size. I would use no less than -10AN even on a BB cartridge turbo given designing a system from scratch.
Rob,
Nice job of coming up with a product to help alleviate potential problems. Looks like it will have some great benefit to solving any issues from drainback restrictions.
Chris
Tin Tin is offline
Default 10-25-2015, 03:20 PM
Are these still available? I'm down for inlets, could these be put in the same box if I paid?
Stalker
Car: 335I
Default 10-25-2015, 03:22 PM
Yes sir.
BeastMode335i's Avatar
BeastMode335i BeastMode335i is offline
Car: 08 E92 335i
Default 10-26-2015, 07:43 AM
Anybody mind posting some installed pics...??
Stalker
Car: 335I
Default 10-26-2015, 07:54 AM
You do realize these are not very visible installed right? Someone would have to take the car back apart to get pics. These are just higher flow fittings that connect the underside of the turbo to the engine block. Pictures of them are in this thread.
Car: 08 E92 335i
Default 10-26-2015, 08:34 AM
I didn't mean an undercarriage shot once everything was all put back together lol, I meant pics of them newly installed once still down there..
Stalker
Car: 335I
Default 10-26-2015, 08:41 AM
See post #3 for stock line example. See post #49 for RB High Flow drain install example. See post # 90 for RB High Flow drain finished product example.
Thanks,
Rob
Car: 08 E92 335i
Default 10-26-2015, 09:18 AM
Couple pics I snapped of these without anodizing, hose clamps, or heat shields; just do give you an idea of how they route the drain. 1st pic is rear, 2nd pic is front.
These weren't showing up on my phone but just looked on computer, thanks Rob that's exactly what I was interested in seeing..
Car: 09 E92 335i
Default 10-26-2015, 09:47 AM
I think this is a great concept. But can you have some OEM quality hoses and connector instead? Or maybe AN fitting instead.
Just not a fan of hose clamp style connections for oil lines...
Tin Tin is offline
Default 10-26-2015, 11:22 PM
Yes sir.
Thanks Rob, payment made yesterday.
Cheers
Tin
Stalker
Car: 335I
Default 10-27-2015, 04:09 AM
No sir. There is just not space for AN bends and what not, they are wayyyy to clunky to get it right. This is what I tried back in 2012 and realized it was not going to work and let the project die. In short if you want perfect angles for ideal draining (as pictured), this is the route you must take and I must say it was a massive undertaking to get these all angled to my liking. And BTW many OEM configurations use hose/clamps just like this. At the end of the day, the adapters are the expensive part… if someone feels they can use a better hose go ahead and get another hose that you prefer but the adapters will remain the same by necessity to say the least.
Cheers
Tin
bdhh's Avatar
bdhh bdhh is offline
Car: 2008 335i convertible
Default 10-27-2015, 07:42 PM
First I need to be clear that I know almost nothing about BMW, as I have only had my car for a few months. But I make my living as a red seal certified commercial transport mechanic and I do know something about oil lines & turbos.
Any of you guys that install these with heater hose are looking for trouble, I have seen first hand what engine oil does to heater hose over time. It degrades the hose from the inside & you will never see it. But chunks of crap will be going thru your whole system, not good. I just bought a set of turbos & am seriously considering buying these, they look great! But I will be using hose rated for oil & crimp clamps which anyone can install with a pair of side cutters.
Just saying
Barry
2008 BMW 335i Convertible
ADE Bottom Mount 6062 Single
VRSF Charge Pipe & 7in intercooler Tial BOV,
Ign Project Plasma Coils & grounds
Robs High & low side Catch Cans with
head plugs.
Diff Brace, Fuel it stage 2 & Meth Port Injection
Aquamist HSF-4 Meth injection
Alpina Flash
BMW PE Mufflers
MDH Flash
Line lock & 16in Drag Radials
11.7 ET, 1.8 60ft, 122mph
Stalker
Car: 335I
Default 10-27-2015, 07:49 PM
Agree on the above, just want to add in case anyone is confused- these are not equipped with heater hose.
Thanks,
Rob
bdhh's Avatar
Default 10-27-2015, 09:47 PM
Thanks,
Rob
I was confused, pic looks like it.
my apologizes
head plugs.
Alpina Flash
BMW PE Mufflers
MDH Flash
Car: '10 335i
Default 10-28-2015, 07:13 AM
Thanks,
Rob
Can you tell what material they are?
Stalker
Car: 335I
Default 10-28-2015, 07:29 AM
It is a low pressure oil hose made by Gates of 5/8" ID. Used it for years with no issues ever.
"Tube: Black, oil resistant, synthetic rubber highly resistant to oil and heat (Nitrile - Type C)."
However and as stated prior, if anyone doesn't like it (want it in blue/etc), all you need less than 1' of any hose of your preference (each hose is around 5.5"). This stuff in particular is around $5 per ft, about the norm for a high quality oil hose.
Rob
Car: '10 335i
Default 10-28-2015, 07:48 AM
Rob
bdhh's Avatar
Default 10-28-2015, 07:49 PM
Rob just sent payment
Barry
head plugs.
Alpina Flash
BMW PE Mufflers
MDH Flash
Stalker
Car: 335I
Default 10-29-2015, 06:23 AM
Barry
Got it thanks. These will ship today.
Rob
DOCRAMON DOCRAMON is offline
Car: 2008 535i
Default 11-01-2015, 07:03 PM
How could i order these upgrade?
