GabrielGray's Avatar
GabrielGray GabrielGray is offline
Car: 2007 BMW 335i
Default Stealth airbox mod for under $10 (pictures work now) - 11-24-2016, 09:27 AM
My best friend suggested I try this and given I see people sell air boxes all the time on Facebook so I figured I'd give it a go. Worse case I have to buy a used air box for 80 bucks. Idk how it performs yet but I'll keep y'all informed.
Step 1:
Remove air box.
Step 2:
cut a hole in the right side (see picture) with a hole saw. Sand it down after the hole is in the air box to ensure the surface is free from large particles and has grip to plastic weld the pvc shower drain to.
Step 3:
Sand the sides of the black pvc pipe to give the surface a little extra grip for plastic weld. After all the sanding is complete I took a cloth and wiped off all surfaces to remove debris from all surfaces.
Step 4:
I then used the plastic weld (pictured) and ran some in the outside of the pvc pipe.
I then inserted it into air box. After it was where I wanted I went from the inside and put a bead of plastic weld around the two contact points on the airbox and pvc pipe.
Step 5:
Let it sit for a while, the directions to plastic weld recommend 24 hours to ensure a perfect hold. I let it sit for 4 hours and then installed it again.
That's it! We'd recommend if you were driving the car daily to put a mesh screen over the grate, I did not do this however because I don't use the car daily.
I did this because DCI and CAI are like 400-500 dollars and very visible. I'm trying to give the illusion that my car has zero mods. This was very cheap and very hard to see at a quick glance. I'll let you guys know how it seems to work in the next month or so, but few free to comment and orntry it out yourself. Plastic weld and pvc purchased at lowes.
Let me know what you think below.
Happy thanksgiving nerds!
2007 335i:
VRSF Chargepipe, HSK BOV, VRSF **, VRSP FMIC, MMP inlets, MMP outlets, Stage 3 MMP twin turbos, JB-4
Car: 2007 BMW 335i
Default 11-24-2016, 10:18 AM
Very hard to even see it st a quick glance
2007 335i:
Default 11-24-2016, 10:26 AM
Right idea but it's even cheaper to just remove the airbox lid when racing or on the dyno. Then you put it back on when you want the air going in to the turbos/engine filtered.
Stroked & Blown Stroked & Blown is offline
Car: '10 e61 535i Xdrive
Default 11-24-2016, 12:08 PM
Isn't that hole post filter?
Car: 2010 135i
Default 11-24-2016, 12:19 PM
Yes.
Some friends are idiots and should not be listened to.
2010 135i auto, MHD E40 tune, Fuel-It stg 2 pump, best 1/4 mile 11.863 @ 119.17 mph
new mods this year, VRSF 5" stepped IC, RB EVO inlets, CP-e/Tial CP, 1320 **'s, xhp stg 3 trans tune, E-85 tune
Best 1/8 mile: 7.469 @ 98.56, 1.769 60'
Best 1/4 mile: 11.480 @ 121.79 1.802 60'
eaton18spd eaton18spd is offline
Car: 2008 535xi
Default 11-24-2016, 01:05 PM
I would not recommend anyone doing this. This permanently bypasses the air filter. You will quickly destroy the turbos and the engine.
bradsm87 bradsm87 is offline
Car: E90 LCI 335i
Default 11-24-2016, 02:57 PM
LOL. Nice air filter!
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 11-24-2016, 03:06 PM
that will just take all the dust directly without being filtered pemenantly.
Icelandic Icelandic is offline
Car: 2008 335i 6MT
Default 11-24-2016, 03:25 PM
Nothing says zero mods like a HKS BOV.
Car: 2007 BMW E90 335i
Default 11-24-2016, 04:18 PM
Is this a joke? You need a new best friend...
2013 135is DCT Carbon Black
badblackcoupe's Avatar
badblackcoupe badblackcoupe is offline
Car: 2007 335i e92
Default 11-24-2016, 09:46 PM
wants a stock underhood look but wont hide his BOV...
and in the process converted his cool air grille induction to a engine bay induction
vitan's Avatar
vitan vitan is offline
Car: e92 N54 335i
Default 11-25-2016, 04:19 AM
07 335i
RSicks's Avatar
RSicks RSicks is offline
Car: 2010 535i M-Sport
Default 11-25-2016, 09:03 AM
It would have been easier to just remove your air filter, throw it away and then close air box lid. It would have at the very least gotten you colder air since you dont care about clean air entering your engine.
'15 435i ///M Sport
CTS Intake VRSF CP/Race FMIC/D P/TIC MHD S2+ E20
Sold - '10 535i ///M Sport - FBO
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 11-25-2016, 09:16 AM
And some people are too and should never touch a car, let alone open their hood.
Mike Levy
2017 X3 xDrive35i
2000 F150 Lightning
2018 Equinox LT 2.0T
Car: 2007 BMW 335i
Default 11-25-2016, 09:41 PM
People have been running open turbos and intakes forever.
2007 335i:
Car: 2007 BMW 335i
Default 11-25-2016, 10:22 PM
Also a bov doesn't add hp.
2007 335i:
ianc ianc is offline
Default 11-26-2016, 08:44 PM
Awesomely well documented and photographed method of defeating that pesky factory air filter. Well done!
ianc
Mike_L's Avatar
Anti-Social
Default 11-26-2016, 08:54 PM
They've also been blowing turbos and engines forever. Your point?
Mike Levy
2017 X3 xDrive35i
2000 F150 Lightning
longnvu longnvu is offline
Car: 535i
Default 11-26-2016, 09:01 PM
https://www.youtube.com/watch?v=lLSD6ntBoEw Yea forever sounds about right
automech automech is offline
Car: e92 335i
Default SAVAGE - 11-26-2016, 09:58 PM
savage lol!!
Car: E90 LCI 335i
Default 11-28-2016, 02:55 AM
LOL at you trying to cover up what you overlooked acting like it was intentional!
Vogt.ryan's Avatar
Car: 2008 BMW 335i sport
Default 11-28-2016, 03:21 PM
between the leaking oil housing and the unfiltered air, he will be rebuilding the motor in no time.
Kish2604's Avatar
Kish2604 Kish2604 is offline
Car: E92 335i
Default 11-30-2016, 06:39 AM
A for execution but big F for thinking this one through...
#fail
|RB old gen|Jb4 G5|3" **'s|ER Competition Cooler|ER Charge pipe|Tial BOV|CM Meth Kit|Dual nozzle setup|BMS cowl filters|AFE intakes+scoops|
|BMS low temp oil thermo|MHD flash + coding|HnR Springs|M3 Control arm kit + H&R + Koni|LED Angel eyes+plate lights
DennisPacMo's Avatar
DennisPacMo DennisPacMo is offline
Car: 335xi
Default 11-30-2016, 02:17 PM
I like the idea. Stealthy and cheap. That air should be filtered though. Google or search MR5 intake. That takes your idea to the next level if your going to continue to use your stock airbox.
Car: 2007 BMW 335i
Default 12-01-2016, 09:48 PM
I've been looking into that stuff actually. The nizpro guys did this to their 335 and I love it.
https://youtu.be/6MP9OQ_VJ-0
2007 335i:
