(#76)
str8shot str8shot is offline
Car: N54 135i
Default 01-22-2016, 02:41 PM
Originally Posted by Vegasboy
Okay I was able to get the str8shot app to pair and connect over Bluetooth, I'm now showing E46. I did notice you have to select the Bluetooth module each time you start the app, is there any way to get it to automatically connect to the module when you launch it? Also instead of being able to see everything on one screen you have to scroll down to see temp, and scroll down again to be able to select the Bluetooth module. Landscape mode would also be nice.
Now how do I get the JB4 mobile to show the correct content?
What kind of phone do you have? It shows everything on one page for me.
2008 Montego Blue 135i Coupe // Sport Package // JB4 G5 Iso in passive mode with custom e30 MHD tune // Bluetooth e85 content analyzer with JB4 integration // Walboro 255 inline pump // BMS downp|pes // VRSF 7" FMIC // ER charge pipe // Turbosmart BOV // Injen intake // M-Factory SMFW // F10 550i clutch // Vorshlag camber plates // Hotchkis FSB // Turner adjustable drop links // AST 5100 coilovers // Hawk HPS pads // Ti backing plates // Stoptech stainless lines // Turner 15mm front spacers
3000GT MR's Avatar
3000GT MR 3000GT MR is offline
Car: 09' 335i
Default 01-22-2016, 08:54 PM
I've tried to PM you on both here and e90. Im interested in a kit.
Have a single turbo and/or tired of burning up O2 sensors? Ask me about the new ADV O2 sensor retro kits!
335i 2010 e92 M-sport Mods: VM Top mount 6466, Aquamist HSF4 w/custom direct port. VRSF IC + Exhaust
335i 2009 e90 665RWHP VFF900 ST RIP .
Vegasboy Vegasboy is offline
Car: 2009 335i
Default 01-23-2016, 09:10 AM
I'm running a Dragon Touch tablet. Finally got the ECA reading on the Jb4 mobile, you have to make sure meth scale is set to 100. I have noticed your app currently shows E45 while the JB4 app shows E44. Why are they different?
TwistedTuning TwistedTuning is offline
Car: 2007 335xi 6MT Sedan
Default 01-23-2016, 09:35 AM
This is a great little tool you have here. So I would just need to buy the continental ethanol sensor and your kit with Bluetooth for this to work? (Aside from the connections needed for the stock fuel line)
I'm non JB4 so if I read correctly, to get a readout I'd need either the digital display or your Play store app?
"Increasing the Area Under The Curve"
Custom Performance ECU Calibration
www.twistedtuning.com
twistedtuned@gmail.com
veee8's Avatar
veee8 veee8 is offline
Car: BMW
Default 01-25-2016, 10:19 AM
Sorry, absolutely slammed with my day job and two orders that are way way overdue. I'll reply to all shortly.
Are you ready to accept an order yet str8shot?
Car: N54 135i
Default 01-25-2016, 11:28 AM
I'll be replying to all PM's this afternoon.
Car: N54 135i
Default 01-26-2016, 03:36 PM
Correct. You'd need a stand alone display, or Bluetooth (or both!).
Car: N54 135i
Default 01-26-2016, 03:38 PM
It probably has to do with the way JB4 rounds an analog value (JB4 is voltage in, so there's a bunch of conversion - sensor stream - to voltage out - to JB4 voltage in - to DA converter). Mine rounds up at a .5 or greater value.
The Bluetooth value is the truest value there is. On the same token, the continental sensor itself has a +/- 5% tolerance, so the variance isn't anything to be concerned over.
Car: N54 135i
Default 01-27-2016, 10:00 AM
A couple people have asked about wiring. All future orders should feature interlocking connectors, which should make things much easier and cleaner.
For anyone with current ECA's up to yesterday, here's how you wire them:
For USB powered - the USB power supply red / black get wired to the DME power / ground. The USB cable is then plugged into the ECA and the power supply:
For new power supply models:
For the digital display:
Car: N54 135i
Default 01-28-2016, 02:24 PM
FYI - The above pictures should say pin 15 of the DB25 connector, not the DB9 connector.
Car: N54 135i
Default 02-01-2016, 04:12 PM
Two gauge upgrades and a full digital kit shipped out today. More going out tomorrow.
Car: N54 135i
Default 02-04-2016, 03:57 PM
New ECA design is complete! This will feature all plug and play interlocking connectors. Now when you buy a standard ECA, it will be prewired with matching connectors for bluetooth and display upgrades.
This should make the DME box much cleaner, and eliminates any confusing wiring.
Connectors from top to bottom are 2 pin power, 4 pin main connector (sensor input along with JB4 output pin), 5 pin digital LED connector (plugs into the digital LED display harness), and 3 pin bluetooth connector.
Pictured below it is a bluetooth add-on module with matching 3 pin connector. Just plug it in and go!
Here's what a standard ECA will look like with the bluetooth add-on module connected. I'll be including a piece of heat shrink to bundle the two together:
The power supply and main sensor harness (not pictured yet) both feature matching connectors. Everything locks together, and will only plug in one way.
Let me know what you think!
veee8's Avatar
Car: BMW
Default 02-05-2016, 07:16 AM
Looks very nice and clean! Great for future upgrade ease.
I love the fact that you are always trying to improve the product.
Can't wait to get mine!
kurt4726 kurt4726 is offline
Car: EVO X
Default 02-05-2016, 06:20 PM
The new version is nice! The connectors are an excellent improvement. Will I be getting the new version when you have some ready to ship? If you will be improving it further I can wait.
Default 02-05-2016, 06:25 PM
Do you have any Bluetooth enabled kits ready? If not when will you? Think I'm ready to grab one for my shop car
neroneuman's Avatar
neroneuman neroneuman is offline
Car: n54 335i
Default 02-06-2016, 06:14 PM
I'm trying to get one standard ECA Package A to connect with JB4. how can I pay and get it?
Car: N54 135i
Default 02-07-2016, 09:28 AM
Hi Kurt,
You'll have a new one - it should be delivered Wednesday.
Thanks,
Scott
Car: N54 135i
Default 02-07-2016, 09:30 AM
I have all the parts for bluetooth in stock, but I do have a few to build ahead of you.
If you want to order, PM me and I'll send you the paypal address to send payment to.
neroneuman's Avatar
Car: n54 335i
Default 02-07-2016, 06:00 PM
Is there a way to install the Ethanol sensor in between the stock fuel lines?
If that's not possible, is "HPFP to Tank " the right option to buy from the fuel-it website http://www.fuel-it.biz/e-series-135i...grade-options/
I see only one line in that option, I'm not sure how to fit the Ethanol sensor in between?
Car: N54 135i
Default 02-07-2016, 09:05 PM
That's the correct fuel it kit. You can buy the fittings and cut your stock fuel line, but it requires a special compression tool to install them. . I can provide part numbers if you'd like.
neroneuman's Avatar
Car: n54 335i
Default 02-07-2016, 09:29 PM
cool, that's good. Please give me the part numbers and the tool information. I will see If I can do it.
Car: N54 135i
Default 02-09-2016, 01:40 PM
The Dorman tool would be 800-301:
http://amzn.com/B000E35W1K
And the fitting you need is for 5/16th nylon line to 3/8 steel would be 800-085:
http://amzn.com/B000E35WJW
Car: EVO X
Default 02-12-2016, 10:20 AM
I received mine in the mail today! Thanks str8shot.
_ink's Avatar
_ink _ink is offline
Car: 335i DCT
Default 02-19-2016, 09:19 PM
Str8shot, you are probably the most least responsive person out there trying to sell a product online. I've tried PM'ing several times for the required firmware for the LED screen that's required.. so posting here so you actually see that i'm still waiting.
Also, I wanted to confirm the wiring with you. I think i've got it right but need confirmation:
This is the confusing part.. I have a blue wire and black wire (male)...
But the females are both black? Does it matter which goes into which?
Please confirm?
Car: N54 135i
Default 02-19-2016, 09:31 PM
I've been out of state for work. I'll reply tomorrow (saturday).
That is not correct, I'll post a wiring diagram in the morning.
