(#1701)
Pumaman Pumaman is offline
Car: 2017 bmw 440i
Default Upload error everytime. Help please!!! - 08-26-2019, 02:49 PM
Iím updating my 440i with what I thought was the correct B58 hex 13 file. However it wonít move past 10 files and tells me itís an upload error. Now I canít do anything for maps. Help please!!
biocops biocops is offline
Car: BMW 530i M sport
Default Firmware ver 11 - 08-26-2019, 04:09 PM
Hi, Iím new here and I canít seem to get the firmware download for version 11. Pls assist to guide me to the correct page. Thanks in advance
mesor mesor is offline
Car: M140i
Default 09-09-2019, 05:09 AM
Hello from Germany,
My M140i MY2018 suddenly changes the map after a short drive, from map 2 to map 8,
map1 and 3 works fine.
How can that be?
Latest Firmware is installed, car is stock, fuel is 100 RON.
risktaker76's Avatar
risktaker76 risktaker76 is offline
Car: BMW 440XI MPPSK
Default 09-09-2019, 05:37 AM
I had the same issue - do it when the car is cold. if your bluetooth make sure nothing else is connected.. try to get as close as possible to the car.
I had to do it like 10 times!!! before it took!!
Then make sure your FUD is properly set or you will be running on backend flash settings - which dont work well on a non-flashed car.
BMW After BMW
Car: BMW M240i
Default 09-09-2019, 06:32 AM
Is it also possible youíre triggering safety mode? I think 8 was safety mode map, but I may have forgotten.
Bmw_ire_2012 Bmw_ire_2012 is offline
Car: M240i
Default 09-10-2019, 01:59 AM
What's the lastest firmware version for the b58, I see many I'm guessing it's 14?
xz329 xz329 is offline
Car: F30 330e
Default 09-10-2019, 08:19 AM
how do i upgrade my firmware for b48?
BMW After BMW
Car: BMW M240i
Default 09-10-2019, 09:56 AM
There are messages and videos explaining it on the main b58 thread.
Elfeix Elfeix is offline
Car: M240
Default Can bus control - 09-25-2019, 05:41 AM
How to control the can exaust in map 2 and 3 by bluetooth?
335i101 335i101 is offline
Car: 07' 335 Cpe
Default 10-04-2019, 07:31 PM
Installing in Supra tomorrow. Just confirming the map guide at the beginning of this thread is not accurate and I should use the map guide listed on the BEF thread? Even if I don’t have a BEF?
Default 10-04-2019, 10:10 PM
The BEF guide is for BEF settings, so use the normal guide if not running a BEF.
