3van 3van is offline
Car: Pure turbo S1 FBO 335i
Default Can't figure out what's wrong - 02-23-2019, 02:04 PM
FBO pure turbo stage 1 335i
Car sat for 5 months, and started throwing random check engine lights after the sit. I thought it was the fuel, but after a few tanks it wasn't. Noticed it would throw a CEL @ 5.5-6k rpms wot. So I decided to change the plugs, ngk -1 .. which were the same ones that were in the car. old ones didn't look fouled once pulled.Igapped them to .22
Drove the car, once again got a cell (sometimes) for a camshaft sensor, intake. So while waiting for the part I cleaned my vanos solenoids. I Swapped the sensor today and idle and driving is perfect. Car pulls hard, but now around 6k the car misfires cylinder 1 & 3. Prior to today, never got a misfire in any cylinder. I am stumped and don't know what else to do. AFR is digital using jb4 and the car isn't running lean. Fuel pressure L/H is perfect.
Someone help
treehouse treehouse is offline
Default 02-23-2019, 02:34 PM
Swap coils from bank 1 to 2. See if the failure follows.
If still on bank 1 then do injectors.
Swap and recode injectors between banks. See if the problem follows
Default 02-23-2019, 03:30 PM
That's what I'm going to try tomorrow, start with coils. If it's not, might bring it somewhere to get it diagnosed
Default 02-24-2019, 02:39 PM
Just swapped coils, still cyl 1 & 3 ****.
Default 02-24-2019, 03:58 PM
You could also check if there is gas on a plug after sitting for a bit. That would indicate a failed injector as well.
Default 02-26-2019, 08:04 AM
Just did brand new plugs .22 gap ngk -1 laser iridiums
Default 02-27-2019, 12:28 AM
.22 or .022?
If .22 thatís an issue too.
Default 02-27-2019, 07:57 AM
.022 gapped typo.
Default 02-27-2019, 12:03 PM
Let the car sit overnight -
Pull plugs 1-3- see if they’re wet with fuel.
If yes- injector on that bank
Edit- could also check the gap & close it a bit to .020
