robinsson's Avatar
robinsson robinsson is offline
Car: bmw 335
Default how to get psi with turbo stock - 11-11-2017, 09:48 AM
help how to get 23 psi with turbo stock ????
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 11-11-2017, 09:51 AM
Use map 3 or map 6 if you have enough supporting mods
treehouse treehouse is offline
Default 11-13-2017, 04:24 PM
That is above the standard tmap so you will at least need 3.5bar and the rest of the supporting mods. On stock turbos this is at the complete upper limit. You may want to do some more research before just setting to 23 and winging it.
AWSAWS's Avatar
Default 11-14-2017, 09:22 AM
Exactly. You are going to want methanol injection or a good mix of E85, (which in turn requires an upgraded fuel pump above an E30 mix) and a back end flash if you aren't going to just blow your engine up
robinsson's Avatar
Car: bmw 335
Default 11-14-2017, 02:11 PM
i have tmap sensor, backend and flash, fuel it stage 2 FPL, downpip,intake,pi meth and tuned map 6 running e85...but I do not have more than 380whp ):
Car: 2008 E93
Default 11-14-2017, 03:08 PM
Post a log or 2
