8900120d 8900120d is offline
Default hydraulic lifters (tappet) diagnosis - 05-16-2017, 06:16 AM
Hi guys,
So im always hearing metallic rattling noise coming from the engine at idle, i have my valve cover off to tap and plug the pcv system.
i was wondering if theres anyway to check which hydraulic lifters are damaged? or if there a way i can clean them?
would appreciate some info
Vogt.ryan's Avatar
Car: 2008 BMW 335i sport
Default 05-16-2017, 11:21 AM
I wouldn't plug your pcv valve imo. And are you sure it's not injectors? When's the last time you changed oil? N54 motors generally make some lifter noise.
2008 335i Sport Jb4, MHD BEF, Alpina flash, Uncatted *****, PE Mod, Injen Intake, v710's , Vogtland Springs
Default 05-16-2017, 01:45 PM
I plugged the pcv intake slots as i have an external pcv system. The car is running fine so i don't think its injectors. But as i have it all open i thought it's a good time to replace the hydraulic lifters...
I6+TT=FTW's Avatar
I6+TT=FTW I6+TT=FTW is offline
Car: 2007 E90 335xi
Default 05-16-2017, 02:48 PM
he was saying that the injectors tick. Not that they're broken, just loud. Direct injection isn't quiet.
2007 Jet Black E90 335xi /PTF-Cobb/E50/FuelitS2/5" Stepped FMIC/Synapse BOV and Charge Pipe/Black 19x8.5/245s all around/and more
