Levan-i's Avatar
Levan-i Levan-i is offline
Car: 2007 BMW 335i E92
Default 09-16-2015, 03:24 PM
btw did you try to replace injector? to other cylinder, just to surely exclude it
2007 E92 335
ST - GTW3684
JB4 G5, ST Pump Flash, Fuel-It Stage 1, Meth
MT (after swap),
MFactory LSD
Rolltide67's Avatar
Rolltide67 Rolltide67 is offline
Car: 2008 335i E92 coupe
Default 09-16-2015, 04:11 PM
I'm going to try that this weekend.
Default 09-17-2015, 08:18 AM
FCV is the fuel Flow Control Valve, it's located on the HPFP.
If the dealer installed an injector retention plate upside down, forgot to install a coupler, or there is a bad o-ring, that could cause the issues you are seeing. Coding could also contribute to that. Your rail pressures are really erratic though...that is pretty strange.
Send me a copy of the exact flash you are running from your computer.
steve@burgertuning.com
Rolltide67's Avatar
Default 09-17-2015, 05:13 PM
Ok well the problem is fixed! Cylinder 6 had a bad injector. Not that the part was bad but it was improperly installed( by the dealer) and the retaining tab was broken. Therefore it was just moving back and forth in the head. Secondly my plug(NGK) on # 3 was not sealed properly from the factory. There was blow by on the porcelain top part of the plug. Replaced both. It now runs great and NO MISFIRES...for now I am looking forward to getting my inlets from VRSF and hopefully putting down some decent numbers.
Thank you everyone for all of your help and advice!
Default 09-17-2015, 06:34 PM
335iboosted 335iboosted is offline
Car: 2007 e90 335i
Default Revive old thread - 05-13-2017, 07:47 AM
Hey I've been having same issue , I got WOT and get misfire cylinder 2 and does not move , I have replaced the plugs gapped to 0.020 and to 0.018 , moved also to ngk 95770 and now to auto lite 5862 1.5 step colder and still misfire , got new Eldor coils , still misfire , got new injectors for bank 1 and still misfire , I'm wondering if it's my port Injection cause if unplug harness and go to different map no misfire so I'm wondering if I have a bad injector on the port injection on #2 , I've done everything I can think of besides coding the injectors yet just trying to do trial and error I'll post log now for u as well if someone could help
PawlyGuNNz PawlyGuNNz is offline
Car: 135i N54 6sp MT
Default 05-13-2017, 09:06 AM
Post some log 2k-redline ... 3rd gear... I'm having misfire issues too in cylinder 6, hoping it my hpfp choking, since I'm upgrading to PI and stage 3... but might be my DMFW... have you done a compression test?
jb4 g5 ISO,MHD\JB4 BEF, Pure stage 2 hybrid hi flow n54,PR stage 3 fuel pumps, ADE port injection,RB PCV, BMS occ, ER CP, TIAL BOV, VRSF Hotside inlets, VRSF 7" fmic, VRSF 3" ***, n55 mid, Berk Race, NGK GTR plugs, HPF Spec smfw twin disc clutch
ms335i ms335i is offline
Car: 2007 BMW 335i
Default 05-13-2017, 09:11 AM
I had the same issue and it was a boost leak causing the hpfp to cut off at high rpm. I know it sounds crazy but that's what it was.
Default 05-13-2017, 09:33 AM
Wow, that's interesting, but my car doesn't seem to have any boost issues, for example map 7 runs fine, for me it was only misfiring above 6k at 23psi on E85 bef w e50 fuel
Car: 2007 e90 335i
Default 05-13-2017, 10:18 AM
My hpfp is diving up top and I'm stage 3 pump and pi here is log
Car: 2007 e90 335i
Default 05-13-2017, 10:19 AM
http://www.***********/u/335iboosted/...=1-4&zoom=0-60
Car: 2007 e90 335i
Default 05-13-2017, 10:23 AM
Here is the other with the new boost settings and log
335iboosted/log-1494696181?log=0&data=1-4
