328iwagon 328iwagon is offline
Car: 2009 328i wagon (335i)
Default cylinder 5 constantly misfiring and going crazy - 04-16-2017, 05:44 PM
hi everyone
i been having issues with my car misfiring, i can not get it to work properly.
my mods are:
n54 engine, single turbo 6466
jb4 MHD back end flash
stage 4 pump with return kit and fuel-it port injector with bms controller jb4 integrated, controller is been remove from now but did not change anyhitng with the misfire.
full e85
i replace the injectors, spark plugs and coils. injectors were coded. also i replaced both o2 sensor pre *** ones an hpfp as well is been replaced
i changed spark plug and coildpack from cylinder 1 and to cylinder 5 and 1 to 5 and still misfire the number 5. not matter what i do, the number 5 is the f**** misfiring cylinder.
i remove the ecu msd81 and checked the mosfet and they test good, i run out of the answer and ideas on what can be happening.
map 1 misfire, map2 as well, not matter wha i run it misfire
i attached is a log that i did today,
sshec152's Avatar
sshec152 sshec152 is offline
Car: 07 335i mt
Default 04-16-2017, 06:03 PM
Compression and leakdown test
Default 04-16-2017, 06:04 PM
Yes I did compressiontest and leak test as well, I will remove the thread and put it in the right place before the tell me something lol
ms335i ms335i is offline
Car: 2007 BMW 335i
Default 04-17-2017, 07:08 AM
hpfp is ****ed
phv628's Avatar
phv628 phv628 is offline
Car: BMW 2009 335i xdrive
Default 04-19-2017, 05:03 AM
Originally Posted by 328iwagon
hi everyone
my mods are:
full e85
You should post a log so we can check it out.
|E92 335i xDrive| |JB4+MHD BEF| |VM Single Turbo Kit + PTE 6466| |Built Auto Trans| |xHP Trans Flash| |Stage 4-Triple Walbro 450s, fpr + return| |EOS Intake with Port Injection| |AD-ENG FMIC + AD-ENG OCC| |RB PCV Kit| |PR Ignition kit| |Built N54: Darton Sleeved, Manley I-Beam Rods+ARP Rod Bolts, JE 9.5:1 Pistons, JE Wrist Pins, VAC coated main & rod bearings + ARP Head Studs| |Keyed crankshaft snout, crank hub, timing & oil pump sprockets + VTT crank-bolt capture| |ADV Oxygen Sensors|
