(#626)
Default 10-16-2016, 11:02 AM
Responded to your email....thanks.
dh58 dh58 is offline
Default 10-17-2016, 07:22 AM
Anyone else get a whiff of ethanol in the cabin after hard boost?
NA55 NA55 is offline
Default 10-17-2016, 08:22 AM
Check for leaks on the fuel filter under passenger seat on drivers side..
rstihl rstihl is offline
Car: BMW 335i
Default 10-19-2016, 10:50 AM
tbi is still not working i have checked everything, wiring,power, fittings tight adjusted hobbs switch max both directions. at a loss and not too thrilled about a $600 mod that doesnt work.
car pulls fairly hard up to 6000rpms and then misfires
Default 10-19-2016, 05:42 PM
Your FOL is at zero and your trims are maxing out.
You're running 100% E85 correct? Set your FOL to 60. Then try a log with TBI on and without it, both at lower boost to determine if you are triggering TBI or not.
lightning lightning is offline
Car: BMW 1M Coupe
Default 10-19-2016, 07:36 PM
Hi Steve, what's the difference between the TBI and the direct port injection?
Default 10-19-2016, 09:09 PM
TBI uses a spacer between the throttlebody and the intake manifold that has two injection nozzles that are opposed and flows are controlled by a boost referenced solenoid. TBI flows approximately 1000cc/min when activated and is either on or off.
Port injection is a spacer that is installed between the intake manifold and the head with 6 individually controlled injectors. Our port injection kit flows 0-3300cc/min and is PWM referenced based on boost, rpm, and fuel pressure.
Car: BMW 335i
Default 10-19-2016, 10:17 PM
logs
im on now e50
played with ff and fol settings
pulls great until 6000rpms then misfires
should i still try the lower boost with and without tbi hooked up steve?
Default 10-19-2016, 10:24 PM
Yes
Where is your hobb's switch mounted? Do not max out the hobb's switch in either direction. Set it so you can see about 1 thread showing.
Car: BMW 335i
Default 10-19-2016, 10:27 PM
Originally Posted by Steve @ BMS/Fuel-It!
Yes
meth bung
johmei's Avatar
johmei johmei is offline
Default 01-18-2017, 01:43 PM
What is the circled piece called and where can I get a new one without just getting the whole adapter/fitting?
(I got a used TBI kit and this piece was pretty messed up)
Default 01-18-2017, 02:45 PM
We don't get or sell those separately however if you do a search, Dorman offers those individually.
johmei's Avatar
Default 01-19-2017, 12:27 AM
Ok thanks Steve! I'll check it out.
Contacted Nitrous express Europe yesterday to see what they can do as well.
enyce5434's Avatar
enyce5434 enyce5434 is offline
Car: 2007 bmw 335I
Default 01-19-2017, 10:45 PM
Hi steve, can I buy a 15ps hobb switch? Couldn't find it on the website?
Default 01-20-2017, 09:08 AM
Here is the link for those.
http://www.fuel-it.biz/stage-3-hobbs-switch/
johmei's Avatar
Default 01-20-2017, 11:12 AM
http://i.imgur.com/TpLSR5G.png
I can confirm that Nitrous Express Europe offer the individual clip for sale.
matthewo matthewo is offline
Default 01-23-2017, 11:16 AM
Hi Steve,
I purchased a used one of these, does the kit come with a new O ring for the plate, or does it just reuse a factory gasket?
also if you provide the gasket can I purchase a new one.
Jeffman's Avatar
Jeffman Jeffman is offline
Car: 335xi
Default 01-23-2017, 12:58 PM
I had misplaced my o-ring. Here is the replacement you can buy online, for example at Amazon:
152 Viton O-Ring, 75A Durometer, Black, 3-1/4" ID, 3-7/16" OD, 3/32" Width
2008 E90 335xi AT 67K MILES
MHD CUSTOM FLEXFUEL 24 PSI, N20 TMAP, FUEL-IT STG 2 LPFP, cPE CHARGE PIPE, HELIX IC, TIAL Q BOV WHITE SPRING, BMS DCI, BMS T-STAT DELETE, BMS HIGH AND MISHIMOTO LOW OCC, RB PCV, KW-V1 COILOVERS, APEX ARC-8, 235/265 MICHELIN PSS, xHP STAGE 3, SCOOPS, PR IGNITION
jlcf22 jlcf22 is offline
Default 01-23-2017, 07:32 PM
Has anyone ever thought about running tbi with shotgun single barrel...benefit of that would be you won't have to buy and mess with any controllers and I wonder how much whp it would support
I6+TT=FTW's Avatar
I6+TT=FTW I6+TT=FTW is offline
Car: 2007 E90 335xi
Default 01-24-2017, 08:53 AM
Haven't seen this on anyone's car yet, but if you could snag a single barrel for cheap enough, I bet this would be a nice kinda simple solution. How much whp does the single barrel supposedly support?
2007 Jet Black E90 335xi /PTF-Cobb/E50/FuelitS2/5" Stepped FMIC/Synapse BOV and Charge Pipe/Black 19x8.5/245s all around/and more
Default 01-24-2017, 09:57 AM
Originally Posted by matthewo
Hi Steve,
For the throttlebody, you re-use the factory gasket.
For the manifold, the TBI kit comes with the correct o-ring as listed by Jeff
I don't know of anyone running that setup so I'm not sure what it would support.
At that point, I'd really just run port injection though.
Default 01-24-2017, 03:54 PM
I've seen used tbi go for 350.00 plus 800 for the single barrel new hpfp for 400.00 thought maybe it's worth a shot..maybe it can support 650whp?
johmei's Avatar
Default 02-02-2017, 05:43 AM
IMG]http://i.imgur.com/TpLSR5G.png[/IMG
The metal clip ordered: Dorman 800-093 Fuel Line Retaining Clip.
Also got a bunch of the plastic clips for the quick connect fittings as I do not like to reuse those: Dorman 800-005 Retaining Clip Gm
Default 02-02-2017, 08:42 PM
I just bought a used kit an installed it and have been running it a little while.
I have noticed on my logs when it sprays my trims per bank are way different.
I log both trims and avgign as trims so I can see both banks, before I installed the kit they stayed pretty much the same, now I am having 25-30 difference in it, like trims may be richer like 10-15 area and avgign trims I assume this is bank2 is reading 35-40
I need to adjust my fuel scalar a little for tip in, but I hope I don't have to adjust the fuel scalar per bank, I can only assume its getting uneven distribution but not sure why...
hunting11s hunting11s is offline
Car: none
Default 02-03-2017, 01:22 AM
that's exactly what's happening.
