7smurfs's Avatar
7smurfs 7smurfs is offline
Exclamation Oil on BOV (normal?) and meth bung (???) - 08-31-2016, 03:04 AM
Car doesn't seem to be pulling as hard and I noticed there's oil on meth bung which I find a bit odd?
I retightened the bung and managed to turn the nut about 1/4 . Could this be the culprit or is it normal?
135i N54 - BMS DCI - JB4 ISO - Meisterschaft GT exhaust - VRSF CP - Turbosmart Raceport BOV
I6+TT=FTW's Avatar
I6+TT=FTW I6+TT=FTW is offline
Car: 2007 E90 335xi
Default 08-31-2016, 08:18 AM
I've got oil residue all around my BOV. These cars have oil blow by issues, just is what it is. Even with a catch can I've still got some oil around the bov.
2007 Jet Black E90 335xi /PTF-Cobb/E50/FuelitS2/5" Stepped FMIC/Synapse BOV and Charge Pipe/Black 19x8.5/245s all around/and more
Jeffman's Avatar
Jeffman Jeffman is offline
Car: 335xi
Default 08-31-2016, 08:25 AM
^ exactly. Some oil will collect in the charge pipe. So oil outside the blow off valve suggests it's leaking out, which suggests a likely boost leak. Take off the bung screw or meth inlet and rewrap with Teflon tape and reinstall.
2008 E90 335xi AT 67K MILES
MHD CUSTOM FLEXFUEL 24 PSI, N20 TMAP, FUEL-IT STG 2 LPFP, cPE CHARGE PIPE, HELIX IC, TIAL Q BOV WHITE SPRING, BMS DCI, BMS T-STAT DELETE, BMS HIGH AND MISHIMOTO LOW OCC, RB PCV, KW-V1 COILOVERS, APEX ARC-8, 235/265 MICHELIN PSS, xHP STAGE 3, SCOOPS, PR IGNITION
7smurfs's Avatar
Default 08-31-2016, 03:08 PM
I've always assumed oil outside the BOV as standard due to blow by?
Jsr1256 Jsr1256 is offline
Car: 08 335i Sport Package
Default 08-31-2016, 07:16 PM
No oil on mine and I have oem dvs. I've always head that means there is a leak which is obvious if oil escapes. Check the dv orings they sell them at Lowe's in plumbing same.size
08 E92 335i AT 20k Miles | Wedge E60 Flash| E85 | VRSF FMIC | VRSF Lower Charge Pipe | ER Charge Pipe|Tial Bov| Vrsf *** | DCI | IC Sprayer | Scoops | NGK 1 Range Colder Plugs | Fuel It LPFP | E60 | [12.2 @ 118with e85 flash] [ My E60 flash 1/4 = 11.8 @ 120
RCB RCB is offline
Car: E61 535XIt
Default 09-01-2016, 07:18 AM
My car would do this until I installed the RB external PCV system now it stays clean. I have had my IC and piping out a few times since the install and everything is much cleaner.
2008 E61 535xit MHD, VRSF CP, Tial BOV, DCI, RB Inlets and Outlets, VRSF 7"FMIC, Custom ***, BMS OCC, RB External PCV, M5 seats, LED interior/DRL, 20" Style 128 wheels, KWv3, M5 steering wheel, M-Sport conversion, Bimmer-Tech HD/Apple TV, RB Twos
2008 Lexus ISF I/H/E, Figs suspension arms, BC/swift, BC wheels, PSS (305 rear)....
1993.5 Supra 857 WHP, GT42R, CCW/R888 (305 rear)...
1968 Plymouth GTX 440 (For Sale)
2017 Chevy 2500HD Z71 LTZ
IG: CBBOOST
7smurfs's Avatar
Default 09-01-2016, 04:50 PM
Good to hear as I've had a RB PCV sitting around not installed!
I assume that meth bung is causing a boost leak also, so will seal it up good to ensure it doesn't leak again.
