(#2151)
Default 10-09-2015, 09:35 AM
If you're using the POSI-TAP method its per the first post.
If you added on the OBDII CANbus cable and firmware, details on that are here: http://www.n54tech.com/forums/showthread.php?t=30750
arkow arkow is offline
Car: 2015 335i m-sport
Default 10-09-2015, 10:56 AM
Terry,
Are those the same firmware updates:
N55_FSERIES_EWG_3_31.hex
N55_OBDII_EWG_3.hex
I used N55_FSERIES_EWG_3_31.hex, should i update using N55_OBDII_EWG_3.hex?
tredirtyfive tredirtyfive is offline
Car: 335 E92
Default 10-09-2015, 04:21 PM
Originally Posted by arkow
Terry,
N55_OBDII_EWG_3.hex
If you have the ODB hardware installed you will have to use the "N55_OBDII_EWG_3.hex" file, otherwise none of the ODB dash tools will work.
Default 10-09-2015, 04:45 PM
Terry got back to me and i updated the firmware and all is working now.
harkes harkes is offline
Registered Users
Car: M135i
Default 10-11-2015, 05:22 AM
Hi Terry
I upgraded to OBD but the DB button functions does not work..? I am running pneumatic ISO - what is the correct FW version? I set FUD=2 and locked the car for ~10minutes. RPM etc is working in the interface.
Registered Users
Car: M135i
Default 10-11-2015, 06:54 PM
Interface Version 10/1/15
I just found out there is a new version... What are the upgrades compared to 7/1/15? Last safety will show why JB4 jumped to map4 I presume?
Default 10-12-2015, 07:44 AM
For the N55 there are no changes to the interface yet. In future firmware versions we'll add the new logic re: safety switch. Currently it's only in test versions of the N54 firmware.
toorboy toorboy is offline
Car: 2014 f10 535i m-sport N55
Default 10-13-2015, 11:41 AM
Hello everyone I am new to this site need little help installing my new jb4 to my 2014 f10 m-sport n55. I just received my new BMS intake and jb4 last week I installed intake was easy but confused with jb4 wiring harness comes with 3 plug and 2 wires are routed to the first plug .based on BMS instructions 2 wires goes by JB box but they routed different direction . Thanks
Default 10-13-2015, 12:31 PM
If you need install help on a new product purchased from us the easiest way to get it is to email in to tech support. Ideally with reference photos.
Make sure you're looking at the right guide as well. The three plugs are TMAP, MAP, and FlexFuel. The CANbus wires connect per the guide using posi-taps.
Default 10-13-2015, 02:28 PM
Thanks terry this help a lot
Registered Users
Car: M135i
Default 10-15-2015, 10:03 PM
You don't post any instruction here on how to deal with the removed FF rpm gain. Is that because it only applies to the ISO version of the OBD FW?
Default 10-18-2015, 12:11 PM
There isn't any information on the F series ISO BETA posted. Much of the same stuff carries over though.
Registered Users
Car: M135i
Default 10-23-2015, 12:04 AM
Tuning DB to get boost spot on target, I find the OBD FW much harder to tune than the old ISO. A 1-2 points +/- of DB will result in maybe +/- 1psi - very sensitive. I also find logs/pulls being more inconsistent... Anyone else experience this? I am considering going back to non-OBD but I also like to make it work.
Default 10-23-2015, 02:43 PM
There are probably 6 people using both versions of F series ISO firmware combined. The only difference as far as boost goes is on OBDII ISO the FF learning has been disabled and the built in FF RPM gain has been removed. Depending on the turbo used controlling boost can be a challenge on F series. I'd suggest tuning FF so its consistently below PWM a bit to allow the PID to be more dynamic in the control.
Registered Users
Car: M135i
Default 10-23-2015, 05:38 PM
6 people?! My impression is that there should be minimum 20 F-series with upgraded turboes and that all of those would run ISO?
Default 10-23-2015, 08:30 PM
Most cars are EWG and the control system with EWG is much better. PWG was only for 2013 models, and some 2012 international F series like your M135. ISO is for PWG systems only.
Registered Users
Car: M135i
Default 10-24-2015, 05:06 PM
Oh...then it makes sense. Well in that case - an even bigger >Thank you< for supporting the six of us
sc67065's Avatar
sc67065 sc67065 is offline
Car: n55
Default 10-27-2015, 09:56 PM
Any potential updates on the fw? CANFlap indicator fix? N55 could use a little more love here...
Registered Users
Car: M135i
Default 10-28-2015, 02:27 AM
Whats a canflap indicator fix? Something to show you what setting you are running?
secret_asian1 secret_asian1 is offline
Car: bmw f10 535xdrive
Default 10-28-2015, 08:43 AM
Don't forget about us F10 PWG guys
2014 535 xdrive, JB4 + FF running 93 octane SUNOCO FTW!!!
Default 10-28-2015, 09:01 AM
The F10 PWG guys can use F30 OBDII PWG firmware. Just need to set FUD = 2 to enable the BC button controls.
Registered Users
Car: M135i
Default 10-28-2015, 08:09 PM
Is it possible to get meth flow in the fuel gauge instead of boost? Dont really need a gauge to tell you whether you have boost or not + its not detailed enough to provide any useful information... Maybe the rpm gauge could also be made to show which map you are in when starting up the car (for those of us with Alzheimers ). A few ideas for more features
F30George's Avatar
F30George F30George is offline
Car: f30 335
Default 10-29-2015, 12:18 PM
I would prefer meth flow instead of boost also!��
F30 335i Jb4 ISO/ Pure stage2wIntlet/ DV+/ER Cp,Dp,FMIC /meth/MPE/BMS Intake/3.5barTmap/Spec stage3+/Pss10
Default 10-29-2015, 12:58 PM
We'll expand the fuel gauge at some point. But with boost on dash using map 3 you're also monitoring meth flow. If meth isn't flowing boost won't go up to target.
J2R J2R is offline
Car: M135i
Default 10-31-2015, 07:31 AM
Hello, my car is a 13/14 M135i with ewg.
My obd2 jb4 is working fine, change maps with BC button etc.. But the exhaust valve dont work, any ideas what causing this problem?
