(#126)
Alan L. Alan L. is offline
Default 05-21-2013, 03:18 PM
Are you guys changing any of the default settings or running it as is?
I am not sure what is even functional for the F10 at this point.
Alan
Sharbotcom Sharbotcom is offline
Car: 2011 F10
Default 05-21-2013, 03:22 PM
Since I have no other performance mods, I leave the settings and just use map 1.
Bill
2011 535i xDrive, Dark Graphite Metallic, Veneto Beige Dakota Leather, Technology Package, M Sport Package, Executive Package delivered Christmas Eve '10, Mods - quad tips, 20% tint, JB4.
ballinsoldier's Avatar
ballinsoldier ballinsoldier is offline
Car: F30 335i
Default 05-21-2013, 08:08 PM
Bill
Is stage 2 much of an upgrade over stage 1 if you have no other mods?
tredirtyfive tredirtyfive is offline
Car: 335 E92
Default 05-21-2013, 10:16 PM
Yes...very worthwhile.
Car: 2011 F10
Default 05-22-2013, 09:07 AM
I would have to say that it feels very good. I can't say there is a big difference since I don't push it very often, but I would say that all round it is worth while.
Bill
pnosker pnosker is offline
Default 05-23-2013, 08:18 PM
What's the difference between this firmware and the 3/1 firmware? Is there a changelog?
Default 05-23-2013, 09:19 PM
No change logs for F10/F30 stuff at the moment. But various minor changes.
thirtyfiver thirtyfiver is offline
Send a message via AIM to thirtyfiver
Default 05-26-2013, 08:00 PM
Just follow the install PDF in the first post.
I will never buy a stage II until somebody makes a DETAILED install video. I watched the JB4 stage III video 10 times before I bought one.
Car: 335 E92
Default 05-26-2013, 08:27 PM
If you mean the N54...the N55 JB4 install is truly a piece of cake in comparison.
Default 05-26-2013, 08:30 PM
One option is to hire an experienced tuner shop to install it for you. Once it's out of BETA we'll make a video but frankly we want those more experienced with installs / tuning in general handling the BETA stuff.
lazycat lazycat is offline
Car: f30 335i
Default 05-29-2013, 03:24 AM
Hi Terry, for f30 335i, what is the difference between JB3 stage 1 on ** and set at +4.5 psi vs JB4 stage 2 map 2, in terms of power and smoothness? Thanks!
anelson524 anelson524 is offline
Car: F30 335i
Default 05-29-2013, 09:40 AM
Nothing like going to update your firmware and finding out you've been in map 1 for who knows how long.
Default 05-29-2013, 10:30 AM
The JB4 has direct solenoid control so makes a lot more power up top. And also offers lag reduction. But I have not done an F30 S1 vs S2 same day dyno comparison test. I'll have to do that one of these days.
mikew2069 mikew2069 is offline
Car: F30 335
Default 05-29-2013, 04:09 PM
Yea, I was on Map 0 for a while and I had no idea. Since that happened, I no longer use my Volume Down on the steering wheel.
Default 05-31-2013, 08:33 AM
When the JB4 S2 is in map 0, is it truly 100% bypass or is it just running a stock like boost setting?
I plan to bring my F10 in for service and will likely get the car reprogrammed so i don't want the JB to cause any communication errors. I know the tech so him seeing the JB isn't a concern but don't want to prevent him from doing the update either.
Alan
Default 05-31-2013, 08:50 AM
It's a bypass.
Default 06-12-2013, 08:15 AM
Thanks Terry.
So the dealer should have no problems updating my cars software in bypass mode i assume?
Default 06-12-2013, 12:59 PM
Originally Posted by Alan L.
Thanks Terry.
Correct.
Car: F30 335i
Default 06-17-2013, 07:47 PM
Could someone take a pic of where it taps into the CAN or explain which wires are to be tapped into? The instructions state the black/blue and yellow wires, but there happen to be multiples of each. Are we just working with the two closest to the end? The instruction picture leaves a bit of room for doubt. It looks like the yellow wire on the end, but the blue/black wire looks like it could be either the one next to the end or the one further down.
PeterC4 PeterC4 is offline
Car: BMW 535
Default 06-23-2013, 03:46 PM
Bill
Bill, how long does the update take? You do it from the engine bay with the connection at the module I assume?
Car: 2011 F10
Default 06-23-2013, 04:19 PM
Peter:
I usually run the usb cable from the module under the hood into the cabin where I have it plugged into my pc. You must run it with the power on but the engine off. It takes about 8 to 10 minutes to do the update. I make sure I've just put the car into accessory mode before I start so I know there is enough time for the update to complete before the car shuts off. You can see the progress on your pc's screen.
Bill
Car: BMW 535
Default 06-23-2013, 04:25 PM
Thanks. So I'm using my iMac at home and I can't recognize the hex file, but I assume if I load the interface on my PC and the corresponding hex file, I should be able to use the interface to update the firmware...kinda scary, but I will read the instructions carefully. On another note, had 3 rims replaced under warranty (I have RIM/tire insurance) as they were out of round due to the stress caused by the stiff sidewalls on the run flats.
Car: 2011 F10
Default 06-23-2013, 04:28 PM
You should be alright as long as the interface works.
Car: BMW 535
Default 06-23-2013, 04:30 PM
LOL....that's the interface that says JB3 isn't it? I'm not really kidding.
Car: 2011 F10
Default 06-23-2013, 04:32 PM
The newer one does say JB4.
