lostsailor lostsailor is offline
Car: 2008 BMW 335i
Default jb4 - surging, some shadow codes - 02-09-2020, 02:57 PM
Hey, I am new to the jb4 and farily new to the n54. My car seems to surge and not be that smooth. I have made adjustments and it is better but still seems like something may be off. I have adjusted menu 10 to 2000 and I have menu 12 set to 2700. I have been moving menu 12 around and it does not seem to change things. I have also been getting the 2D2E Angle of throttle valve - intake pipe underpressure, correlation codes. I have some logs I will post in hopes that someone can take a look and see if anything seem out of the ordinary. Also wondering is the 2D2E could be a boost leak? I have a new O ring on the way for the charge pipe.
Default 02-10-2020, 03:50 PM
Hey,
First off, welcome!
A couple things- you’ll want to enable 6cyl timing under user adjustments
Second, with your log posted- did you have traction control on / partial on?
Don’t think you have a boost leak either, FF is low & your pretty close to target.
Are you using our BEF?
Car: 2008 BMW 335i
Default 02-10-2020, 08:07 PM
Thank you for the reply. I set the 6cyl timing and it seems to be running better.
I was not 100% sure about the traction control on that last logs so I turned it off and have made more logs.
Currently I am not running a BEF, at least not one that I did, but the car did have some mods done to it when I bought it. Is there a way for me to tell if the previous owner did a BEF?
Car: 2008 BMW 335i
Default 02-11-2020, 10:33 AM
While driving the car today, it was raining and I had traction control on and the car seemed to surge in the mid rpm range while accelerating. Traction control was not kicking in but the car was still surging and running a bit rough. On the way home i wanted to get another log to post. I turned off traction control and the car seemed to run way better. I will post that log as well but is traction control making the car surge even when it is not kicking in? Do I always need to have traction control off?
Default 02-11-2020, 12:15 PM
WHat are you menu 10 & 12 set to?
Car: 2008 BMW 335i
Default 02-11-2020, 12:31 PM
i have menu 10 set to 2000 and have been moving menu 12 around between 2400 and 2800. Right now menu 12 is set to 2800.
Default 02-11-2020, 01:35 PM
What’s your pedal set to as wel, menu 11
Car: 2008 BMW 335i
Default 02-11-2020, 01:53 PM
Menu 11 is set to 0
Car: 2008 BMW 335i
Default 02-13-2020, 05:33 PM
The car is still surging at times and seems to be running rough at times. Other times it seems fine. Not really sure what is happening but I am going to upload a screen shot of codes and some more logs in hopes of figuring out what is going on.
I am also going to do a BEF tonight and see if that helps.
Default 02-13-2020, 07:48 PM
The BEF is going to help smooth things out tremendously.
Flash the appropriate flash for your mods / fuel.
Let’s look after that.
Car: 2008 BMW 335i
Default 02-14-2020, 08:43 PM
Got the BEF done and have some logs to share.
I have one log of mid range rpm running in 4th gear where to car not running smoothly and it seems like I may have caught it in the logs. I am very new to all of this so forgive me it this does not add up, but in the logs you can see the the pedal is fairly stable but the throttle is all over the place. When this is happening the car does not feel smooth.
Also when the car is warming up, once it hits the 160 oil temp but before it at normal operating temp the car seems to surge. Once I get to normal operating temp it seems to smooth out a bit. I may have a lot of that but will have to dig through them to find the right one.
Car: 2008 BMW 335i
Default 02-15-2020, 04:25 PM
Car is still running a bit rough. Here are some new logs. I hope this helps, starting to feel a bit frustrated.
Car: 2008 BMW 335i
Default 02-15-2020, 08:16 PM
Here is another log where I got kicked to map4. This pull seemed smooth until I got kicked to map4. Any help on figuring out what is going on will be greatly appreciated.
Default 02-16-2020, 11:07 AM
Looks like your last safety was overboost.
You can bump your boost safety up to 20
Still surging?
Car: 2008 BMW 335i
Default 02-16-2020, 01:21 PM
I will set the boost safety to 20.
It is still surging, but not all the time. Seems sporadic and worse after the car hits 160 oil temp but before it hits normal operating temp.
I am also still trying to figure out what is happening at mid RPM range when the car feels like it is misfiring. When I look at that log the pedal is fairly steady but the throttle is all over the place. When I graph that, the throttle jumping up and down is how it feels when I am driving it. That log is from my post on 02-14-2020 10:43 PM
Car: 2008 BMW 335i
Default 02-18-2020, 11:40 AM
Here is another example of the car running really rough at times. Can someone people graph this log and help me resolve this issue? I am guessing it is not normal for the pedal to be fairly consistent while the throttle is all over the place.
