Jet3three Jet3three is offline
Car: BMW F82 M4 ZCP
Default Error code: air mass meter 2, signal electrical fault - 07-22-2018, 06:09 AM
Hi guys, I just installed jb4 today, there are couple of code here, and I donít think is normal. Anyone has any idea please? I am appreciate!!
Itís on map 1
102A11 Air mass meter 2, signal: electrical fault
102901 Air mass 2, Plausibility: Air mess too high
102E11 no description found
And I switched to map 0, still got one code:
2013 BMW F30 328i
2016 BMW F82 M4 ZCP
Car: BMW F82 M4 ZCP
Default 07-22-2018, 06:12 AM
It’s F82 M4 ZCP by the way
And the flap controls seems can’t hold the settings, I don’t know why
2013 BMW F30 328i
2016 BMW F82 M4 ZCP
Default 07-22-2018, 09:08 AM
Did you knock your MAF connection loose or try to attach anything to it?
Car: BMW F82 M4 ZCP
Default 07-22-2018, 04:37 PM
I don’t think so. Anyway I could test that? Any suggestions please?
Once I disconnect maf connection, codes are gone. For now I can’t run any map but put on map 0,with maf disconnect
2013 BMW F30 328i
2016 BMW F82 M4 ZCP
Car: BMW F82 M4 ZCP
Default 07-22-2018, 10:17 PM
I donít quite understand
What are those codes mean?
2013 BMW F30 328i
2016 BMW F82 M4 ZCP
Car: BMW F82 M4 ZCP
Default 07-23-2018, 04:41 PM
Hi Terry, do you mean there’s possible problem with the connector?
2013 BMW F30 328i
2016 BMW F82 M4 ZCP
Default 07-24-2018, 03:00 PM
Originally Posted by Jet3three
Hi Terry, do you mean thereís possible problem with the connector?
Have you tried unplugging and replugging in your MAFs on both intakes?
gbk99's Avatar
gbk99 gbk99 is offline
Car: 2008 e92
Default 07-19-2019, 08:46 PM
Hello. My friend is having the exact same issue as initially described. Same codes. Just installed JB4 on his M4. Is there a solution for this? Any troubleshooting steps? Please help, thanks.
farbmw's Avatar
farbmw farbmw is offline
Car: 2011 335is
Default 08-14-2019, 03:23 PM
Bump, for solution!
