Ztuck45 Ztuck45 is offline
Car: 2010 335i M-Sport
Default Single turbo boost control issue - 06-30-2018, 01:08 PM
Hey guys. Iíve recently developed a boost issue that i canít figure out.
Last week i autocrossed my car, ran it on map 1 (17psi) and afterwards when i changes to a different map my car hasnít been able to get past 16-17psi. My wastegate pressure is 17psi so it led me to believe thereís something wrong with either the jb4 or my Mac solenoid.
I did a smoke test to check for boost leaks and it was all good. The Mac solenoid also clicks when i put 12v to it.
I also checked the voltage on each solenoid plug, both read 12v dc. I saw a video Bms put on their YouTube channel and their solenoid plugs read 6 and 12v. The voltage also drops on one side to 0 at wot.
Iíve been running this setup with no issues for almost 10k miles so Iím not sure what the problem is.
Any input would be appreciated!
Default 07-01-2018, 01:37 PM
Who knows on those. There isn't a set way to diagnose issues with boost not building over WG spring. Normally the solenoid isn't getting power though. Normally if solenoid clicks at part throttle ign on, engine off, then the solenoid, JB4, and related electrical are all working. You may have to set DWP = 0 to do that test though, haven't done it in awhile with the current firmware.
Default 07-02-2018, 04:01 PM
I have done the part throttle test, i can hear the clicking at half throttle.
I ordered a new jb4 from BMS to see if thatíll help, i doubt it will but Iím at a loss here, i have no idea whatís going on
Default 07-02-2018, 04:08 PM
I'd try a new solenoid, first. On the JB4 end if something failed you'd just need the control board not a new harness. The boards are $175.
Default 07-02-2018, 04:34 PM
Okay Iíll try a new solenoid as well. If both donít work Iíll start taking stuff apart
Default 07-02-2018, 10:10 PM
New Mac should be about $50 bucks off bms site
http://www.burgertuning.com/N54_JB4_upgrades.html
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 07-03-2018, 05:58 AM
Already ordered thanks!
Default Update - 07-13-2018, 02:25 PM
I replaced the jb4 board and Mac solenoid, no change.
I can hear the gates open if i put compressed air to them.
Both solenoid plugs read 12v on each side. Is this normal? In a old bms video on YouTube they measured 12v/6v on each side (see pictures)
dmikhael619 dmikhael619 is offline
Car: 2008 e92 335i
Default 06-21-2019, 07:28 PM
Sorry to resurrect an old thread but did you fix this, I also put in a new solenoid, new jb4 board, and I still get 12v on both wires controlling the mac solenoid. Not going past spring pressure also tested the mac solenoid with a battery and it clicks. Any help is appreciated
Default 06-23-2019, 07:53 AM
Yes i did! It turned out the top wastegate fitting loosened up causing it to not go over spring pressure. I put locktite on the fitting and tightened it back up and itís been fine since.
