steve30's Avatar
steve30 steve30 is offline
Car: E36 M3, E90 335i
Default mac solenoid issue - 07-28-2017, 07:55 PM
My mac solenoid seems to not be working properly on my ST setup. I turn the ignition on and give it 100% throttle and it doesn't click. If i keep the throttle around 40-60% you can hear the solenoid constantly click but once you pass a certain point it shuts off. I'm assuming this may be the issue that is resulting in slow spool.. The car is now hitting full boost at around 5000 rpm which is way too late.. its a precision 6266 gen2 so it should be hitting boost at around 3300-3500 rpm. It just feels very laggy..
steve30's Avatar
Default 07-29-2017, 11:23 AM
Measured the voltage on the connectors and its getting 12v on both sides. Its supposed to be 12v and 6v right?
phil1320 phil1320 is offline
Car: 2011 335is
Default 07-29-2017, 12:10 PM
Sounds like it is tune related but I could be wrong. MAC solenoids are new to me. But I will say between two different tuners, one tune I could hear the MAC solenoid and even feel it inside of the cab. The other tune, it was quiet as could be.
2011 335is DCT | DocRace 6266 | HPF Gen 2 3.5" Exhaust | Stett Stage 2 Oil Cooler | CSF Aluminum Radiator | AD-E 1000 HP IC | Fuel-It Stage 3 Pump | AD-E PI | MFactory LSD | MFactory Axles | YCW Coilovers | SSP Spec R | M4 Flywheel
steve30's Avatar
Default 07-29-2017, 12:48 PM
I've got the JB4 single turbo backend flash and the special jb4 firmware for the mac solenoid loaded up so I don't see the tune being an issue..
Car: 2011 335is
Default 07-29-2017, 01:07 PM
Right. Just saying, in my experience, one tune the MAC solenoid was clearly audible whereas the other was not. But yes, 5000 rpm for full boost is stupid slow for a gen 2 6266. I hit full boost fairly quick.
Car: 2011 335is
Default 07-29-2017, 01:16 PM
I'm hitting full boost around 3-3700 RPM from a 5th gear "load" pull mashing the pedal around 2500 rpm.
Default 07-29-2017, 01:36 PM
If it clicks at half throttle solenoid is working fine. If you need tuning help post a log of the issue.
steve30's Avatar
Default 07-29-2017, 02:06 PM
I understand but with the car off and just ignition on I measured the voltages on the solenoid harness and it's getting 12v on both pins on both connectors. According to your YouTube video it should be at 12 and 6v. Regardless, I will get a 3rd and 4th gear log posted up within the next couple days.
Default 07-29-2017, 05:24 PM
12v on both sides is normal when gas pedal isn't pressed.
steve30's Avatar
Default 07-31-2017, 06:03 PM
Here is a log
Wastegate spring is 10 lbs
added map3 log as well.
Default 07-31-2017, 10:43 PM
Boost creep on map 1 is interesting.
On map 3, you need to lower your FF to 40 and let it learn from there.
Quite a few timing corrections at that boost level. More octane will be needed to run 25psi, but lets see how 20psi looks once you lower FF.
steve30's Avatar
Default 08-01-2017, 09:09 AM
Ok i'll set the ff to 40 and log another pull tonight. I'm running the car on 94 octane so it should be good enough for map4 right?
on the user settings i have the duty bias and fuel bias all set to 0. is that ok?
DWP:60
PID: 25
Auto Shift: 60
FF/WA: 100
Fuel Open Loop: 40
I pulled these settings off of a thread Terry had made specific to the ST setups.
FEDE/E92 FEDE/E92 is offline
Default 08-01-2017, 10:01 AM
If I'm not mistaken according st set up page duty bias is 50... FF way lower than 100
steve30's Avatar
Default 08-01-2017, 10:58 AM
ok thanks, i'll make the adjustments and log again.
steve30's Avatar
Default 08-01-2017, 06:23 PM
New log with updated user settings
Default 08-01-2017, 07:01 PM
Duty biases should be set to 0 for ST firmware and FF to 40 to start.
You still have an overboost issue despite FF and DB's being zero. What is your spring pressure? Looks like you have a hardware setup issue.
steve30's Avatar
Default 08-01-2017, 07:15 PM
Wastegate spring is 10 lbs. pre turbo exhaust leak would cause issues like this?
Default 08-01-2017, 07:57 PM
Are the single setup note wrong? This is copy and paste from the notes
6) With single turbo firmware FF and dutybias are saved on a per map basis. As a starting point for any given map set dutybias all to 50 (level), FF relatively low, and let it learn itself up. Since there is such a wide variation of turbos, manifolds, etc, used we anticipate each setup will require some fine tuning for perfect boost control. Note to enable duty cycle by map settings dutybias 1500rpm must always be set to 50. This tells the JB4 to use your dutybias 2000rpm+ settings.
Default 08-01-2017, 08:08 PM
For duty bias 0 and 50 are the same.
Default 08-02-2017, 12:21 PM
With the single turbo firmware as well? I know those numbers become pretty random as it adapts.
Originally Posted by boldfacemeat
where do i get firm ware for the mac solenoid?
http://www.n54tech.com/forums/showthread.php?t=20406
Chris98m3 Chris98m3 is offline
Car: 335i n54
Default 08-28-2017, 04:39 PM
Did u fix it ?
DamnDatsun's Avatar
DamnDatsun DamnDatsun is offline
Car: 2010 135i msport
Default 08-17-2019, 04:55 PM
Originally Posted by Chris98m3
Did u fix it ?
X2. I'm literally having the same issues with the Mac solenoid. Clicking at haha throttle, but not at full throttle. Can't seem to hit map 3 Target
steve30's Avatar
Default 08-18-2019, 07:28 AM
its fixed now but I removed JB4 and went with dme only tune
