birdmanshepard birdmanshepard is offline
Car: 2011 335I
Default 335I N55 36BE Error - 07-10-2017, 02:08 PM
Gentlemen,
I've tried to research this code but can't quite figure the cause or solution. I've recently updated my JB4 firmware to the latest firmware and have since been receiving two error codes:
36BE
2C90
I could be wrong but I'm assuming 2C90 is coming because I've got an upgraded chargepipe. It is a tuner code.
It is the 36BE that I can't figure out. I've read that it could be a DME issue. Has anyone been able to figure out what this code is and the solution for it?
I did get an engine malfunction warning two days ago around the same time I noticed this code, but it could have been due to 94f weather here in SoCal. Again, I could be wrong.
I've been speaking with BMS on this but we couldn't come with anything. Any input would be highly appreciated, thank you.
My setup:
- 2011 335i E92 MSport
- PS2 Turbo, FMIC, **, CP, CAI,
- MHD BEF (e85 map) + JB4 (map5)
afranke afranke is offline
Car: 2013 ActiveHybrid 3
Default 07-10-2017, 03:59 PM
If the PDF linked here is correct: http://www.1addicts.com/forums/showthread.php?t=591928
"The fault is recognized when the DME has not been encoded."
Potential problem source(s): DME not encoded
Fix: Encode DME
Have you been messing with Esys or the Bimmercode app (or anything similar) lately?
Default 07-10-2017, 04:00 PM
Also, the second Google result is this thread: http://www.n54tech.com/forums/showthread.php?t=46581
Default 07-10-2017, 04:02 PM
Or this thread about it not being an issue and happening after a flash: https://www.northamericanmotoring.co...y-here-90.html
Did you even Google it? I literally searched "bmw code 36BE" and there's tons of stuff.
Car: 2011 335I
Default 07-10-2017, 04:36 PM
Yep, there are a couple of threads out there. However, none of which solve the issue. Just trial and error. Nothing that worked for me so far.
Default 07-10-2017, 04:37 PM
What have you tried?
Weehe Weehe is offline
Default 07-10-2017, 08:59 PM
I flashed ppk and had this code pop up. Went back to stock it went away. Flashed MHD BEF and it popped up again. It has not caused any problems for me.
Car: 2011 335I
Default 07-10-2017, 11:46 PM
Thanks Weehe. Based on code description it appears to be some sort of coding conflict. I've got mhd as well and I'm trying to figure out if it's causing any issues in the backend, or if it's bogging down performance in anyway. Although, in my case it doesn't seem like it's causing any issues so far.
Some people are reporting performance issues, and some say it's harmless. It does appear to be BEF specific. Will continue to dig into this further.
keyap keyap is offline
Car: N55 135i
Default 07-22-2017, 01:00 PM
This is not caused by the JB4, it is sometimes triggered when the DME/DDE module is flashed and, from what I understand, it's where the programming differs to what is expected. This would point more towards MHD although I'd be surprised if MHD has caused this.
An example of what can trigger it would be where people use WinKFP to update or change their ROM, which I guessing is what Weehe is referring to.
Either flashing the DME back to how it was pre the code or by using NCSExpert to flash the 62 or 63BMO module based on VO or with a blank MAN should remove it. However, SOME CAUTION MAY BE NEEDED as I'm not sure what other impact this may have for someone using a MHD BEF?
[B]
sicknick530's Avatar
sicknick530 sicknick530 is offline
Car: 2011 BMW e92 n55
Default 09-17-2019, 08:35 PM
JB4 with mhd bef gave me the same code on my ‘11 335i msport. I know that for sure. Looking for a Sol.
Car: guess...
Default 12-11-2019, 08:14 AM
Add me to the list of unfortunate souls with 36BE now after flashing MHD and using JB4+BEF. I thought the 2EF2 one was annoying...; I'm surprised no one's found a solution for this yet. It looks like it's been a known issue for years.
Default 12-14-2019, 07:59 PM
The code just stopped popping up eventually for me
tboudre's Avatar
tboudre tboudre is offline
Car: 2011 BMW 335xi E90 N55
Default 05-27-2020, 12:03 PM
By changing my battery, I bricked the FRM. It was a known issue & covered under warranty for a couple more months (It's 10 years from manufacture date or 156k miles now). Something's not right with the JB4, but it's turned off. When I got it back from the dealer it had the 36BE code - DME, Encoding: Vehicle Identification Code is missing. I've also got 29E0 and 2C6F - to do with the charge air sensor. I think I have to ring out the wires maybe there's a short.
But while it was there, they flashed the entire DME from the factory software: 7620170 to Current software: 8684970. Perhaps they forgot to code the VIN after the flash.
On one hand that was a *WIN* because it would supposedly fix the issue with the Alpina TCU flash RPM dropping to zero on manual shifts. On the other hand by them flashing my DME I lost ALL coding & my Alpina TCU flash.
The good news is that I should be able to put everything back to like it was with my phone rather than scrounging for a copy of the BMW software for my computer as I did years ago (I actually had someone code the TCU for me).
2011 335i xDrive ///M-Sport LeMans Blue Navigation iDrive 15% Tint N55 E90 - BMS Intake, Le Mans Blue Grilles, Le Mans Blue Rear Diffuser, Alpina B3 TCU Flash, Misc Coding, Matte Black Badge, Gloss Black Exhaust Tips, Blue Calipers*, VRSF Charge Pipe*, Cyba Scoops*, JB4 ISO 5.5, Sport Oil Cooler Valve, FlexFuel (Fuel Rail Pressure) Wires, GoFastBits DV+, Ethanol Content Sensor - No problems up to E70 fuel mix
* Painted 7251 Cobalt Blue Metallic - Matches LeMans Blue
