Jdf87 Jdf87 is offline
Car: M2
Default N54 Doc Race Single Turbo first log - 10-14-2016, 08:21 PM
First log jb4/mhd backend single turbo. 6266 turbo getting kicked out of map 1 to map 0 after the pull. any info appreciated. I don't really know if i should hold it wide open the way it is to do a full log.
Default 10-16-2016, 01:12 PM
You're overboosting. What is your WG spring rated for?
Car: M2
Default 10-16-2016, 03:43 PM
WG spring is 14lb pound setup this was running map 1
Default 10-17-2016, 09:07 AM
Check your setup, on map 1 you should only be boosting to WG spring pressure. Set FF to 0 and try a log on map 2.
Car: M2
Default 10-24-2016, 06:31 PM
Heres another 2 logs on map 1 boost is more on target slightly over, had to adjust plugs on waste gate setup. Map 1 still
Default 10-24-2016, 10:29 PM
Fuel system is crashing.
Car: M2
Default 12-28-2016, 05:46 PM
Heres an updated log after waste gate springs change and fuel pump install any help is great thanks
Default 12-29-2016, 09:20 AM
Car: M2
Default 04-10-2017, 04:04 PM
Just installed fuel it stage 2 low pressure pump and reset fuel adaptations
Here's another log if anyone can help out
Default 04-10-2017, 10:02 PM
Check your driver's side filter, make sure there aren't any cracks. At least the HPFP isn't crashing but those pressures are still low. Could be a leak, bad LPFP sensor, or bad EKP.
Car: M2
Default 04-11-2017, 07:37 AM
Aright thanks I'll check into these things.
Default 04-11-2017, 11:18 AM
Car: M2
Default 04-17-2017, 08:05 PM
Here's 3 logs low pressure looks better after replaced lpfp sensor
Default 04-18-2017, 10:44 AM
Yes that looks better.
Car: M2
Default 04-18-2017, 10:47 AM
Any thing else to look for or am I good to switch to map 2 and 3 for some logs?
Default 04-18-2017, 11:10 AM
I'd do a couple on map 2 next.
Car: M2
Default 04-18-2017, 11:13 AM
Sounds good thanks !
Car: M2
Default 04-18-2017, 12:06 PM
Here's a log from map 2, got kicked down to map 1, I think because boost safety set to low? Should I raise it from 18 and try again
Default 04-19-2017, 12:10 AM
Overboost...FF is too high, lower it to 40. Bank to bank trim variation is pretty high.
Car: M2
Default 04-19-2017, 05:44 AM
Here's 2 more, FF learned down on its own when I went to go adjust it.
500hp500tq 500hp500tq is offline
Default 04-19-2017, 07:15 AM
How can you tell when HPFP is crashing? when it drops below 9?
Are you using any Meth or e85?
|2008 135i N54 | VRSF FBO| Motiv Port Injection | BMS PI Controller| AD-E ST Kit 6062 | JB4 G5 ISO 13.0 | BMS ST/MHD E85 Flash | 60% e70 | Fuel-It Stage3 LPFP | Spec2+/SMFW |3.5 TMAP | NLS
"stock"
Xshadows Xshadows is offline
Car: 2008 135i
Default 04-19-2017, 07:26 AM
Remove your rear O2 sensors. It's Pins 19 and 20 in the small black subconnector on the JB4. Then reset your adaptations and relog. This will help with bank to bank fuel trims.
DocRace Top Mount w/ Precision BB 6266 - JB4 G5 - BMS Pump flash - 650HP AD-E Intercooler - BERK Race Exhaust - Fuel-It Stage 2 Fuel pump - ER Chargepipe w/ TIAL BOV - 560whp @ 20psi on 93 octane only
Default Question - 04-19-2017, 07:51 AM
Is this something that normally needs to be done on all ST cars?
"stock"
Car: M2
Default 04-19-2017, 10:32 AM
Default ? - 04-19-2017, 10:34 AM
Are you saying this because his AFRs on bank1 and 2 are off?
or
Is this part of the Single Turbo setup.
"stock"
