(#526)
Zar Zar is offline
Car: Audi s3 2018
Default 08-30-2019, 06:59 AM
We need to see 3rd gear and 4th it safe to do.
Hi George,
Is this the file you need?
This was with 91 and planing running 94ron.
Thanks.
- Audi s3 2018 : CTS Turbo Hi flow cated down pipe, Hi flow K&N filter, JB4, for now.
- Audi TT 2008 : 3.2L, magnaflow exaust, Wrapped Deamon black, 19'' Niche Gamma.
-Touareg 3L TDI, 2013.
Default 08-30-2019, 09:35 AM
Originally Posted by Zar
Hi George,
Thanks.
Looks good enough in map 3 with 91.
When you get the 94 in email over more logs to george@burgertuning.com
Zar Zar is offline
Car: Audi s3 2018
Default 08-30-2019, 10:35 AM
Hi George,
Thank you for looking into this log.
Any suggestion on aditive to bump to 94 or 100 even?
I wont have time to burn the gas in my tank and replace with 94 before the race on monday.
Or have any suggestions on what could be change to optimise for 1/4 mile?
Default 08-30-2019, 02:26 PM
Hi George,
Map 3 is intended for 93/94 but your 91 log looks good so use that at the track if you not going to go with the 94. For a higher map we need to see logs.
Rekt Rekt is offline
Car: Golf R
Default 08-30-2019, 08:46 PM
https://drive.google.com/file/d/1wyw...w?usp=drivesdkHey George ran map2 on pure 91 no ethanol did a pull from 4k in four gear WOT. What do you think does it look good? Or should I bump up fuel grade?
Default 08-31-2019, 05:11 AM
Cant download it. email to george@burgertuning.com
Car: Golf R
Default 08-31-2019, 06:27 AM
Done, thank
You! Cheers
FeldiSan FeldiSan is offline
Car: VW Golf 7 R
Default 09-01-2019, 02:04 AM
Hi George,
Yesterday I noticed something on a long highway ride.
I drove in normal mode the whole time and had to let a drifter pass quickly and accelerate to the next gap that comes to the right. Remember, however, that the car has only series performance. It was not until I switched to race mode and gave it full throttle that JB4's performance was there.
Can it be that the activation threshold in normal mode is too low for the Jb4 to increase performance? After the acceleration process in race mode there was also more power in all other modes.
What could that be?
Car: VW Golf 7 R
Default 09-01-2019, 02:37 AM
Hi George,
I noticed something there yesterday. Yesterday in normal mode drove on the highway and have several times fully accelerated and always had a normal performance. It was only when I switched to Race Mode that the jb4 activated full power. After that I had the jb4 performance on all modes.
Is there possibly the threshold for the jb4 activation set too high or what could that be?
Drive map 5 with 102 Octan in Germany
Regards Mic
quattromaniac quattromaniac is offline
Car: 2018 Audi S3
Default 09-02-2019, 11:14 AM
I can't send any logs on the JB4 ios app.
Default 09-02-2019, 12:32 PM
Originally Posted by FeldiSan
Hi George,
Regards Mic
The modes shouldnt make a difference since the JB4 doesnt look at them.
Default 09-02-2019, 12:33 PM
You need to set up the default email client that the phone uses.
Car: VW Golf 7 R
Default 09-03-2019, 03:10 AM
But I have a devinitive problem there. In racemode he always has the power immediately but at least after an acceleration attempt she is there.
I have noticed with the map 5 several times now that he sometimes only after a lot of acceleration increases the performance.
Should I just flash the JB4 again?
Greetings Micha
Default 09-03-2019, 04:00 AM
Greetings Micha
If it is to aggressive ECU will pull power when using map 5.
Best bet is to log the two modes and email to george@burgertuning.com
Car: VW Golf 7 R
Default 09-13-2019, 06:50 AM
For a time didn't undestand what you mean. A light go's on in my head for a couple of times. You mean the VW Ecu not the jb4, right there?
Grearing Micha
Default 09-13-2019, 10:09 AM
Grearing Micha
Yes, if its set to aggressive the ECU will pull back the timing for safety purposes.
Car: VW Golf 7 R
Default 09-13-2019, 11:53 AM
For example, the jb4 requests 25 psi, but the VW Ecu only passes 19 to the waste gate. After several full accelerating changes that and the VW Ecu follows the jb4 requirement again. I can't see any problems with Timings or lean running.
I'm trying to capture that with a log at the moment to show you where it suddenly jumps and again follows the performance of the jb4.
Greetings Micha
Ceejayell Ceejayell is offline
Car: 2019 Leon Cupra
Default 09-17-2019, 04:04 AM
Trying to update via the mobile app, data cable and OTG adapter. After downloading the hex file linked in the thread, hitting flash, then update, I get this error "delete timed out. Firmware not erased on JB4". Any advice?
Default 09-17-2019, 05:44 AM
Try delete the hex file and download again and see what it does.
With data cable make sure its secure on the board tightened properly.
On bluetooth make sure you not connected to other devices at the same time and it helps to put phone close to JB4 on some phone models that have weaker bluetooth.
Berto371 Berto371 is offline
Car: 16 gli
Default 09-19-2019, 06:27 PM
When will the oil temp and trans temps be available
Default 09-20-2019, 03:53 PM
We will look to add the oil temp but cannot find the trans temp on the DME side of things at this stage.
Car: VW Golf 7 R
Default 09-21-2019, 04:36 AM
My engine check lamp goes on and the power is very low. The JB4 says, a code from "3C66 No Description Found". Can someone translate this code for me, to handle this problem?
greetings Micha
Tiguan_2_Berlin Tiguan_2_Berlin is offline
Car: Tiguan 2 AD1 2.0 TSI
Default Update failed - 09-21-2019, 04:49 AM
Hi, need help. Today i tried to update to 8.5.1 (file in this thread) by app via bluetooth kit. Something went wrong and now i have no connection to the app at all! Engine will not start. I had to unplug the OBD!
What can i do now? Thanks in advance.
Tiguan AD1 2017 162
Default 09-21-2019, 07:52 AM
greetings Micha
The fault is per below. Something to do with the engine cooling system. Seems a dealer visit will be needed for this as it might relate to the failing water pumps.
15462 :
Engine Coolant Bypass Valve Control Circuit/Open
P2681
Default 09-21-2019, 07:53 AM
Tiguan AD1 2017 162
If its a 162kw/220ps version then try load the firmware again making sure you not connected to any other bluetooth device.
If its the lower power version it is the wrong firmware and you need to load firmware from Gen3B section.
