Iflickr.als Iflickr.als is offline
Car: Bmw
Default 135i n55 2011 throttle issue - 09-04-2016, 11:47 AM
Hello guys
I experience problem with my car last year the car showed code 28A0 throttle valve angle pressure
And the car was not working good when cold start give CEL and when i drive the car like jerking in the fixed speed normal driving , changes throttle valve body works fine , now less than a year the problem come back again , same codes
My car is fbo pure stage 1 jb4 cobb bms flash , auto clear code is off
BMW 135i 2011 N55 Pure Stage 1 ETS Fmic , BMS Downp1p3 , BMS Intake , BMS OCC , BMS meth kit cm7 , jb4 ISO + MHD .
Default 09-05-2016, 01:52 PM
JB4 isn't connected to MAF correct? Possible boost leak or intake leak?
Car: Bmw
Default 09-06-2016, 01:30 AM
It was working good , suddenly this issue come from time to time , ill check the intake and leaks
But is there any way to disable the MAF , cause i think mos of the problems comes from the MAF
Default 09-06-2016, 11:08 AM
Not on the E-series N55, only the F-series N55.
Any leak post MAF will cause idling and low RPM drivability issues as well. The throttlebody error could be a post turbo leak.
Car: Bmw
Default 09-07-2016, 02:01 AM
if there is no leaks only MAF problem , it will cause same issues ?
Default 09-07-2016, 08:26 AM
Both would have similar symptoms.
Car: Bmw
Default 10-08-2016, 02:53 AM
Here is the log after cleaning the MAF sensor and changed the HPFP there was issue with it , plus the car was running rich before i replace the hpfp and clean the maf sensor , this log without BACK END FLASH i guess .
Review and feedback me please
Bump
Default 10-08-2016, 09:42 AM
Log looks totally normal.
keyap keyap is offline
Car: N55 135i
Default 10-08-2016, 10:59 AM
You could do with some more octane
[SIZE="2"]UK 2011 - E82- 135i - N55 - DCT
[B]
Car: Bmw
Default 10-08-2016, 10:21 PM
Ill upload again the BEF and log with meth , so glad to see my beast back
Car: N55 135i
Default 10-09-2016, 08:28 AM
Time to have some fun.
No more
Lots of
[B]
Car: Bmw
Default 10-13-2016, 04:00 PM
This two logs after installing BEF but I received code 36BE , i dont know why
Default 10-14-2016, 06:11 AM
Not sure what that code is...what's the description?
Logs look pretty normal, some timing events but not too bad given the IAT's are a little high.
Car: Bmw
Default 10-14-2016, 03:09 PM
No description code
Default 10-16-2016, 01:03 PM
You'll need to research it and let us know what the code is.
Car: N55 135i
Default 10-16-2016, 02:50 PM
Strange?
36BE Code.pdf
[B]
Car: Bmw
Default 10-17-2016, 02:44 AM
Originally Posted by keyap
yes this is exactly what I found , and its really strange I tried to uninstall the BEF and install it back again same thing .
Default 10-17-2016, 07:13 PM
What if you return the flash to stock?
sicknick530's Avatar
sicknick530 sicknick530 is offline
Car: 2011 BMW e92 n55
Default 09-17-2019, 08:39 PM
Solution?
