Wrecker 426's Avatar
Wrecker 426 Wrecker 426 is offline
Car: 335xi
Default 2step wonít limit but tries - 08-10-2019, 02:32 PM
So I put the 2 step relay in and when I put it in first clutch all the way in and floor it, you can tell it trying to limit the engine however it powers through then gives me all sorts of codes. If itís not in first or clutch isnít in will rev fine, it only pops all of these codes once I try and use it, more or less want NLs. Running E85 with E85 BEF, and a 7th injector from fuel it
07' 335xi, VTT Stage 2, Meth CM10, Stage 2 LPFP pri, walbro 525 LPFP 2nd, JB4 E85 BEF, VRSF exhaust, Phoenix Race IC, MMP AL inlets, VTT AL Outlet, PR Coils, Fuel-IT CPI 950cc, Manual swapped, SMF Spec Twin disk
Car: 335xi
Default 08-11-2019, 06:48 AM
Any help
