Jdf87 Jdf87 is offline
Car: M2
Default 04-19-2017, 10:46 AM
Originally Posted by 500hp500tq
Are you saying this because his AFRs on bank1 and 2 are off?
or
Is this part of the Single Turbo setup.
I'm asking the same question as you are, i didn't know this is something to do for single turbo setup.
500hp500tq 500hp500tq is offline
Default +1 - 04-19-2017, 11:44 AM
oh, lol.....
would be good info. if so; never hear of anyone needing to do it before.
|2008 135i N54 | VRSF FBO| Motiv Port Injection | BMS PI Controller| AD-E ST Kit 6062 | JB4 G5 ISO 13.0 | BMS ST/MHD E85 Flash | 60% e70 | Fuel-It Stage3 LPFP | Spec2+/SMFW |3.5 TMAP | NLS
"stock"
Default 04-19-2017, 09:42 PM
It's standard ST protocol to remove the rear O2 sensor wires. Last two logs look pretty good.
Xshadows Xshadows is offline
Car: 2008 135i
Default 04-20-2017, 06:30 AM
It's common practice on single turbo cars.
DocRace Top Mount w/ Precision BB 6266 - JB4 G5 - BMS Pump flash - 650HP AD-E Intercooler - BERK Race Exhaust - Fuel-It Stage 2 Fuel pump - ER Chargepipe w/ TIAL BOV - 560whp @ 20psi on 93 octane only
Car: M2
Default 04-20-2017, 10:46 AM
Okay will do this tonight, after pull the pins and reset, then I'll be left with a cel for o2 correct?
Default 04-20-2017, 09:10 PM
Not with code clearing...
Car: 2008 135i
Default 04-21-2017, 07:28 AM
No codes if you're using the JB4 backend flash. Terry has disabled those codes in the flash.
Car: M2
Default 05-02-2017, 06:16 PM
Here's a new log, reset adaptations and pulled the o2 wires..
Car: 2008 135i
Default 05-03-2017, 06:19 AM
Turn on 6 cylinder timing logging.
Default 05-03-2017, 11:09 AM
Log looks normal but agreed...turn on 6-cyl timing.
Car: M2
Default 05-03-2017, 12:00 PM
Here's log timing enabled, after this can I switch to map 3 to pull some logs?
Default 05-04-2017, 09:12 AM
Looks pretty clean, just a few minor timing corrections.
Car: M2
Default 05-04-2017, 09:14 PM
Here's a log from map 3..
Default 05-05-2017, 01:23 PM
No change...looks about the same.
Car: M2
Default 08-18-2017, 12:30 PM
Couple new logs, car kicks down from map 3 on some pulls any ideas
Default 08-20-2017, 04:59 PM
Interesting....bank 1 AFR's go lean but bank 2 trims switch to open loop.
That issue needs to be resolved.
Car: M2
Default 08-22-2017, 03:44 PM
New logs changed bank 1 o2 sensor.
Default 08-22-2017, 09:09 PM
Did you reset your adaptions? It's looking better. Bank 2 is still a little unstable but not too bad.
Car: M2
Default 08-23-2017, 06:07 AM
Nope adaptations have not been reset will do that and repost.
Default 08-23-2017, 09:39 AM
Car: M2
Default 08-24-2017, 09:20 PM
Finally updated, reset adaptions.
Default 08-25-2017, 08:35 AM
Looks pretty good but you continue to get minor timing corrections on multiple cylinders. More octane will likely help with that.
Car: M2
Default 08-25-2017, 08:47 AM
So just to help me understand better, He can run low e85 mix on the pump back end flash like 30% or less? Also that can be done on map 1 2 or 3 and it will adjust as long as fueling is up to to it?
Default 08-25-2017, 08:55 AM
Pretty much.
Car: M2
Default New run - 07-07-2019, 10:49 AM
Update on car, just got Brand new Index 12 injectors, and updated jb4/mhd firmware, and 6 new stock coils just want to see how log looks
