(#276)
VF-1J VF-1J is offline
Car: 2015 M3 F80
Default 07-18-2020, 09:32 AM
What's the difference with the JB4_S55_PS2_E85_14_2 vs JB4_S55_E85_IGN_14_2 and the JB4_S55_V2_E85_IGN_13_T3?
How do these compare to what I have in my car now?
I have PS2 in my car and have been running JB4_S55_E85_IGN_13_T2. Runs great, but always open to newer updates.
@m3ndeezee
F80/S55 | JB4 w/MHD | BMS Intakes | BMS WMI w/Stealth Tank | BMS Intercooler | PureTurbos PS2 | D***P**** | NGK 2-steps cooler | E45-E85 | Remus Exhaust
Default 07-18-2020, 01:12 PM
You can open them in tuner pro to look at the differences in detail. But the V2 labeled maps are for the newer vehicles ECU that can't flash the normal ones.
ChrisMavM6 ChrisMavM6 is offline
Car: M6 F06
Default 08-03-2020, 08:00 AM
Are these maps available for the S63TU engine cars? M6 F06 here, Thank you!
E90 M335i E90 M335i is offline
Car: 09 E90 335i Msport
Default 08-14-2020, 08:19 PM
same question
GOGRN GOGRN is offline
Car: 2011 E90 335xi Msport
Default 08-18-2020, 11:07 PM
So far, MHD is still in BETA for the S63Tu. I dont believe there are any BEF maps or otherwise yet.
Jimmyjames Jimmyjames is offline
Car: F80
Default 08-19-2020, 07:23 PM
Hi terry do you make custom bef?
iDrift iDrift is offline
Car: 2018 ZCP M3 6 Speed
Default 09-03-2020, 02:01 PM
Hi Terry,
Iíve been running the latest e85 ign map and itís very inconsistent, sometimes the car pulls super hard and sometimes it misfires and hesitates bad at higher rpm, here is a short log on map 7, it does the same in map 2 and map 5. I have changed spark plugs to ngk 2 step colder gapped to .018. Please advise.
Default 09-03-2020, 11:12 PM
Here are a couple more logs for reference, itís like the first WOT pull after start up is very lean, then it fixes itself in a couple of runs. All input appreciated
CICCO's Avatar
CICCO CICCO is offline
Car: M3 f80
Default 09-20-2020, 12:34 AM
Is the S55_PS2_E85_14_2 file specifically for pure stage 2 turbos and Full e85 stock fuel system???
Bader_Al_F82's Avatar
Bader_Al_F82 Bader_Al_F82 is offline
Car: 2015 BMW M4
Default JB4 Map 8 + MHD BEF - 09-23-2020, 03:06 PM
Good day Terry,
I've upped the pre-intercooler nozzles from dual BM5 to Dual BM7, and from a single BM5 to a Single BM10 on the J-pipe.
Boost Additive is set at 68, Signal Scaling set at 60, Min Flow Boost set at 12 PSI. Running 100% Methanol on RON 98.
I was wondering since I have added much more methanol, is it safe for me to use (JB4_S55_RACE_14_IGN) flash instead of (JB4_S55_RACE_14) ?
Weather temp was 102f and about 40-55% humidity.
from my understanding, 26-28 PSI is the maximum I can run the stock turbos at.
Attached below is a log of a couple runs, seems like my Trims are quite high, is that because of the hot and humid weather?
I do not really know how (Trim) works.
any additional advice regarding my meth setup/settings would be appreciated.
Regards,
Bader.
