(#1376)
tc535i tc535i is offline
Car: 95 M3, 01 330i, 07 335i
Default 08-31-2015, 09:12 AM
Originally Posted by Riceball777
How do I make sure my duty bias and afr are both zeroed out?
gotta use the app or windows interface
dmbfan1717's Avatar
dmbfan1717 dmbfan1717 is offline
Default 08-31-2015, 09:30 AM
Added new logs to DataZap..any help is appreciated!
http://***********/u/seekup17
Thx!
2011 335is
MHD flash
AFE intakes
AFE c@tless dp's
3" custom full exhaust
BMS charge pipe
07 335i Coupe Monaco Blue- RIP
JB4 G5 Board
Helix Intercooler
ER Charge Pipe
Forge Dv's
BMS DCI
DP's
BMS Trunk Mount 2.2g Meth Kit
BMS 4 LED Angel Eyes
n54 power's Avatar
n54 power n54 power is offline
Default 09-01-2015, 05:08 PM
Hi Terry
my car is ijeos MT;
Can i from 6/6/15 JB4_MHD_IJE0S_ST_E85 flash???? or should I from 5/7/15 JB4_MHD_IJE0S_ST_E85_MT.flash
thanks
ba114's Avatar
ba114 ba114 is offline
Car: 135i 6MT
Default 09-01-2015, 05:16 PM
Originally Posted by n54 power
Hi Terry
my car is ijeos MT;
thanks
If you arent single turbo, neither. the "ST" is for single turbo
n54 power's Avatar
Default 09-01-2015, 05:18 PM
Yes ST is for single turbo
Grip Grip's Avatar
Grip Grip Grip Grip is offline
Default 09-01-2015, 05:55 PM
On the next MHD update it would be great to see MPH as an option.
2009 335i XDrive (wife's)
Sold - '11 335is - N54 - DCT
Sold - '07 335i - 11.8 @ 120
Sold - '08 128i (wife's)
CLTEURO CLTEURO is offline
Car: 08 335i 6MT Coupe
Default 09-01-2015, 09:08 PM
I'm so happy the latest update got high/low monitors near the gauges. A nice touch, now, to allow custom gauges! haha
2008 E92 335i Coupe 6MT | Apex Arc-8 18x9.5 | MHD: Stage 2 93oct | CP-e Charge Pipe | Active Autowerke BOV | DCI | VRSF C*****S D*******S | VRSF 5" FMIC | Cyba Air Scoops | BMW PE Mod
climax_E92 climax_E92 is offline
Default 09-03-2015, 05:51 PM
Hey guys I have an 07 335i. What is the appropriate number setting to allow 6 cylinder timing? I use to have it on 4 and now it doesn't say whether to use 4 or 6. Just says 0-6.. thanks you
djlilmikeny1 djlilmikeny1 is offline
Car: 2011 BMW 335is
Default 09-04-2015, 05:54 AM
Hey Terry, would you have a more aggressive jb4 backend flash for the 335is? I have ******* *** and run only 93.
Thanks,
Mike.
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 09-04-2015, 06:51 AM
4
Eristoff's Avatar
Eristoff Eristoff is offline
Car: BMW e92 335i n54 coupe (2006)
Default 09-04-2015, 08:04 AM
I have some questions. I have european car. SO do the MHD support european cars with the backend? Will it cause the errors that the BB flash does? DO i need to edit it via tunerpro to my bin and specific MHD XDF file, like we do with the BB backend flash?
Thanks in advance
E92 335i coupe 10/2006 @ BMS DCI ; JB4 G5 ISO ; AR Design 3" DP´s ; APEX EC7 18" wheels ; BMS OCC ; BEF ; MMP inlets & outlets ; RB PCV valve ; Vibrant ressonators
Nordic335IM3's Avatar
Nordic335IM3 Nordic335IM3 is offline
Car: BMW 335I N54
Default 09-04-2015, 09:22 AM
Thanks in advance
I have a Euro 2007 335i and just flashed the MHD pump flash with cold start option, and the log is much better now, had timing problem before.. ;-)
Texsquirrel's Avatar
Texsquirrel Texsquirrel is offline
Car: 2009 BMW 135i
Default 09-04-2015, 10:19 AM
My eBay green circuit board cable fails.
So are these cables guaranteed to work?
http://bimmersoftware.com/Cables
I want to flash, not fart around trying to find a working cable.
2009 BMW 135i | Alpinweiß | 6AT | MHD/BMS JB4 G5 ISO32.8 | JB4 MHD 3/15/17 E85 Backend Flash | BMS Anti-Lag | Fuel-It Stage 2/ES-1/JB4 integration Kit | AD Engineering Port Injection | PR (Turbo-side) Inlets | PR Ignition System | VRSF DP | aFe Exhaust | Cobb FMIC | ER CP | Tial BOV | N20 TMAP | BMS Oil Cooler Valve | JB4 Mobile | 100% E85 | H&R Swaybars F&R | BA Diff Lock | StopTech D&S Rotors F&R | Cool Carbon Pads | Michelin PSS
yournamehere90 yournamehere90 is offline
Car: 2008 535i
Default 09-04-2015, 12:56 PM
Yes, it is guaranteed. Have you tried using mprog to orgasm your cable before returning it? It has worked for some. It didn't work with my white board but it's worth trying.
Car: BMW 335I N54
Default 09-04-2015, 01:35 PM
I have a white board cable and it works with MHD flash on my cheapo android tablet.. but BMW carly wont let me do anything, eventhough it detects the usb connetion and so on.. but if I try carly with my samsung cell phone then it works ( but the plug on the phone is loose so its not stable..)
1. What can I do with "mprog" to my white board cable ?
2. you think A green board cable would work with BMW carly ?
Car: 2009 BMW 135i
Default 09-04-2015, 01:49 PM
I'm new to android.
I'll have to google that to know what you're asking.
I'll give it a try, but I don't want to mess with it much if buying a different cable will solve it.
Not worth the hassle to nickel and dime my mods.
If my HP Slate would give me a Linux command prompt, I'd be in heaven.
So far though I'm not very impressed.
My iPad is far better than the HP Slate.
Or course the Slate was just $80.
But it is NOT iPad quality.
Car: 2008 535i
Default 09-05-2015, 07:02 AM
I'm new to android.
I meant program in my above post, not orgasm. You can buy a different came which is what I'm doing, but if you've already got one in your hands out eliminates the wait if you can fix it. I hope I can provide a link to another forum thread fill of relevant info.
http://www.boostaddict.com/showthrea...9-Amazon-cable
mave198 mave198 is offline
Car: 07 335i e90
Default 09-05-2015, 10:05 AM
Orgasm, Came...........porn much??
LOL
Car: 2008 535i
Default 09-05-2015, 03:33 PM
LOL
I really need to read what I type
wardy335i's Avatar
wardy335i wardy335i is offline
Car: E93 335i
Default 09-05-2015, 10:55 PM
I had everything ready to go last night.
Sitting in the car with 5 different OBD>USB cables.
none worked!
Can only think because they were Vag Com and normal OBD cables..
I should be getting a Dcan OBD-USB cable today will this work?
i have a 2008 E93
2008 E93 335i M-Sport 6AT
MHD Stage 1 // Dual Foam Cones // Avant Garde M359 //
Powerflex Black Edition Polys // Ferodo DS2500s // VRSF 3" *** // TBC
London
Litebulb Litebulb is offline
Car: '09 SGM E88 135i
Default 09-06-2015, 01:19 AM
I brought this one and I haven't had any issues:
http://www.ebay.com/itm/For-BMW-INPA...item3a9ff3a8c4
none worked!
i have a 2008 E93
wardy335i's Avatar
Car: E93 335i
Default 09-06-2015, 06:49 AM
http://www.ebay.com/itm/171874618534...%3AMEBIDX%3AIT
I purchased this one earlier today.
They look the same cable just different companeis
London
swat's Avatar
swat swat is offline
Car: 07 335i
Default 09-06-2015, 09:49 AM
Should've went with the onestopelectronics one for peace of mind...
Stacked BMS Flash & JB4, Dinan CAI, ER Chargepipe, 7" VRSF Intercooler, VRSF DP's, ER Sport Oil Cooler w/Steel lines, Gunmetal 19" VMR V710's, 335is clutch, Wavetrac LSD, M3 FSB, M3 Front & Rear Control arms, M3 RSB, M3 rear subframe bushings, M3 guide rods
wardy335i's Avatar
Car: E93 335i
Default 09-06-2015, 09:57 AM
Im in the UK id have to wait a week or 2 for that to ship over.
London
Bullitt1841's Avatar
Default 09-06-2015, 10:01 AM
Originally Posted by Bullitt1841
Is anybody else still noticing the linearity difference of the throttle behavior between E85 and PUMP flashes? E85 is more responsive and PUMP is more linear. It is very hard to dial in the new JB4 Menu 11 Throttle Sensitivity adjustment, in my opinion.
IJE0S
6/6/15
Bueller? Bueller?
