(#3826)
Budi Budi is offline
Car: 2007 335i 6MT
Default 05-29-2019, 11:36 AM
Originally Posted by LuSt4Boost
I don't think you did any damage. I had the same issue. Unfortunately, the BMS cables are cheaply made. I ended up buying a Twisted Tuning cable and finished the flash that way once it came in.
Just wanted to update, the bimmergeeks cable came in and I flashed it with no problems. It's really worth buying the right cable rather than a cheap amazon one, shipping was pretty quick considering it was over memorial day weekend too
mb443 mb443 is offline
Car: 08 E90 335i
Default 06-03-2019, 08:32 AM
When running stacked JB4 and flash tunes, what is the result when running the JB4 on map 0? Obviously the BMS BEFs are designed to complement JB4 for the best improvements over stock, is there any performance benefit from the BMS flash when the JB4 is disabled/removed?
2008 E90 335i 6MT Sport A22, no iDrive
FBO | JB4 G5 ISO + Pump BEF | Turbosmart DualPort DVs | 335is/550i clutch | RE trans mounts, shift bushings | Phoenix CP | BMS DCI, OCC, diff lockdown, etc | ZHP knob | Shiftek DSSR | PS AS3+ on stock 162s
TimboBlackkers TimboBlackkers is offline
Car: '08 135i MT
Default 06-03-2019, 08:24 PM
I did this once (long story).
The car drove fine on E85 BEF with no JB4. Just had a super low boost target.
I couldn't log it as there was no JB4 installed at the time, I don't have MHD logging module or anything similar.
I think if you were lerning to custom tune at home then the JB4 BEF would probably be a good starting point
Jay2094 Jay2094 is offline
Car: 2009 BMW 335XI
Default Misfires at high speed in 6th gear - 06-05-2019, 07:05 PM
I am experiencing some mild bucking/misfires. I did some logs at the track but I don't really know how to read them or what to look for. Anyone know what could be wrong?
MHD BEF PUMP
TurboLabs Hyrbid Turbos
7 inch vrsf intercooler
Vrsf down pipe
Vrsf Charge Pipe
Magnaflow full exhaust
BMS Dual cone intake
Maniac0908 Maniac0908 is offline
Car: 07 BMW 335xi JB4 G5 DP DCI BOV
Default 06-10-2019, 01:49 PM
Hello, I have a 2012 335is. I read the thread terry made about the 335is and itís timing and stuff. Iím here to get a bef for it. Which one should I use?
2007 335XI SEDAN // ACF/VM 6266 SINGLE TURBO// MMP PORT INJECTION // VRSF CP W/ TIAL BOV // XHP 6AT FLASH // MOTIV TUNED // BMS OCC // VRSF EXHAUST // DIY STAGE 3 LPFP// VRSF FMIC //
landshark92 landshark92 is offline
Car: 2013 335is
Default 06-15-2019, 08:23 PM
I am trying to flash back to stock from the latest "pump" BEF through the BimmerBoost 1.3.3.1 software with a BavTech cable. When I write my stock flash that I originally saved, the car won't start. The ECU goes into recovery mode. It seemed to write okay and take the full 17 or 18 minutes but the car won't start.
I have to flash the BEF to get my car to run and it runs okay like that. I tried the stock flash a second time and it still didn't work.
Do I have to do a force write with the stock flash or am I doing something wrong?
2013 335is N54 / 6MT / JB4 G5 ISO "E85" BEF map 5 / Fuel: E40 / Phoenix Racing charge pipe / Diff lockdown / 70K miles
I'm addicted to meth but E85 gets me by...
RhynoBoiler's Avatar
RhynoBoiler RhynoBoiler is offline
Chi-Town Cruiser
Car: 2011 BMW 335is
Default 06-16-2019, 10:37 AM
What happens if the BEF is completed, but the JB4 was still set to map 5?
All aboard the Lakeshore Drive Express!
iturbo's Avatar
iturbo iturbo is offline
Car: 2009 335i e92
Default 06-16-2019, 03:12 PM
when flashing via the mhd app, do any of the mhd settting options interfere with the jb4 settings?
for example, the mhd has a wastegate position setting, and jb4 does as well. also there is a cold start option, but i think the jb4 bef's include this already right?
what settings can we select that will not intefere with the jb4 setting? using the mhd to flash a bms bef
2009 335i e92 n54 | FBO | JB4 | e85 flash |
Car: '08 135i MT
Default 06-16-2019, 04:59 PM
Nothing, I've done this a few times.
I think there was a firmware update in the JB4 that automatically switches to MAP0 when you plug the cable in.
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 06-20-2019, 12:58 PM
I have a new set of dpís that Iím going to install in the next few weeks. Iím also going to do a mhd bef and was wondering if I should wait to do the bef until I install the dpís? Main reason is the cel that I donít want. Iím wondering if I can go back in and take care of that after if I go ahead and do the bef now?
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 06-20-2019, 01:18 PM
Yes sure you can do the BEF anytime
Rule77's Avatar
Car: 08 E90 335i
Default 06-20-2019, 01:23 PM
Can I go back into mhd and change the setting for dpís?
Car: '08 135i MT
Default 06-20-2019, 06:32 PM
Yes very easily,
A reflash will only take a few minutes
Rule77's Avatar
Car: 08 E90 335i
Default 06-20-2019, 09:46 PM
Originally Posted by TimboBlackkers
Yes very easily,
Thank you!
suni_335's Avatar
suni_335 suni_335 is offline
Car: BMW 335i N54 2007
Default 06-21-2019, 07:02 AM
Are these backend flash maps disabling the CEL appearing after installing dawnpipes. ?
Haynpunch's Avatar
Car: 07 E90 335i
Default 06-21-2019, 01:13 PM
no
that has been removed. if you search hard enough you can find the solution
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Rule77's Avatar
Car: 08 E90 335i
Default 06-22-2019, 06:51 PM
Originally Posted by Haynpunch
no
So there isnít option anymore for dpís?
What do I do?
suni_335's Avatar
Default 06-24-2019, 01:42 AM
What do I do?
Not really sure.. I asked the same question in facebook n54/55 group and they told me only the US backend flash isn't working anymore for hiding the CEL. The europe one is doing it. For example I'm going to use the : JB4_I8A0S_PUMP instead of JB4_I8A0S_PUMP_USA. Can somebody approve that's true?
Rule77's Avatar
Car: 08 E90 335i
Default 06-24-2019, 06:08 AM
Yes Iíve been told the same.
jmb85 jmb85 is offline
Car: 335i e92
Default 06-24-2019, 10:06 AM
no
Can you maybe send me a PM? Thanks!
suni_335's Avatar
Default 06-25-2019, 03:16 AM
Can anyone approve that? Terry for example or someone else who is familiar? I'm located in Europe, Bulgaria and will be installing ********* this week. After that I'll install the backend flash (JB4_I8A0S_PUMP.bin **NOT the USA version**) to the DME and now I'm wondering together with several other guys if this flash will prevent the O2 CEL from appearing.
yellowfin's Avatar
yellowfin yellowfin is offline
Car: 335xi - jb4 - DCI
Default MHD JB4 license boost ceiling - 06-25-2019, 08:21 PM
I am trying to match JB4 and BEF boost targets up to 21-22 psi, and later maybe go menu 4/4. However, I canít seem to get the DME_BT above 18.7 (boost ceiling, load target, load-torque tables via TunerPro). Now it dawns on me that MHD may not write those numbers and maintain, e.g., the 1.28 bar ceiling no matter whatís in my custom bin.
Iím fine with upgrading to full flash with mboost option, if thatís what it takes, but before, Iíd like to understand how it works. If I buy the full license with mboost, should I use ďcustom flashĒ instead of ďbackendĒ? This way, can I write my bin 1:1 to the DME without any overriding by the MHD flasher?
2007 335xi (I8A0S kline) -- VTT GC lites + inlets + outlets -- Fuel-it stg 2 lpfp -- CPE catted **, FMIC, CP -- Tial BOV -- BMS DCI + OCC
JB4 + BMS/custom bef (E50)
Car: '08 135i MT
Default 06-25-2019, 08:53 PM
Probably need to email MHD about that.
I'd be interested to know if MHD is editing the Boost target in the BEF when using their cheaper BEF option rather than the custom flasher option.
suni_335's Avatar
Default 06-26-2019, 02:20 AM
So I flashed the DME with JB4 BEF via MHD yesterday. Everything went well, I've set the menu 4 to option 2 and running map 1 currently (Boost is hitting 15psi which is the target) . Can't say if there's any difference in the car.. even I can feel it's more sluggish or IDK.. Something to mention is I'm with OEM cats and at the end of the week dawnpipes will be installed but yesterday when I was flashing in the MHD additional options as burble and etc I didn't select that I'm using OEM cats but instead I left it unchecked which means it thinks I'm with dawnpipes. Could that be a problem, make the car sluggish or something else? I also have rattle and in order to prevent it JB4 menu 10 is set to 800, menu 11 to 3000 and menu 12 to 1600. That I think are the best settings which I could achieve cruising yesterday. Any opinions will be appreciated , thank you!
Rule77's Avatar
Car: 08 E90 335i
Default 06-26-2019, 05:34 PM
Have you figured out what the problem was?
08 E90 335i - MONTEGO BLUE - JB4/MHD E85 BEF
BMS DCI - BMS OCC - NRW CARBON COWL FILTERS
MMP CHARGEPIPE - TIAL BOV - VRSF 7.5Ē RACE FMIC
VRSF DPís - VRSF INLETS - VRSF OUTLETS
BMS PEDAL TUNER - RB PCV VALVE - 3.5 BAR TMAP
NGK 97506 @.022 - PFS STAGE 2 LPFP - H&R SPRINGS
SPOOL PERFORMANCE ETHANOL ANALYZER
MISHIMOTO 25 ROW OIL COOLER
BMS SPORT OIL COOLER VALVE - NRW V1 PADDLES
19Ē 666m WHEELS - HANKOOK VENTUS V12 EVO 2ís
