(#3626)
135i-pp 135i-pp is offline
Car: BMW E82 135i N54 6-MT
Default 07-08-2018, 03:54 AM
Hello From Germany,
I run in my 135i N54 JB4+BEF Racegasmap (MAP5) with Aral 102.
Can you please take a Look on my Log ?
BMS DCI
Chargepipe
Turbosmart Dual BOV
Mishimoto FMIC
Fully ******* with BMW PE exhaust
https://***********/u/rabr34/4gang?log=0&data=1-4
Haynpunch's Avatar
Car: 07 E90 335i
Default 07-08-2018, 04:25 AM
Originally Posted by 135i-pp
Hello From Germany,
BMS DCI
Chargepipe
Turbosmart Dual BOV
Mishimoto FMIC
Wrong Section....Support is located here
http://www.n54tech.com/forums/forumdisplay.php?f=35
Also....post the csv file
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Thumbs up 07-08-2018, 04:36 AM
Sorry, And Thank you
enrita's Avatar
enrita enrita is offline
Default 07-09-2018, 12:34 AM
Hello From Germany,
BMS DCI
Chargepipe
Turbosmart Dual BOV
Mishimoto FMIC
I would not use the race bef with aral 102. Thats not proper racegas.
07 335i AT - MOTIV 750 - MHD BMS E85 Flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 07-21-2018, 07:53 AM
Terry, came up in another thread and I was thinking about it. Usually in the tables you have the IAT correction tables, one with a factor and one with values, based on IAT and WTT. In the BMS BEF you hard code those for use with the 2-step/anti-lag, but does that mean there is no correction made, or is it done elsewhere like in the JB4? If we aren't using those features is there any benefit to putting the original correction tables back in? The Pump flash already runs slightly lower timing so maybe it isn't needed. Thanks
Ripley's Avatar
Ripley Ripley is offline
Car: 335i N54
Default 07-21-2018, 09:05 AM
A question about RACE BEF. I usually use it with map 3+meth and all works fine.
Can I safely use it also with map 4, 5 and 6 with 91/93 octane fuel or I need reflash PUMP BEF every time?
Black Sapphire E92 335i AT: VTT GC 2.0 - VTT inlets/outlet - VRSF 7'' FMIC - VRSF 3'' d p s - JB4 G5 w/ FSB - AEM meth - Fuel-It stage 2 LPFP - BMS DCI - Phoenix Racing CP - TIAL BOV - NGK 5992 - KW V3 - Dinan camber plates - Brembo 8 pot - Pagid RST3 - Mishimoto 25 row oil cooler - Quaife LSD - M3 rear bar - xHP stage 3
Default 07-21-2018, 12:58 PM
The RACE flash can be used on pump fuel, map1 is probably the best bet to start unless you know the fuel is really good. Then map2 or map5. If the fuel is really bad, map4.
Ripley's Avatar
Car: 335i N54
Default 07-23-2018, 01:20 AM
Nice! Thanks for the info
Roma_335i Roma_335i is offline
Default 07-26-2018, 12:00 PM
Hey need help, for single turbo do i go to flash a backend map or do i go to flash a custom map? Cant find this information anywhere.
NashtyN54 NashtyN54 is offline
Car: 2007 335 e92 st 6466 6mt
Default 07-26-2018, 10:10 PM
If your running a jb4, using mhd select, Flash a backend map... then locate your downloaded maps file on your device... choose your dme type.... select the file based on your setup/ fuel
Hazynighthawk Hazynighthawk is offline
Default 08-01-2018, 06:27 PM
So what map for ije0s st e85 ? All it has is the ts map no regular ball bearing one
Default 08-01-2018, 07:58 PM
What turbo kit do you have? TS just means twin scroll. Ball bearing or journal bearing turbo doesn't matter.
Default 08-01-2018, 08:19 PM
Vie kit. I have a Garrett 6465 ball bearing turbo. Iím saying there isnt a choice for just non ts turbo .
Default 08-02-2018, 10:22 AM
VIE is TS, that is the one you want.
TS means Twin Scroll. Your turbo and turbo kit is twin scroll
Default 08-02-2018, 10:56 AM
Is it ? I didnít know that the GTw was twin scroll lol
Default 08-02-2018, 12:59 PM
Yes lol, take a look at your turbo exhaust housing.
Default 08-03-2018, 09:12 AM
It only has one hole.
veer90's Avatar
veer90 veer90 is offline
Car: '09 335i sedan 6MT
Default 08-06-2018, 06:24 AM
Which map do I use if I want to run pump gas on single turbo? IJE0S_PUMP.bin or IJE0S_ST.bin?
Default 08-06-2018, 11:15 AM
That's very odd. Your manifold is twin scroll but your exhaust housing is single scroll? I'd check with VIE to make sure he sent you the correct housing. AFAIK they should have ATP Twin scroll housing for your application.
IJE0S_ST.bin
e92coupe23's Avatar
e92coupe23 e92coupe23 is offline
Car: e92 335i
Default 08-07-2018, 06:07 AM
new to BEF so looking for a little help on which BEF to load and map to run / e85 mixture adivce. I have an MSD81 DME so i should need 1JE0S file, but should i run the pump, race or e85 file?
Supporting mods: full exhaust, FMIC, turbo inlets, charge pipe, stage 2 lpfp, stock turbos
Meth kit is on the way.
Default 08-07-2018, 10:11 AM
Start with the pump gas if you are using 91/93 octane.
Once you get the meth kit you can use the race flash.
e92coupe23's Avatar
Car: e92 335i
Default 08-07-2018, 10:23 AM
Thanks Payam. I have the ability to run e85 with my stage 2 bucketless fuel pump. Currently testing out E30 now and can I can go higher if needed. Is it not safe to do so or should i wait until I install my meth kit?
CharliesN54's Avatar
CharliesN54 CharliesN54 is offline
Car: 2008 335xi
Default 08-09-2018, 07:23 AM
Would it be possible to get a INAOS BEF for my e89 Z4 thats single turbo running pump gas? The current maps under INAOS dont provide that option. or if theres already one out there can someone point me in the right direction as i've search quite a bit and cant find anything.
Thanks in advance.
Single Turbo Z4 that's constantly broken
Default 08-09-2018, 09:19 AM
You can go higher maybe about e50 blend if you're using an e85 flash.
Thanks in advance.
Email Terry, he should be able to make it.
Terry@burgertuning.com
