(#2776)
Default 06-28-2011, 03:37 PM
Probably not possible.
hworang00 hworang00 is offline
Car: '08 535i
Default 06-28-2011, 03:45 PM
Hey Terry, just a quick question: Does the max cool mode somehow cause the battery to pull a higher than average amount of charge from the battery after the car is shut off? Because about 3 times since I've turned on max cool mode the car given me the discharge error, and nothing has changed except that. Then I heard today at the BMW place that the fan being constantly on could cause that (overheard another conversation about a car's battery constantly dying). LMK if this could be a problem or if it's something else I should look at.
2008 535i || JB4 || BMS DCI || Custom Mandrel Bend Borla Exhaust || AR Design C@tless *** || More to come!
Default 06-28-2011, 03:54 PM
Haven't come across any issues like that with it.
Car: '08 535i
Default 06-28-2011, 04:08 PM
Alright, cool thanks! :D
bmwowner619 bmwowner619 is offline
Car: e92 335i
Default 06-29-2011, 12:18 AM
Hey Terry, i am going to upload the software tomorrow, as for maxcool when is the proper time to use it?
2008e90 2008e90 is offline
Car: 08 e90 sedan
Default 06-29-2011, 10:15 AM
I'm not Terry but I believe he said you could leave it on all the time
Eric SS's Avatar
Eric SS Eric SS is offline
Car: 2013 335i M Sport
Default 06-29-2011, 10:17 AM
I just installed the new firmware yesterday (had the February Firmware prior) and It feels about the same to me (the jerkiness) but it's not bad. I don't mind it at all. I wonder if it's because of the DCT? At Any rate, Terry, I emailed you a few logs yesterday but I'm not sure if they are going to do you any good. I couldn't get past 3rd gear due to where I was and for some reason the Map 0 log didn't record RPM's or a bunch of other prameters. Outside temp was 106 degrees. The Map 1 log showed IAT's in the 140's. Seems high to me but nothing I can do about it without Meth or FMIC I assume. Only other mod I have besides JB4 is the DCI
EddyH EddyH is offline
Default 06-29-2011, 03:29 PM
I've been running map 5 for a week or so now and it's really good, spiking at around 17psi and generally holding 15psi. Only other mods are AR DP's and Supersprint mufflers, running on Tesco 99ron (UK).
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 06-29-2011, 03:40 PM
Map 0 logs will not show any CAN supplied information because in Map 0 allmost all CAN functions are turned off. If you want to log stock values then use Map 4 at least for the time being.
Yes it's HOT here in Phoenix!!! Your IAT should be 20 degrees over ambient while on the highway and up to 170 or so at the end of a long pull without meth.
Eric SS's Avatar
Default 06-29-2011, 03:52 PM
Thanks. I already can't wait for summer to be over. This N54 feels like a slug compared to when it was in the 60-80's.
Terry let me know about the user error on the data logging so I know for next time.
Throttle's Avatar
Throttle Throttle is offline
Car: 08' 335xi
Default 06-29-2011, 04:05 PM
Originally Posted by GSXR_MARKY
Try a windows update!
Installed a bunch of updates.....still says USB device is unknown and I can't connect.
Terry, do you know of anything else I can try?
Default 06-29-2011, 04:43 PM
Can't offer much help there. Maybe try a local computer whiz or another laptop. You just install the FTDI driver package in our install folder and it works like a charm every time.
Throttle's Avatar
Car: 08' 335xi
Default 06-29-2011, 05:14 PM
Is there any chance it could be the cable? It's been folded up under the hood and tucked in the passenger side fender since I installed it a few months ago.
triumph's Avatar
triumph triumph is offline
MY TR6 needs Bimmer power
Car: 07 335i coupé cabriolet
Default USB cable - 06-29-2011, 05:37 PM
Try this right click on my computer go to Manage.
Click on device manager.
With it open plug in you cable.
If you do not see a new tab called port your computer is not recognizing your cable or the drivers.
If nothing shows up look in the event viewer at application or system and see if you have any errors.
I am using a netbook with XP with no problems.
Throttle's Avatar
Car: 08' 335xi
Default 06-29-2011, 06:11 PM
Yeah, the port doesn't show up since it says USB Device not Recognized. I tried another computer and have the same issue. I really think it's the cable now.
triumph's Avatar
Default Its the cable - 06-29-2011, 06:21 PM
Yes it is the cable of the connection to the JB4 is loose.
GbreeE90 GbreeE90 is offline
Default 06-30-2011, 03:47 PM
Terry, I think I remember you saying you didnt have plans to have a jb4 program for mac, but is there any chance?
Default 06-30-2011, 04:41 PM
I may do it some day. But busy with other fun stuff for us.
haus_07's Avatar
haus_07 haus_07 is offline
pursuit of performance
Car: 2007 E90 335i
Default 06-30-2011, 06:03 PM
I LOVE when Terry says things like this!!! It means lots more of this!!! -->
2007 E90 335i // sparkling graphite metallic // sport package // logic 7 // light grey leather w/aluminium trim // m-sport steering wheel // HID foglight conversion // LED angle eye upgrade // M3 style CF hood w/vents // matte black kindney's // AFE dual cone intake // ********* DP's // custom SS exhaust w/ high-flow cats, H-pipe, single magnaflow muffler // 265/35/18 - 225/40/18 Yokohama s-drive's wrapped around TSW machined lip wheels w/car colored centers // Burger Tuning JB4
indy99gpgt indy99gpgt is offline
Engineer
Car: 2008 BSM 335i Coupe
Default 07-01-2011, 06:25 AM
You can create a windows virtual machine on your mac laptop with vmware fusion. I have a linux laptop and use a virtual windows machine to connect to my jb4. Just an idea.
2008 BSM 335i coupe-jb4.BMS intake.meth
1999 Pontiac Grand Prix-10.5PSI.PRJ LL Cam.supporting mods
Jayock's Avatar
Jayock Jayock is offline
Enginerd
Car: 2009 135i
Default 07-01-2011, 11:00 AM
Or Oracle's VirtualBox, which is free. Thats what I use on both my Mac and Linux machines.
Byoung8's Avatar
Byoung8 Byoung8 is offline
Car: E90 335i 07
Default 07-01-2011, 01:57 PM
I love how easy it is to install/uninstall the JB4!
I just had the injector recall/campaign done and reinstalled JB4...so smooth so powerful!!
chilam1019 chilam1019 is offline
Car: 2009 E60 535i
Default 07-01-2011, 10:48 PM
i turned on the max cool.
The fan was running crazy and loud on the 5 ser.
Any solution Terry??
SlicktopTTZ's Avatar
Turbo Lover
Car: 300zx TT, 1M
Default 07-01-2011, 10:58 PM
Huh? It's supposed to.... hence the term "Max Cool".
Steveo's Avatar
Steveo Steveo is offline
Humid 535i
Car: 535i
Default 07-02-2011, 10:32 AM
Yep. That means it's working.
