ERIKGARCIA's Avatar
ERIKGARCIA ERIKGARCIA is offline
Car: M135i
Unhappy Damaged Meth Pump? - 08-31-2018, 06:51 PM
My port injection sometimes works and then no, I do not find the fault.
Had the check valve before the PI when disconnecting the hose pulled a lot of hot air pressure is normal?
I already remove the check valve because the PI does not need it, but that pressure is returned to the tank?
https://youtu.be/WKk40osBFfk
Sorry for my english
M135i EWG 2014
[B]Pure Turbo Stage 2 | Port Injection FI | Exhaust |Chargepipe ER | Intercooler Phoenix | Intake BMS | LPFP Stage 2 FI | TMAP N20 3.5 BAR | Pure Inlet Highflow | GFB DV+ | JB4 | BEF Trebila
Hoosier
Your’s Erik🇲🇽
Default 09-04-2018, 08:30 AM
Sounds like you have a leak in the system
