(#76)
Jatco903 Jatco903 is offline
Car: w205
Default 04-11-2015, 07:22 PM
Hi Terry,
Do you have the installation manual for the tune? I just bought the w205 c300 stage 1 but there is no installation manual comes with it. Thanks
Default 04-11-2015, 08:40 PM
Yes I do, email me and I can send over the draft.
Default 04-17-2015, 05:02 PM
Added install guide to the first post and started to add some general info. I'll update it more as we go along.
timereaper timereaper is offline
Car: C400
Default 04-21-2015, 07:33 AM
Terry you need to update your install guide for C400. Sensor B confusion in the instructions.
B) Purple wire patch, 3 positions. Connects to camshaft sensor B.
C) Brown wire patch, 3 positions. Connect to TMAP sensor B.
snellepiet snellepiet is offline
Car: mercedes A250 Sport 4matic
Default 04-23-2015, 03:31 AM
Hello, i am new here in forum. I'm coming from Switzerland and i drive the A250 sport 4matic with Carlsson tuning, and we are very happy with it. Now my question, We want to order the C300 T modell and in Europe is only RWD. I always tune the cars that i have and i want the C300 tune also. The gasoline in Europe is 95/98 octane. Is the map for BMS TUNING also for 95/98 octane or only 98.
Default 04-23-2015, 08:45 AM
It's compatible with 95 RON. But, you'll make a little more power on 98 RON.
Thanks I'll look in to it. I could use some better C400 photos. Feel free to post or email them in if you have a car and camera handy.
blacksapphirez blacksapphirez is offline
Car: Mercedes
Default 04-23-2015, 11:39 AM
signed up just for the C400 updates! lol
who has dyno chart for the 400? and any long term reviews?
Car: Mercedes
Default 04-27-2015, 07:06 AM
Anyone??
Default 04-27-2015, 08:19 AM
No aware of any C400 dynos being posted. When the RWD models are more plentiful I expect you'll see a lot more data.
MikeGL MikeGL is offline
Car: 2015 GL450
Default 04-28-2015, 01:53 PM
Does the stage one tuning for the C400 boost it to GL450 OEM tuning numbers?
What I'm getting at, is there a tuning capability for a 2015 GL450, or is it maxed out OEM?
Thanks.
Great work btw.
jtmoney jtmoney is offline
Car: W205
Default New W205 - 05-12-2015, 05:49 PM
Yes, that's what I run on ours. Map 1 with 91.
Hello Terry, you've been talking about a devil sensor to enable stage 2. If I connect to the devil sensor can I run stage two with 93 pump gas instead of the mixture? My interest is to tune my C300 W205. Also will I need anything additional to run stage 2 other then connecting the devil sensor?
Default 05-12-2015, 07:07 PM
The devil sensor adds another 10-15whp if octane allows for it. 93 octane should be adequate.
Car: W205
Default 05-13-2015, 09:25 AM
So I only need the kit you sell and no additional mapping for max tuning?
Car: W205
Default 05-13-2015, 09:26 AM
Please contact me. I have additional info for you. jtinfuse@gmail.com
Default 05-13-2015, 09:27 AM
Right the kit can cover mild to wild on the tuning end.
Jeffjj Jeffjj is offline
Car: C400
Default 05-19-2015, 07:37 PM
I have had the tuner for the C400 for a couple of months now. and I am impressed can definitely feel the difference from stock, absolutely no issues so far, the Installation was very easy, (no devil wire on the 400) now I would LOVE to get a stage 2 tune
All-black All-black is offline
Car: C300
Default 05-20-2015, 09:11 AM
Hey terry is there a way to make boost stable to redline? Or is the engine flowing more then the turbo will be able to keep up with
Car: C400
Default 05-20-2015, 09:59 AM
Just purchased BMS USB cable for my stage1 for the C400. Wondering if 94 octane gas good enough to run map 2 safely?
Please shed some light on this Terry, or do I need some race gas/E85 mixed in to run it?
Also I didn't see clearly in detail how I would switch from Map 1 to Map 2 with the cable and laptop. Do I need a program?
Default 05-20-2015, 10:39 AM
You use the JB4 interface which I'll link in the first post. If it's Canadian 94 for some reason, that is awful gas. Similar to your 91. But it's easy to try out map 2 and see how it feels. I don't think the engine is at any risk with it even on a lower grade fuel. But you might not make as much power as say map 1 if the octane isn't up to the task.
Car: C300
Default 05-20-2015, 09:01 PM
hey terry i just installed the beta stage 1 kit and took it out for a drive, a short while into the drive the car threw a code for low pressure at the fuel rail any insight on this? also how should i go about reseting the check engine light
Default 05-20-2015, 09:03 PM
Could be a connection issue with the green patch or a map setting in the firmware. But, unless you are using E85, the fuel rail connector should not be installed. I'd remove that to start and the fault should clear itself after a few driving cycles. Or use any OBDII reader.
Car: C300
Default 05-20-2015, 09:04 PM
i do plan on running e85 i have a e85 station super close to me
Default 05-21-2015, 08:57 AM
If you need additional specific help you can either email tech support or throw up a post in the support section.
topgun32 topgun32 is offline
Car: MB
Default 05-25-2015, 10:42 PM
terry,
good news for this engine... respected tuner OE/Jeremy released a solid 91 oct tune with very good results at 16 psi. Over 100 Hp and TQ to the wheels. mbwolrd.org
currently Map 2 is at around 14 psi, any chance you create map 3 to boost to 16psi?
i can you data logs if you want to beta test.
2015 C400 3L Bi-Turbo
2012 E550 Coupe 4.7L Bi-Turbo
2008 Toyota Land Cruiser 5.7V8
