vtn86 vtn86 is offline
Car: 335i xDrive
Default Overboost Issue - 09-01-2018, 08:41 AM
Hi - Having some issues post JB4 install and BEF update. Cliff notes are as follows:
-JB4 (used) installed.
-Few issues right off the bat - bad settings/incorrect information laid out by previous owner, settings changed to default.
-ISO modification done - Initial Map 4 safety due to overboost (prior owner said it was done) after firmware update.
-Car seemed to run OK, but ran fairly lean around 3k rpm.
-Member on another forum mentioned a BEF would help as well as some additional octane. Given I didn't want to play with fuel mixtures until the baseline tune/BEF worked appropriately, I opted to do the BEF.
-BEF done, went for a test drive and hitting overboost safety again. I did set the JB4 to Menu4/Setting2
Latest log:
datazap (DOT) me/u/vtn86/log-1535690672?log=0&data=1-4
^modified the link above; appears I can't post links.
e90post forum post (couldn't figure out how to get a registration here until this week):
https://www.e90post.com/forums/showthread.php?t=1528091
Vehicle details:
335i xDrive
2011
N55
Bone stock besides charge pipe and JB4
Thanks in advance for any help that can be provided here.
Default 09-01-2018, 08:55 AM
Attach actual CSV here if you need help. But, if you are the same person who emailed me lower FF to 70 as I said in email and relog.
Car: 335i xDrive
Default 09-01-2018, 12:09 PM
Terry, same person. Apologies for the multiple posts. Won’t do it again. Thanks!
Default 09-01-2018, 12:56 PM
No worries.
