Go Back   N54Tech.com - International Turbo Racing Discussion > General > Regional Forums > California
Reload this Page Orange County BMW Service and Installs for Forum Members - N54/N55 cars
Thread Tools Search this Thread Display Modes
SoCal BMW Installs's Avatar
SoCal BMW Installs SoCal BMW Installs is offline
Helping Local Members
Car: 2007 BMW 335i E92 6MT
Default OC/LA/SD/IE - BMW Service & Installs (N20/N54/N55/N63/S55/S63 Cars) - 06-20-2014, 07:26 PM
WEBSITE: www.SoCalBMWInstalls.com
INSTAGRAM (Updated Photos!): #SoCal_BMW_Installs
Hey fellow N54tech members! My name is Rob and I live in the Anaheim/Yorba Linda area within Orange County. I am offering a variety of services for BMW cars in the Orange County area as a low cost alternative to local Dealerships, Mechanics, or Tuner Shops.
ABOUT ME:
I work from my home garage and I have all the appropriate BMW specific tools for the services and installations listed below. I have owned a 2007 BMW 335i Coupe (w/ Mods) for about 4 years now, and I have done all the maintenance and service myself. I am well versed with the N54 engine and can do anything in regards to the car with confidence. I have worked with many different car enthusiasts in the past, and even regular BMW owners just looking to get their car serviced or maintained. People have driven to me from distances such as Los Angeles, San Diego, Temecula, Riverside, San Bernardino, and of course all the major cities within Orange County.
CARS I USUALLY WORK ON:
-2006-2013 BMWs with the N54/N55 (Inline 6 Turbo): 135i, 135is, 1M, M235i, 335i, 335is, 335xi, 535i, 535xi, Z4-35i, X6-35i
-2006-2011 BMWs with the N52 engine (Inline 6 Non-Turbo): 128i, 325i, 328i, 330i, 528i, etc.
-2011-2015 BMWs with the N20 engine (Inline 4 Turbo): 228i, 320i, 328i, 420i, 428i, 520i, 528i
-2007-2015 BMWs with the N64 engine (V8 Twin Turbo): 550i, 650i, 750i/Li, X5-50i, X6-50i
-2010-2015 BMWs with the S63 engine (V8 Twin Turbo): M5, M6, X5M, X6M
-2014+ BMWs with the S55 engine (Inline 6 Twin Turbo): M3, M4
MAINTENANCE for N54/N55 Vehicles:
-Walnut Shell Blasting [$250 w/ OEM BMW Intake Manifold Gaskets included]
-Oil changes [$100 w/ provided OEM BMW TwinPower 5w30 Oil]
-Coolant Flush/Fluid Swap [$110 w/ OEM Coolant]
-Transmission Flush/Fluid Swap [$390 w/ OEM Transmission Fluid]
-Differential Flush/Fluid Swap [$140 w/ OEM Differential Fluid]
-Spark Plugs Replacement [$175 w/ provided OEM Spark Plugs]
-Coil-pack Installation [$240 w/ provided OEM Coil Packs]
-Injector Installation w/ Coding & Reprogramming [$275 for 1 Injector, $725 for 3 Injectors, $1400 for 6 Injectors]
-Vacuum Line Replacement [$200 w/ provided OEM Vacuum lines]
-Oil Filter Gasket [$400 w/ OEM parts provided]
-Oil Cooler Gasket & O-rings [$400 w/ OEM parts provided]
-Water Pump/Thermostat Replacements [$700 w/ Waterpump, $800 w/ Additional Thermostat]
-Intake / Cabin Air Filter [$50 w/ provided OEM Filter]
-Brake pads [$100 - Quote without parts*]
-Rotor replacement [$125 - Quote without parts*]
-Brake pads & Rotors [$140 - Quote without parts*]
-Clutch / Flywheel Replacement (Stock OEM, Aftermarket) [Please contact for accurate quote]
-Turbo Replacement/Installation (Stock OEM Twins, Upgrades Twins, Single) [Please contact for accurate quote]
INSTALLATIONS:
-Piggyback Tune Install [$50-75, USB Cable Installation Extra]: JB4 N54 (G5 or G4), JB4 N55, JB+, etc
-Flash Tunes Install [$50-75]: Please contact for questions
-Alpina Automatic Transmission Flash [$75]
-Intakes Install [$40-60]
-Intake Air Scoops [$40]
-Turbo Inlet Installs (RB, VTT, PR, VRSF, MMP, TTF, etc): Please contact for accurate quote
-Front Mount Intercooler (FMIC) [$100 for bolt-on FMIC, Additional for Lower Chargepipe or Cutting Applications, Please contact for custom FMIC]
-Down pipes (***) [$200 for 135i/335i, Other models may be more please contact]
-Catback Exhausts [$150]
-Chargepipes (CPs) and Blow-Off Valves (BOVs) [$65]
-Oil Catch Cans (OCC) [$75]
-Other Performance: Rob Beck PCV Valve (RB) [$50], Burger Motorsports (BMS) Clutch Stop [$20], Burger Motorsports (BMS) Low Temp Thermostat [$40], Burger Motorsports (BMS) Cowl Filters [$30], Shift Knob Installation [$20]
-Cosmetic Upgrades: Please contact for accurate quote*
-Rims: Mounting available [$80], Wheel Spacers Installation [$40/Pair, $70/Set of 4], (Installation of tires not available)
-Coding: Injectors [Please contact], Alpina Transmission Flash [$75], Many other options (Please contact for list)
-Battery [$50-100]: Installation [$100 w/ Coding Registration], BMW or non-BMW Battery Registration or Coding [$50]
-Suspension (OEM or Aftermarket) [Please contact for an accurate quote]: Springs, Struts, Coilovers
CONTACT INFORMATION: *Feel free to contact me for any quotes or questions you may have*
Email: Rob@SoCalBMWInstalls.com
Phone Number: Rob @ (714) 485-9794 (Please leave a voicemail OR Text)
Website: www.SoCalBMWInstalls.com
PRICING:
Please contact for anything not shown above. I can and am happy to accommodate for anything related to these cars. Thanks and look forward to meet local enthusiasts!
Installs, Maintenance & Walnut Blasting in Southern California
Contact: Rob - (714) 485-9794 (Leave a Voicemail OR Text)
Default 07-01-2014, 10:41 AM
The last week has been busy. Here is a short list of a few of the services I did this week, as well as a few customer cars I have worked on:
-Oil Level Sensor Replacement
-4x - JB4 installs
-4x - Walnut Shell Blastings
-2x - Alpina Flashes
-2x - Coding Sessions
Default 07-04-2014, 03:41 PM
Few more local members have come down for services including:
-Oil Filter Housing Gasket
-VANOS Solenoid Replacement
-Oil Change
DV135i's Avatar
DV135i DV135i is offline
Default 07-05-2014, 12:16 PM
Do you do clutch installs?
19T Turbos~3.5 Bar Tmap~S55 Eldor Coils~VRSF Relocated Inlets~VRSF Outlets~VTT Cast Valve Cover~VTT Dual CC~XClutch Twin Disk~BMS Short Shifter~VRSF Race Intercooler w/ HKS Racing SQV~3"AR DP's~3" Custom exhaust~Fuel-It Stage 2.5 Bucket~Turner Motorsport Billet Engine and Trans Mounts~JB4~DocVu Tuned
Default 07-05-2014, 12:18 PM
Unfortunately, I do not do clutch installs, engine swaps, or transmission swaps. My apologies. I can refer you to a few local shops that I have good relationships with that can help you though. Let me know.
Default 07-13-2014, 08:26 PM
I have been staying busy with services and installs this week. I was not able to take pictures of everything, but included is the ones I do have pictures of. Off the top of my head I can remember the following done during the last week:
-Custom Intercooler Install on 535xi Wagon
-Valve Cover Gasket Replacement
-Brake Fluid Flush
-Front Bumper Replacement
-Down pipes Install
-3x - Oil Change
-3x - Walnut Shell Blastings
skysurfer's Avatar
skysurfer skysurfer is offline
Car: 2008 535i
Default 07-14-2014, 12:55 PM
How was the install of the 7" FMIC on the 5'er?
How bad, hard was it really?
2008 BMW 535i
JB4 G5, BMS Pump Flash, ( Updated FW ), DCI,
Eisenmann Race Exhaust
ER CP
E60 DP
450 HP / 480 TQ ( when running AEM 320, 50% E85 )
https://www.youtube.com/watch?v=51z_sELokzk
Default 07-14-2014, 01:10 PM
It took a lot of cutting and removal of parts. Also it was necessary to relocate the Transmission cooler. To be honest, it wasn't particularly easy or hard. Just time consuming. If you have any questions feel free to reach out to me.
nguyenvn nguyenvn is offline
Car: 2007 335i E92
Default 07-26-2014, 06:38 PM
Major props to Rob for fixing my problems today. We took care of a boost leak issue and adjusted my ********* from rubbing. My elbow had a small hole in it and there was also a leak at the meth bung. The ********* were improperly installed by BMW when they replaced my turbos. Yes the replaced them with all my mods on but unfortunately they messed up on my *********. At least I got new turbos.
Rob is very knowledgeable and I would take my car to him again. He definitely goes above and beyond to make sure you are happy with his service. Thanks again Rob!
|2007 E92 SGM 335i|
Cobbv3 • BMS DCI & OCC • VRSF *** & FMIC • E85 • Custom Backend & Alpina TCU flash • ER CP • RB PCV+Cap
Walbro 255 • Rohana RC5 19s • Nittos 555 245/275 • Cyba Scoops • LUX V3 • M3 Cowl • ST Coils • LCI Tails
Default 07-27-2014, 12:31 PM
Thank you for the kinds words nguyenvn it means a lot! It was a pleasure working on your car. In addition, I appreciated the helping hand throughout the day while we worked on everything. I look forward to seeing future logs and hope you are much happier with how the car performs now.
Time to install a N55 DP so back to work!
mj888 mj888 is offline
Car: 2010 535I
Default 08-15-2014, 02:16 PM
I would personally like to thank Rob for his great work. He did an Intake Valve Cleaning. He is very knowledgeable and super professional, not to mention very honest and humble. The customer service that he provided was way better than what I would get at a dealership or any high end performance shop. He went beyond my expectation trying to troubleshoot my problems. You can’t get customer service like that anywhere else. If you need any kind of work done, I would highly recommend giving Rob a call.
1. Car warms up super-quick.
2. No more rough idles (mostly noticed in cold weather).
3. Acceleration is extremely linear and responsive.
4. Turbo lag has significantly decreased.
5. Engine noise has decreased.
pnguyen951 pnguyen951 is offline
Car: 335i convertible
Default 09-23-2014, 04:46 PM
Had walnut blasting, AFE intake installed, & jb4 installed. Rob did an exceptional job. He explained and showed me what he was doing as he was doing it. He is very knowledgeable.
As a newbie to bmw's, can be intimidating to go to dealerships and independant bmw shops for service, but Rob was really nice and easy to talk to.
Thanks Rob for the great work you did on my car. Will be back for future services.
Default 09-23-2014, 05:30 PM
Thank you for the awesome reviews guy! I really appreciate the feedback and its what keeps me going to help out all the local guys. Its been a while since I have posted due to staying so busy, but I am going to add some pictures of cars I have been working on
Default 09-23-2014, 05:36 PM
I haven't updated this post in what feels like a long time. This is mainly because I have been swamped with work over the last couple months. I have done over 50+ Walnut Shell Blasting now for local guys as well as many other common service jobs such as:
-Valve Cover Gaskets
-Oil Filter Housing Gaskets
-Replacement of Vacuum Lines
-Coolant Flushes
-Transmission Fluid Flushes
-Differential Flushes
-Oil Changes
-Other Services as well
Not to mention countless installs of mods for the cars as well including:
-Burger Motorsports JB4
-Down pipes
-Intakes
-Intercoolers
-Chargepipe / BOVs
-Low Pressure Fuel Pumps
-Exhausts, etc.
If anyone has any questions feel free to reach out to me and here are some pictures in the mean time to enjoy
Default 09-23-2014, 05:37 PM
More Pictures:
Default 09-23-2014, 05:41 PM
More Pictures: (part 2)
Default 09-23-2014, 06:32 PM
More Pictures: (part 3)
Whateva's Avatar
Whateva Whateva is offline
Car: E90
Default 10-11-2014, 12:02 AM
Rob's the man! He walnut blasted, changed the oil housing gasket along with oil and coolant and cleaned vanos solenoids in one day! My car runs like brand new and was able to turn my JB+ 100% with no more P0015 errors. He's a pro and will be returning to him for future maintenance.
Default 12-02-2014, 03:08 PM
Thanks for the kind words J! Appreciate it
Been staying very busy over the last few weeks. I will post an update with new pictures soon. Have been helping quite a few locals with all their N54 service and maintenance needs.
Seven11 Seven11 is offline
Car: 535i
Default 12-12-2014, 06:35 PM
why can't you be more closer to San Francisco!
i need a lot of things done
1. walnut blasting
2. jb4 install
3. intake install
4. diff fluid flush
5. valve cover gasket
6. spark plugs
7. transmission pan and fluid
8. new vacuum lines
and i am sure some more!
- BMW 535i - Sport - Sport Auto - JB4 G5 ISO - DCI - BMS E85 BackEnd via MHD - 19in M6 Wheels -
- Suzuki GSX-R750 - Akrapovic Titanium Exhaust - Mirror Block-Offs - WoodCraft RearSets - Yoshimura Frame Sliders -
tkong tkong is offline
Car: 2011 e90 space gray 335i
Default 12-13-2014, 08:26 PM
how much for a muffler install?
Default 01-11-2015, 10:25 PM
Bump! Thanks for all the support guys. As always, been staying busy and working on a lot of local cars
Default 02-15-2015, 02:34 PM
Feel free to reach out if anyone needs anything for their BMWs
samstryker's Avatar
samstryker samstryker is offline
Car: 2008 535xiT e61
Default 02-16-2015, 05:30 PM
I had Rob squeeze a giant 7" VRSF fmic into my e61 for me a while back. He did an amazing job! He took his time and made sure everything fit perfectly. The intercooler is still working flawlessly
Thanks Rob!
2008 e61 535xit: VTT GCs, Fuel-it PI, fuelab FPR w/ return line, stage 2 lpfp, fuelab "700" inline pump, RB external PCV, VRSF 7.5" race FMIC, Inlets, outlet, AR ***, 3" chargepiping, 3" exhaust, JB4, BMS PI controller
jtrejo jtrejo is offline
Car: 535 2008
Default 02-17-2015, 11:22 PM
might be interested in the walnut shell blasting
2015 535 - JB4 - Pure Turbos Stage 2 - VRSF DPipe- Burger Intake - Straight piped - MHD Backend Flash - BMS Meth - VRSF Intercooler - VRSF Charge Pipe - Dorch Stage 2 HPFP - Fuel it stage 2 LPFP
