drifter's Avatar
drifter drifter is offline
Car: N54 135i
Default Vanos help - 10-24-2020, 01:46 PM
Hi guys,
N54 starts and then dies . No error codes etc.
Timing has been performed and 100% correct, compression check and good.
All sensor checked and coming back good.
Engine loom every end checked for correct voltage, few came up bad so replaced the loom, checked new loom and all good.
DME sent off, cloned to another unit but still the same.
Disconnecting the top vanos solenoid and the car runs in limp mode.
Checked the live data on a snap on zues unit today and this is what I got.
I'm currently installing ISTA and will run a diag tomorrow.
Anyone have any idea?
N54 135i - GTX3582R - 7" VRSF IC - BMS Meth Kit - XtremeClutch ceramic twin disk - RTD shifter & a load of other bits
