Car: 2007 e90 335i
Default 504whp dyno of my pure stage 2 and logs - 07-16-2020, 02:11 PM
went to a dyno today and did 3 dyno pulls. 2 pulls on map 7 and one pull on map 2. car made 504whp and 504wtq on map 7 and 451whp and 461wtq on map 2. The 328whp run is a friends 100% stock 2018 440i on the same dyno.
please look at my logs and tell me what need to be done. The car is running the mhd back end flash e85 flash for hybrid turbos. The car runs 50%91 octane and 50%e85 which comes on to about 44%-47% ethanol. Car has full bolt ons with the pure stage 2 DD turbos with RB inlets. stage 2 low pressure pump and i do not have port injection. Car is also running spec stage 2+clutch and oem dual mass flywheel.
2007 e90 335i
Default 07-17-2020, 05:23 AM
Can you separate the logs?
Car: 2007 e90 335i
Default 07-17-2020, 12:42 PM
here is another log
2007 e90 335i
Car: 2007 e90 335i
Default 07-20-2020, 12:21 PM
any help here??
2007 e90 335i
Default 07-21-2020, 05:55 AM
Hpfp looks to be tanking from 4K to 5k
Your riding close to your 22 psi boost safety - may want to up that to 22-23 or adjust your duty bias settings a bit
