918mostwanted 918mostwanted is offline
Default log review - 12-01-2019, 05:06 PM
here's a couple logs after getting a couple things sorted out, please let me know if these look any better. and what I could do to improve. I have user setting currently on default for stock twins because I noticed some turbo flutter during WOT on hybrid twin settings. thanks in advance
E82(AT) w/hybrid twins, cp w/bov, catles dowpipes, stage 2 lpfp, jb4 w/mhd bef, relocated stainless inlets, 3.5 tmap. on 91 oct.
Haynpunch's Avatar
Car: 07 E90 335i
Default 12-01-2019, 06:38 PM
What Fuel?
Steering Wheel Menu 4 setting?
Are you running D.P. Fix full time? Noticed the description in log...
I would stick with map 2 for now until you get everything sorted out...not a fan of map 5 / but to each his own
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Default 12-01-2019, 07:12 PM
Originally Posted by Haynpunch
What Fuel?
91 oct and 4/2 and the fix was for reference cause when I took my last logs one of the dowpipe was loose and somewhat coming off. So no dowpipe fix module, I’ve heard they cause more problems then solve.
Haynpunch's Avatar
Car: 07 E90 335i
Default 12-01-2019, 08:03 PM
double check your FUD options, I could be wrong
and yes running D.P. Fix full time is a no go....
07 E90 AT - xHP
FBO
Hybrids
Default 12-01-2019, 10:25 PM
Need better logs.
3rd gear only, 2k to redline, WOT, traction control off
Default 12-01-2019, 11:09 PM
Need better logs.
Thatís what I did tho?
Default 12-01-2019, 11:20 PM
Iíll get another one tho just to make sure.
Haynpunch's Avatar
Car: 07 E90 335i
Default 12-01-2019, 11:32 PM
you went from 3rd to 2nd to 3rd in both logs
you need to log without hitting the kickdown
07 E90 AT - xHP
FBO
Hybrids
Default 12-02-2019, 12:19 AM
Ahh got you it’ll be up in 20 min.
Default 12-02-2019, 01:21 AM
Need better logs.
when I'm in m mode and wot if I go past the resistor it automatically down shifts for me but I took logs of both pedal past resistor and one just before the resistor. then I made some minor adjustments on the db and took another log, it felt and sounded a lot better. I get a little bit of a flutter as its building boost any pointers that?
Haynpunch's Avatar
Car: 07 E90 335i
Default 12-02-2019, 01:50 AM
why did you adjust the DB settings?
what do you have enabled in FUD settings?
07 E90 AT - xHP
FBO
Hybrids
Default 12-02-2019, 03:35 AM
Because I’m had them at default settings for hybrid and it felt super laggy and I started reading in the hybrid thread that terry had changed the 50 dB to 60 and that if you adjust in small amounts you could dial it in so I thought I’d give it a try. And I have ff off, wastgate adapt on, and fuel adapt on. Those are the ones I remember of the top of my head. And I typed it wrong it’s more of a surge not flutter. Sorry. What’s a good base dB setting? The one on the hybrid thread didn’t feel right and There’s so much in the thread to go thru. I’m gonna get a custom tune in the next couple weeks but so far everyone I’ve talked to has told me to go full mhd so I’m still checking out all my options
Haynpunch's Avatar
Car: 07 E90 335i
Default 12-02-2019, 12:02 PM
I would only enable bit6
Put all duty bias back to original hybrid settings
07 E90 AT - xHP
FBO
Hybrids
Default 12-02-2019, 03:02 PM
Done. Iíll just leave it alone till I get the custom tune. I appreciate the help.
Haynpunch's Avatar
Car: 07 E90 335i
Default 12-02-2019, 03:59 PM
Even with a custom BEF the tuner will have you do pretty much the same as these guys do as far as adjustments
If you go custom full flash then itís a lot simpler
Post a log with updated setting
07 E90 AT - xHP
FBO
Hybrids
Default 12-02-2019, 06:48 PM
You might have a boost leak
FF is about maxes @ 14x
Keep your DB settings to our default for now- manually lower your FF to 70-80 & do a few logs, if your WGDC stays high & FF shoots back up, you need to start looking for a leak- this could also be why things feel ďlaggyĒ
