RAWe36boost's Avatar
RAWe36boost RAWe36boost is offline
Car: E36 Turbo, E92 335xi, E53 X5
Default Log review - 09-15-2019, 08:11 PM
hello, i just installed pure stage 2 turbos, inlets, ******* *********, active bov, walbro 450 lpfp, hybrid pump bef. running map 6 with hybrid turbo settings.
please review log.2019-09-15 18_17_08_Gear-3_Map-6.csv
Default 09-15-2019, 09:38 PM
Log is too short - we need a WOT pull from 2k to redline.
Also- try logging map 1 first, if just Installed
Default 09-16-2019, 06:29 AM
ok, will do thanks.
Default 09-17-2019, 08:11 PM
Hey guys, just took another log, map 1 2k to redline, if you guys can please review, thanks.
Default 09-18-2019, 06:53 AM
In general looks okay.
Timing looks good, as does boost (slightly over target, but not bad)
HPFP might start to be an issue as you jump up in maps- trims are hovering in the 40s too.
What is your fuel mix?
Default 09-18-2019, 07:48 PM
pump 93. Planning on mixing in some e85 occasionally.
Default 09-20-2019, 07:28 AM
You can start to introduce some e if you want.
Just be mindful of fuel trims & your HPFP
Most start with e30 or so
Default 09-20-2019, 08:37 AM
hey Dave,
got some since last log, post *** sensors were mixed, which probably caused high trims, and also leaky injector in cyl 4.
Repaired issues this morning, so i will take another log and report back.
thanks!
Default 09-20-2019, 10:25 AM
Originally Posted by RAWe36boost
hey Dave,
thanks!
Default 09-22-2019, 04:49 PM
Hey Guys, here are some logs of map1 and map6 after repairing some of the issues. i think the fuel trims look much better. Pleases take a look.
Joelkswagen Joelkswagen is offline
Default 09-22-2019, 10:31 PM
I am fairly amateur at analyzing hybrid logs, but your map 1 looks good to me aside from somewhat high IAT (not sure your locale).
Your map 6 is definitely too much boost for the fuel. Pulling lots of timing, trims are maxed, and your HPFP is dipping below 9. For map 6 you should probably run more E and drop the boost, maybe to 21 psi for your next log?
You aren't Port injected are you? I think for that high of boost you will start needing to look into that for fueling. Someone correct me if I am wrong. your HPFP is struggling at 25 psi, but I believe that is totally normal without PI (you need PI for this).
Default 09-23-2019, 07:32 AM
What are you using for fueling?
Your map 6 looks a mess- timing corrections & trims nearly max out. Need to back things down
Default 09-23-2019, 09:40 AM
This was on 93 oct. jb4 hybrid turbo pump bef on setup base settings. no port injection for now, just a walbro 450 lpfp in tank. What do you recommend for now, with out port injection? What should i adjust exactly. i have been running on map 1, just threw in a map 6 to see. How does the map 1 log look?
Default 09-23-2019, 02:05 PM
You can introduce some ethanol if you want. If you just want to see the corrections go away- throw in 1-2 gallons of e85.
If you want to run ethanol in general- meausre your e-content @ the pump & let's start w. E30 or so.
Default 09-23-2019, 02:56 PM
Ok, will do. Am i safe with 93 oct in map1? And just add ethanol with map 6? And also when adding ethanol should i use e85 bef?
Rule77's Avatar
Rule77 Rule77 is offline
Car: 08 E90 335i
Default 09-23-2019, 03:55 PM
You can run e30 maybe e40 on the pump bef. If you decide to go e40 or more youll need the E85 bef.
08 E90 335i - MONTEGO BLUE - JB4/MHD E85 BEF
BMS DCI - BMS OCC - NRW CARBON COWL FILTERS
MMP CHARGEPIPE - TIAL BOV - VRSF 7.5 RACE FMIC
VRSF DPs - VRSF INLETS - VRSF OUTLETS
BMS PEDAL TUNER - RB PCV VALVE - 3.5 BAR TMAP
NGK 97506 @.022 - PFS STAGE 2 LPFP - H&R SPRINGS
SPOOL PERFORMANCE ETHANOL ANALYZER
MISHIMOTO 25 ROW OIL COOLER
BMS SPORT OIL COOLER VALVE - NRW V1 PADDLES
MISHIMOTO 15 ROW TRANSMISSION COOLER
19 666m WHEELS - HANKOOK VENTUS V12 EVO 2s
Default 09-23-2019, 10:49 PM
You can run e85 on any of the maps, not just 6
Our pump flash is ok for up to around e30/40
