Andrew3424 Andrew3424 is offline
Car: E92 335
Default Installing new pure cast turbos - 06-04-2019, 06:42 AM
Hey guys so I bit the bullet on my 2008 335i and just purchased the new pure cast turbos! I'm already fbo, stage 2 lpfp, exhaust, *********, intercooler, intakes, charge pipe , bov, running e70 on backend flash. have done all of my maintenance water pump/ thermostat, vanos solenoids ,starter, alternator, power steering pump etc.... I've replaced a ton of stuff over the past 5 years. My question is I'm replacing my 100k stock turbos with probably the worst wastegate rattle in the world after years of abuse *! I've already replaced all vacuum lines trying to chase down an old boost leak. Installed new Rb pcv valves. Ive also ordered new boost solenoids , vacuum canisters, 2 step cold plugs , and TMAP 3.5 sensor. I want a completely new turbo set up without leaving something out What else am I missing? Should I also replace my turbo oil feed lines? Sorry for the long read and thanks for your help.
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 06-04-2019, 10:01 AM
As you are already there and subframe out, do the oil pan gasket and engine mounts.
nissubaru nissubaru is offline
Car: 2009 335i M-Sport
Default 06-04-2019, 01:19 PM
Well, you didn't list any of the hardware or gaskets necessary for the turbo replacement...so there's that.
They sell kits for it but there's probably $75-100 worth of bull**** you don't need.
Necessary bits in my opinion:
6x 11627558906
16x 18407502196
16x 11127593376
12x 11427558936
2x 11422246091
2x 11427563453
2x 13717568030
2x 18307553601
2x 18307553603 - these are the ******** gaskets, skip it if you already have some
1x 11537545302
Should be it.
Car: E92 335
Default 06-04-2019, 03:18 PM
Car: E92 335
Default 06-04-2019, 03:20 PM
6x 11627558906
16x 18407502196
16x 11127593376
12x 11427558936
2x 11422246091
2x 11427563453
2x 13717568030
2x 18307553601
1x 11537545302
Should be it.
Yes forgot to add I already bought the turbo install kit from pure was there any other parts that I need not in the general install kit?
Default 06-04-2019, 03:36 PM
Water pump bolts maybe
Got Boost?'s Avatar
Got Boost? Got Boost? is offline
*Rollin 3rd*
Car: E93 335i
Default 06-04-2019, 08:22 PM
The musts:
Rear main seal. Get a new one in there
If you have 3 pedals and plan to go beyond 550whp get an upgrade flywheel/clutch
Same applies to fuel regardless of pedal count. Get a dual lpfp kit and start thinking about port injection because why not. Dont ever want to fuel starve it
Inlets/outlets Do homework for the right ones and make them fit right or don't install...
Plug the head and catch can the high/low sides
Tune it, send it, log it.
lshaw13 lshaw13 is offline
Default 06-18-2019, 03:41 PM
how are the turbos running?
09 e90335i 6mt
15 F15 X5
17 Subaru Forester XT
Car: E92 335
Default 06-18-2019, 03:50 PM
Still waiting on them.... hopefully by the end of the week will keep it updated
Car: E92 335
Default 06-18-2019, 07:53 PM
QUOTE=Got Boost?;636053]The musts:
What did you mean plug the head and I have the bms catch can which other one do I need thanks
Tune it, send it, log it.[/QUOTE]
Default 06-19-2019, 11:55 AM
Ever get these installed?
Car: E92 335
Default 06-19-2019, 05:52 PM
Hey Dave I am currently still waiting hopefully within the next week or so Iíll keep everyone updated
fazman fazman is offline
Car: e90 FBO
Default 08-11-2019, 01:31 AM
Any update? I'm looking to get the new cast n54 PURE's as well.
